Features
- High Life Cycle
- High Temperature Capability
- Linear Position Sensor
- IP65 Dust Proof, Water Proof (Intense Spray)
- Fiberglass Substrate
- 3M Pressure Sensitive Adhesive (PSA)
- Upon Request
- Male or Female Nicomatic Connectors
- Wiper of 1-3 Newton Force to Actuate
Part
- Contactless Options Available
Mechanical Specifications
Electrical Specifications
-Life Cycle: >10 million
-Height: 0.51mm (0.020")
-Actuation Force (with a 10mm wide active cavity):
-40°C 3.0 to 5.0 N
-25°C 2.0 to 5.0 N
+23°C 0.8 to 2.0 N
+85°C 0.7 to 1.8 N
-Resistance - Standard: 10k Ohms
(lengths >300mm = 20k Ohms)
-Resistance - Custom: 5k to 100k Ohms
-Resistance Tolerance: ±20%
-Effective Electrical Travel: 10 to 1200mm
-Linearity (Independent): Linear ±1% or ±3%
Rotary ±3% or ±5%
-Repeatability: No hysteresis, but with any wiper
looseness some hysteresis will occur
-Power Rating (depending on size, varies with
length and temperature): 1 Watt max. @ 25°C,
0.5 Watt recommended
-Resolution: Analog output theoretically infinite;
affected by variation of contact wiper surface
area.
-Dielectric Value: No affect @ 500VAC for 1
minute
Environmental Specifications
-Operating Temperature: -40°C to +85°C
-Humidity: No affect @ 95% RH, 24hrs 60°C
-IP Rating of Active Area: IP65
Dimensional Diagram - Stock Linear HotPots
PART LENGTH [P]
10.16 [0.400]
TAIL WIDTH
ACTIVE LENGTH [A]
PIN 1
20.32 [0.800]
6.60 [0.260]
TAIL LENGTH [T]
7.11 [0.280]
ACTIVE WIDTH
7.93 [0.312]
A
12.50mm
0.492"
25.00mm
0.984"
50.00mm 100.00mm 150.00mm 170.00mm 200.00mm 300.00mm 400.00mm 500.00mm 750.00mm 1000.00mm
6.693"
29.528"
39.370"
1.969"
3.937"
5.906"
7.874"
11.811"
15.748"
19.685"
P
28.36mm
1.117"
40.86mm
1.609"
65.86mm
2.593"
T
12.70mm
0.500"
spectrasymbol.com
115.86mm
4.562"
165.86mm
6.531"
185.86mm
7.318"
215.86mm
8.499"
315.86mm
12.436"
415.86mm
16.373"
515.86mm
20.310"
765.86mm
30.153"
1015.86mm
39.995"
24.89mm
0.980"
Rev F2 - Page 1
(888) 795-2283
Diagram - Stock Rotary HotPot
10.01 [0.394]
ACTIVE WIDTH
Ø65.74 [Ø2.588]
OUTSIDE PERIMETER
Ø25.40 [Ø1.000]
THRU HOLE
Ø45.57 [Ø1.794]
(CENTER OF TRACK)
10.16 [0.400]
353°
ACTIVE
ANGLE
PIN 1
5.08 [0.200]
5.08 [0.200]
111.88 [4.405]
Electrical Schematic
Material Cross-Section
PIN 3 (GND)
(LEFT BUS BAR)
0.41 [0.016] CIRCUIT
PIN 2
(COLLECTOR)
0.05 [0.002] 3M 200MP ADHESIVE
PIN 1 (V+)
10K
0.46 [0.018] TOTAL THICKNESS
(RIGHT BUS BAR)
How to Order - Rotary HotPot
HP
R
Series
Model
HP = HotPot
R = Rotary
0046
Center of
Active Track
0046 = 45.57mm
0353
103
Active Angle
Resistance
0353 = 353°
103 = 10 KOhm
Ind. Linearity
3% = ±3%
5% = ±5%
spectrasymbol.com
Page 5
5%
ST ST
Connectors
ST = Solder Tab
MP = Male Pins
RH = Receptacles w/Plain Housing
RL = Receptacles w/Latch Housing
RD = Receptacles w/Detent Housing
(888) 795-2283
10.01 [0.394]
ACTIVE WIDTH
Ø65.74 [Ø2.588]
OUTSIDE PERIMETER
Ø25.40 [Ø1.000]
THRU HOLE
Ø45.57 [Ø1.794]
(CENTER OF TRACK)
10.16 [0.400]
353°
ACTIVE
ANGLE
PIN 1
5.08 [0.200]
5.08 [0.200]
111.88 [4.405]
PIN 3 (GND)
(LEFT BUS BAR)
PIN 2
(COLLECTOR)
PIN 1 (V+)
10K
(RIGHT BUS BAR)
HP
R
Series
Model
HP = HotPot
R = Rotary
0046
Center of
Active Track
0046 = 45.57mm
0353
103
Active Angle
Resistance
0353 = 353°
103 = 10 KOhm
Ind. Linearity
3% = ±3%
5% = ±5%
spectrasymbol.com
Page 5
5%
ST ST
Connectors
ST = Solder Tab
MP = Male Pins
(888) 795-2283
HP-L-0500-203-3%-RH 价格&库存
很抱歉,暂时无法提供与“HP-L-0500-203-3%-RH”相匹配的价格&库存,您可以联系我们找货
