Customer Specification
PART NO: 904 Series
M12‐A Die Cast Passive I/O Box
Issue: 1 Issue Date: 8/20/2016 Effective Date: 8/20/2016
Dimensions
Technical Data
Box Configuration
Ports
Channels per Port
LED
Code Type
Housing
Contact
Receptacle Shell
O‐Ring
Electrical
Contact Resistance
Voltage Rating
Current Rating
Insulation Resistance
UL File
Cable Construction
Conductor Size
Outer Jacket Material
Outer Diameter
Color
4
1
Yes
A
Die Cast Zinc
Copper Alloy, Gold Plated
Copper Alloy, Nickel Plated
FKM
≤5mΩ
30V DC
4A per port/8A max. Total @ 40°C
>109Ω
E485582
3 x .75mm2 & 4 x 0.34mm2
Zero Halogen PUR
.268”
Black
Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207
www.alphawire.com | 1-800-52 ALPHA
1
PART NO: 904 Series
Suitable for C‐Track
Environmental
Degree of Protection
Operating Temperature
Range
RoHS
REACH Regulation (EC
1907/2006)
Accessories Included
2 Dust Covers for unused
sockets
5 attachable labels
Ordering Information
904‐5M NC032
904‐10M NC032
904‐CN NC032
Yes
IP 65/ IP 67
‐40C (‐40F)/ +80C (+176F) (C‐Track and UL
Max. 60C (+140F)
All materials used in the manufacture of
this part meet the requirements of
European Directive 2011/65/EU regarding
the restriction of use of certain hazardous
substances in electrical and electronic
equipment. Exemption used; 6a.
This product does not contain Substances
of Very High Concern (SVHC) listed on the
European Union’s REACH candidate list in
excess of 0.1% mass of the item.
Description
5 Meters
10 Meters
Connectorized
Quantity
Each
Each
Each
2
PART NO: 904 Series
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time
of this publication, information and specifications described herein are subject to error or omission
and to change without notice, and the listing of such information and specifications does not
ensure product availability. Alpha provides the information and specification herein on an “AS IS”
basis, with no representations or warranties, whether express, statutory or implied. In no event
will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such
damages, whether in an action under contact, negligence or any other theory, arising out of or in
connection with the use, or inability to use, the information or specification described herein.
3
很抱歉,暂时无法提供与“904-5MNC032”相匹配的价格&库存,您可以联系我们找货
