TSP-L-0300-103-1%-RH 数据手册
TSP
ThinPot
Features
- Linear Position Sensor
- Half the width of the SoftPot
- IP64 Dust Proof, Splash Proof
- Polyester Substrate
- 3M Pressure Sensitive Adhesive (PSA)
- Upon Request
- Male or Female Nicomatic or Berg
Connectors
- Wiper of 0.7-2.2 Newton Force to Actuate
Part
SoftPot
Mechanical Specifications
Electrical Specifications
-Life Cycle: >1 million
-Height: 0.51mm (0.020")
-Actuation Force (with a 6mm wide active cavity):
-40°C 0.9 to 2.2 N
-25°C 0.9 to 2.2 N
+23°C 0.7 to 1.8 N
+50°C 0.7 to 1.8 N
-Resistance - Standard: 10k Ohms
(lengths >300mm = 20k Ohms)
-Resistance - Custom: 1k to 100k Ohms
-Resistance Tolerance: ±20%
-Effective Electrical Travel: 8 to 2000mm
-Linearity (Independent): Linear ±1% or ±3%
Rotary ±3% or ±5%
-Repeatability: No hysteresis, but with any wiper
looseness some hysteresis will occur
-Power Rating (depending on size, varies with
length and temperature): 1 Watt max. @ 25°C,
0.5 Watt recommended
-Resolution: Analog output theoretically infinite;
affected by variation of contact wiper surface
area.
-Dielectric Value: No affect @ 500VAC for 1
minute
Environmental Specifications
-Operating Temperature: -40°C to +50°C
-Humidity: No affect @ 95% RH, 4hrs 50°C
-IP Rating of Active Area: IP64
Dimensional Diagram - Stock Linear ThinPot
TAIL LENGTH [T]
PART LENGTH [P]
ACTIVE LENGTH [A]
3.17 [0.125]
2 PLCS
6.00 [0.236]
ACTIVE WIDTH
10.00 [0.394]
2.00 [0.079]
2 PLCS
A
12.50mm
0.492"
25.00mm
0.984"
50.00mm 100.00mm 150.00mm 170.00mm 200.00mm 300.00mm 400.00mm 500.00mm 750.00mm 1000.00mm
6.693"
29.528"
39.370"
1.969"
3.937"
5.906"
7.874"
11.811"
15.748"
19.685"
P
18.85mm
0.742"
31.35mm
1.234"
56.35mm
2.219"
T
12.70mm
0.500"
spectrasymbol.com
106.35mm
4.187"
156.35mm
6.156"
176.35mm
6.943"
206.35mm
8.124"
306.35mm
12.061"
406.35mm
15.998"
506.35mm
19.935"
756.35mm
29.778"
1006.35mm
39.620"
25.00mm
0.984"
Rev A1 - Page 1
(888) 795-2283
Electrical Schematic
Material Cross-Section
PIN 3 (GND)
(LEFT BUS BAR)
0.41 [0.016] CIRCUIT
PIN 2
(COLLECTOR)
0.05 [0.002] 3M 200MP ADHESIVE
PIN 1 (V+)
0.46 [0.018] TOTAL THICKNESS
(RIGHT BUS BAR)
10K or 20K
How to Order - Linear ThinPots
TSP
L
0050
103
Series
Model
Active Length
Resistance
TSP = ThinPot
L = Linear
0012 = 12,5mm
0025 = 25mm
0050 = 50mm
0100 = 100mm
0150 = 150mm
0170 = 170mm
0200 = 200mm
0300 = 300mm
0400 = 400mm
0500 = 500mm
0750 = 750mm
1000 = 1000mm
3%
Active Lengths < 300mm
103 = 10 KOhm
Active Lengths > 300mm
203 = 20 KOhm
ST
Connectors
ST = Solder Tab
MP = Male Pins
RH = Receptacles w/Plain Housing
RL = Receptacles w/Latch Housing
RD = Receptacles w/Detent Housing
B = FCI/Berg Clincher
Ind. Linearity
1% = ±1%
3% = ±3%
Standard Connector Options
Crimpflex Solder Tab (ST)
Crimpflex Short Male Pins (MP)
Crimpflex Female Receptacles with a
Plain Housing (RH)
Latch Housing (RL)
with a Detent Housing (RD)
FCI/Berg Clincher (B)
spectrasymbol.com
Page 2
(888) 795-2283
Customization
Customize the size, shape, and even the number of tracks. Such custom requests, for example, can be: multiple
ganged sensors (up to 40 tracks); serpentine active area track; custom lengths 10mm-2000mm; custom rotary
diameters, etc. Feel free to contact Spectra Symbol with your custom request at sales@spectrasymbol.com or
(888)795-2283.
How It Works
In simple terms, the ThinPot membrane potentiometer is a resistive element, which comprises a conductive
resistor, a sealed encasement and a simple wiper assembly. A membrane potentiometer can also function as a
voltage divider.
The ThinPot is a three-wire system with two resistive output channels and an electrical collector channel.
Top Circuit (Collector)
Circuit Spacer
Bottom Circuit (Resistor)
Bottom Adhesive
By pressing a wiper down onto the top circuit the SoftPot produces the desired electrical output. The "wiper" is a
non-conductive mechanism that depresses the top circuit actuating the potentiometer from the outside of the
element. The top and bottom circuits are separated by 0.15mm (0.006") of spacer adhesive build-up and contact
between the circuit occurs by pressure (usually 0.7-1.8 Newtons) from the wiper on the top circuit, pushing down
until the top circuit connects with the bottom circuit to create a potentiometric output.
The construction of the wiper design can adapt to any application because most materials can serve as the wiper:
plastics, metals, sliders, rollers, wheels, etc. Also, the ThinPot can also be manually (hand) actuated.
spectrasymbol.com
Page 3
(888) 795-2283
Diagram - Stock Rotary ThinPot
Ø35.40 [Ø1.394]
CENTER OF TRACK
6.00 [0.236]
ACTIVE WIDTH
10.16 [0.400]
351°
ACTIVE
ANGLE
PIN 1
Ø45.40 [Ø1.787]
Ø25.40 [Ø1.000]
THRU HOLE
50.00 [1.969]
PIN 3 (GND)
(LEFT BUS BAR)
PIN 2
(COLLECTOR)
PIN 1 (V+)
10K
(RIGHT BUS BAR)
How to Order - Rotary ThinPot
TSP
R
Series
Model
TSP = ThinPot
R = Rotary
0036
Center of
Active Track
0036 = 35.40mm
0351
103
Active Angle
Resistance
0351 = 351°
103 = 10 KOhm
Ind. Linearity
3% = ±3%
5% = ±5%
spectrasymbol.com
Page 4
5%
ST
Connectors
ST = Soldertab
MP = Male Pins
(888) 795-2283
TSP-L-0300-103-1%-RH 价格&库存
很抱歉,暂时无法提供与“TSP-L-0300-103-1%-RH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+235.975951+28.19763
- 10+188.8659410+22.56828
- 25+172.6541625+20.63108
- 50+161.2396050+19.26711
- 100+150.49910100+17.98369
- 250+137.27026250+16.40293
- 500+127.94721500+15.28888
