HP-L-1000-203-1%-RH
HP-L-1000-203-1%-RH
    SPECTRASYMBOL
    SENSOR HOTPOT 20K OHM 1000MM
HP-L-1000-203-1%-RH 数据手册
Features - High Life Cycle - High Temperature Capability - Linear Position Sensor - IP65 Dust Proof, Water Proof (Intense Spray) - Fiberglass Substrate - 3M Pressure Sensitive Adhesive (PSA) - Upon Request - Male or Female Nicomatic Connectors - Wiper of 1-3 Newton Force to Actuate Part - Contactless Options Available Mechanical Specifications Electrical Specifications -Life Cycle: >10 million -Height: 0.51mm (0.020") -Actuation Force (with a 10mm wide active cavity): -40°C 3.0 to 5.0 N -25°C 2.0 to 5.0 N +23°C 0.8 to 2.0 N +85°C 0.7 to 1.8 N -Resistance - Standard: 10k Ohms (lengths >300mm = 20k Ohms) -Resistance - Custom: 5k to 100k Ohms -Resistance Tolerance: ±20% -Effective Electrical Travel: 10 to 1200mm -Linearity (Independent): Linear ±1% or ±3% Rotary ±3% or ±5% -Repeatability: No hysteresis, but with any wiper looseness some hysteresis will occur -Power Rating (depending on size, varies with length and temperature): 1 Watt max. @ 25°C, 0.5 Watt recommended -Resolution: Analog output theoretically infinite; affected by variation of contact wiper surface area. -Dielectric Value: No affect @ 500VAC for 1 minute Environmental Specifications -Operating Temperature: -40°C to +85°C -Humidity: No affect @ 95% RH, 24hrs 60°C -IP Rating of Active Area: IP65 Dimensional Diagram - Stock Linear HotPots PART LENGTH [P] 10.16 [0.400] TAIL WIDTH ACTIVE LENGTH [A] PIN 1 20.32 [0.800] 6.60 [0.260] TAIL LENGTH [T] 7.11 [0.280] ACTIVE WIDTH 7.93 [0.312] A 12.50mm 0.492" 25.00mm 0.984" 50.00mm 100.00mm 150.00mm 170.00mm 200.00mm 300.00mm 400.00mm 500.00mm 750.00mm 1000.00mm 6.693" 29.528" 39.370" 1.969" 3.937" 5.906" 7.874" 11.811" 15.748" 19.685" P 28.36mm 1.117" 40.86mm 1.609" 65.86mm 2.593" T 12.70mm 0.500" spectrasymbol.com 115.86mm 4.562" 165.86mm 6.531" 185.86mm 7.318" 215.86mm 8.499" 315.86mm 12.436" 415.86mm 16.373" 515.86mm 20.310" 765.86mm 30.153" 1015.86mm 39.995" 24.89mm 0.980" Rev F2 - Page 1 (888) 795-2283 Diagram - Stock Rotary HotPot 10.01 [0.394] ACTIVE WIDTH Ø65.74 [Ø2.588] OUTSIDE PERIMETER Ø25.40 [Ø1.000] THRU HOLE Ø45.57 [Ø1.794] (CENTER OF TRACK) 10.16 [0.400] 353° ACTIVE ANGLE PIN 1 5.08 [0.200] 5.08 [0.200] 111.88 [4.405] Electrical Schematic Material Cross-Section PIN 3 (GND) (LEFT BUS BAR) 0.41 [0.016] CIRCUIT PIN 2 (COLLECTOR) 0.05 [0.002] 3M 200MP ADHESIVE PIN 1 (V+) 10K 0.46 [0.018] TOTAL THICKNESS (RIGHT BUS BAR) How to Order - Rotary HotPot HP R Series Model HP = HotPot R = Rotary 0046 Center of Active Track 0046 = 45.57mm 0353 103 Active Angle Resistance 0353 = 353° 103 = 10 KOhm Ind. Linearity 3% = ±3% 5% = ±5% spectrasymbol.com Page 5 5% ST ST Connectors ST = Solder Tab MP = Male Pins RH = Receptacles w/Plain Housing RL = Receptacles w/Latch Housing RD = Receptacles w/Detent Housing (888) 795-2283 Diagram - Stock Rotary HotPot 10.01 [0.394] ACTIVE WIDTH Ø65.74 [Ø2.588] OUTSIDE PERIMETER Ø25.40 [Ø1.000] THRU HOLE Ø45.57 [Ø1.794] (CENTER OF TRACK) 10.16 [0.400] 353° ACTIVE ANGLE PIN 1 5.08 [0.200] 5.08 [0.200] 111.88 [4.405] Electrical Schematic Material Cross-Section PIN 3 (GND) (LEFT BUS BAR) 0.41 [0.016] CIRCUIT PIN 2 (COLLECTOR) 0.05 [0.002] 3M 200MP ADHESIVE PIN 1 (V+) 10K 0.46 [0.018] TOTAL THICKNESS (RIGHT BUS BAR) How to Order - Rotary HotPot HP R Series Model HP = HotPot R = Rotary 0046 Center of Active Track 0046 = 45.57mm 0353 103 Active Angle Resistance 0353 = 353° 103 = 10 KOhm Ind. Linearity 3% = ±3% 5% = ±5% spectrasymbol.com Page 5 5% ST ST Connectors ST = Solder Tab MP = Male Pins RH = Receptacles w/Plain Housing RL = Receptacles w/Latch Housing RD = Receptacles w/Detent Housing (888) 795-2283
HP-L-1000-203-1%-RH
物料型号:HoTPOT
器件简介:HoTPOT是一种高寿命、高温度能力的线性位置传感器,具有IP65防尘防水特性,使用3M压敏胶。
引脚分配:文档中未明确列出引脚分配,但提供了电气原理图,显示了GND、COLLECTOR和V+的连接。
参数特性: - 工作寿命:超过1000万次 - 工作温度:-40°C至+85°C - 湿度:在95% RH,60°C下24小时无影响 - IP等级:IP65 - 电阻:标准为10k Ohms,长度超过300mm为20k Ohms,可定制5k到100k Ohms - 电阻公差:±20% - 有效电气行程:10至1200mm - 线性度:线性±1%或±3%,旋转±3%或±5% - 重复性:无滞后,但任何刮水器松动都可能产生滞后 - 功率等级:最大1瓦特@25°C,推荐0.5瓦特 - 分辨率:模拟输出理论上无限,受接触刮水器表面积变化影响 - 介电强度:在500VAC下1分钟无影响
功能详解:HoTPOT传感器提供精确的位置反馈,适用于需要高可靠性和稳定性的应用。
应用信息:适用于需要精确位置检测的工业和汽车应用。
封装信息:提供了线性和旋转HoTPOT的尺寸图,包括不同长度和宽度的规格。
HP-L-1000-203-1%-RH 价格&库存
很抱歉,暂时无法提供与“HP-L-1000-203-1%-RH”相匹配的价格&库存,您可以联系我们找货
