SFH7771
SFH7771
    AMSOSRAM(艾迈斯半导体)
    UFDFN6_EP
    CHIPONBOARD
SFH7771 数据手册
Ambient Light and Proximity Sensor Version 1.1 SFH 7771 Features: • Proximity sensor (PS) - Detection range up to 250 mm - Suitable for emitters with 850nm...940nm - Very good performance behind dark cover glass with 940nm emitters - Programmable pulse current up to 200 mA • Ambient light sensor (ALS)  - detection range 0.001 - 43000 lx; - 50Hz/60Hz flicker noise suppression • I²C interface (max. 400kHz) • PS and ALS Interrupt function • Current consumption - typ. 0.8 µA in Standby mode - typ 90µA for ALS operation - typ 90µA for PS operation • Miniature package 2mm x 2.1mm x 0.6mm Applications Mobile phones PDAs and notebooks Cameras Consumer products • • • • Ordering Information Type: SFH 7771 22.04.2016 Ordering Code Q65111A4189 1 Version 1.1 SFH 7771 Application diagram 1 • • • • Cathode of the emitter is directly connected to the sensor (If max = 200 mA) Bypass capacitors for VDD and VLED are required for proper operation of the device. This example shows ADDR-Pin connected to VDD. Therefore the I²C-Address is 0111001 binary. Proposed size for the pull-up resistors are 10kOhm Version 1.1 2 Version 1.1 SFH 7771 Aplication diagram 2 • • • • Emitter is driven externally over a PMOS transistor Bypass capacitors for VDD and VLED are required for proper operation of the device. This example shows ADDR-Pin connected to GND. Therefore the I²C-Address is 0111000 binary. Proposed size for the pull-up resistors are 10kOhm Pin configuration Pin Name 22.04.2016 Function 1 ADDR I²C address pin; connect to  GND for 0x38 (7 bit-address) VDD for 0x39 (7 bit-address) 2 VDD 3 GND Ground pin 4 TEST Test pin; connect to GND 5 SCL I²C bus serial clock pin 6 SDA I²C bus serial data pin 7 INT Interrupt pin; open drain output; configured via I²C bus 8 LEDC LED cathode pin; current and interval is defined via I²C bus 3 Power supply pin Version 1.1 SFH 7771 Short Evaluation program Register Command Action 0x42 0x3F set LED pulse current to 200mA and ALS gain to x128 0x41 0x06 activate ALS & PS with a measurement repetition time of 100ms 0x44 read data read LSB of proximity measurement data 0x45 read data read MSB of proximity measurement data 0x46 read data read LSB of ambient light measurement of VIS diode 0x47 read data read MSB of ambient light measurement of VIS diode 0x48 read data read LSB of ambient light measurement of IR diode 0x49 read data read MSB of ambient light measurement of IR diode Wait 100ms I²C interface • I/O-pins are open drain type and logic high level is set with external pull-up resistors • SFH 7771 operates in slave mode. Slave address is 0111000 (0x38) when ADDR-Pin is connected to GND or 0111001 (0x39) if ADDR-pin is connected to VDD • Designed for the I²C Fast mode (400 kb/s) • Interrupt pin (INT): open-drain output (like SDA and SCL) Block diagram Version 1.1 4 Version 1.1 SFH 7771 Measurement modes  Mode Description OFF The device is inactive. Other units may use the I²C bus without any restrictions; I/O pins and INT are in high Z state. There is no sink current through the LED STAND-BY This is the initial mode after power-up. IDD is typ. 0.8µA. No measurement is performed. Device can be activated by I²C bus communication. Data registers can be read and written. ALS / PS free running Measurements are triggered internally by the SFH 7771. Stand-by / active mode for ALS and PS, measurement times, interrupt options and LED current can be adjusted via I²C register. Measurement results can be read from the data register, the status from the interrupt register.  If VDD exceeds the threshold voltage, the sensor will switch from OFF mode to STAND-BY mode. As shown in the transition-diagram above it is possible to switch between all modes without any restriction.  22.04.2016 5 Version 1.1 SFH 7771 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Storage temperature range Tstg -40 ... 100 °C Operating temperature range Top -40 ... 85 °C Maximum supply voltage (between VDD and GND) VDD 4.5 V Maximum voltage of SDA, SCL to GND VSDA, VSCL 4.5 V Maximum voltage of INT to GND VINT 7 V Maximum voltage of VLED to GND VLEDC 7 V Maximum Current of INT and SDA IINT / ISDA 7 mA 2 kV ESD Electrostatic discharge - Human Body Model (according to ANSI / ESDA JEDEC JS-001-2011; Class2) Version 1.1 6 Version 1.1 SFH 7771 Operating conditions Parameter Symbol Supply voltage VDD Ripple on supply voltage  (VDDmin and VDDmax must stay in the VDD range, DC ... 100MHz) VDD,rip VDD threshold voltage (voltage to initiate the start-up procedure) VDD;th Value Unit min. typ. max. 2.3 2.5 3.6 V 200 mV 2.3 V 1.7 Pull-up Voltage for INT VINT,pullup Pull-up Voltage for SCL and SDA VIO SDA and SCL input low level voltage VSDA_low, VSCL_low SDA and SCL input high level voltage VSDA_high, VSCL_high 1.26 SDA and SCL input current ISDA_low, ISCL_low -10 INT output low level voltage (IINT = 3 mA) (When INT is active VINT = low. When INT is inactive VINT = high.) VINT_low LEDC Terminal Voltage VLED Ripple VLED VLED,rip 1.65 0.7 5.5 V 3.6 V 0.54 V V 2.5 10 µA 0.4 V 5.5 V 200 mV Characteristics (TA = 25 °C) Parameter Symbol Value min. Unit typ. max. General Conditions for OFF mode VDD,off 0.5 V Current consumption in OFF mode (VDD < 0.5V) IDD,off 0 µA STAND-BY mode current consumption (Mode_control(0x41) = 0x00; VDD = 2.5V) IDD,stby 0.8 22.04.2016 7 1.5 µA Version 1.1 Parameter SFH 7771 Symbol Value min. Unit typ. max. Proximity Sensor (PS) Wavelength of maximum sensitivity S,max 850 nm Sensitivity range, =850nm Ee 1 ... 5000 µW/cm2 Proximity sensor output (Ee = 324 µW/cm2; Ambient irradiance = 0 µW/cm2) PSout 187 234 281 counts LED ON time for one measurement t LED ON 80 200 300 µs LED current, programmable ILED 25 Accuracy of LED current source (ALS_PS_CONTROL: LED Current = 0b00) ILED 22.5 Mean current consumption in PS mode  (current consumption of the pulsed LED is not included; MODE_CONTROL(0x41) = 0x03;  all other registers are default; VDD = 2.5V) 200 mA 25 27.5 mA IDD 90 150 µA Mean current consumption in PS mode during the 200µs LED pulse (t LED ON) (current consumption of the pulsed LED is not included) IDD 6.5 8.5 mA Temperature coefficient of proximity sensor TCPS 0.15 %/K Example of Proximity Setup When proximity sensing is performed, it is desirable that only light from a reflecting object reaches the SFH 7771. Depending on the optical setup, additional and unintended light paths from the IR-Emitter to the detector may exist, which is referred to as '(optical) crosstalk'. One measure to avoid such crosstalk is to add a separator between emitter and detector as drafted in the picture below. For details please refer to our SFH 7771 application note. Version 1.1 8 Version 1.1 SFH 7771 Characteristics (Ta = 25°C) Parameter Symbol Value min. Unit typ. max. Ambient Light Sensors: ALS_VIS and ALS_IR diode Wavelength of max. sensitivity for ALS_VIS Smax Spectral range of sensitivity (10% of Smax) of ALS VIS S10% Wavelength of max. sensitivity of ALS_IR Smax Spectral range of sensitivity (10% of Smax) of ALS IR S10% Illuminance measurement range is programmable (MODE_CONTROL (0x41) = 0x0A or 0x0B) 520 380 nm 950 880 nm nm 800 1070 nm 0.001 43000 lx ALS_VIS sensor output (1000lx; white LED; VDD = 2.5V) (MODE_CONTROL (0x41) = 0x08) (ALS_PS_CONTROL (0x42): Gain = X1) ALSVIS_out 1275 1500 1725 counts ALS_IR sensor output (324µW/cm²; IRED 850 nm; VDD = 2.5V) (MODE_CONTROL (0x41) = 0x08) (ALS_PS_CONTROL (0x42): Gain = X1) ALSIR_out 516 608 700 counts ALS_VIS sensor output at darkness (MODE_CONTROL (0x41) = 0x08) (ALS_PS_CONTROL (0x42): Gain = X1) ALSVIS_out 0 0 2 counts ALS_IR sensor output at darkness (MODE_CONTROL (0x41) = 0x08) (ALS_PS_CONTROL (0x42): Gain = X1) ALSIR_out 0 0 2 counts Resolution of the digital output signal based on gain settings for ALS_VIS: MODE_CONTROL (0x41) = 0x08 tint ALS = 100ms Gain X1 Gain X2 Gain X 64 Gain X 128 ALSVIS_out 0.68 0.34 0.01 0.005  High sensitive mode: MODE_CONTROL (0x41) = 0x0A tint ALS = 400ms Gain X 128 22.04.2016    0.001 9 lx/count Version 1.1 SFH 7771 Parameter Symbol Value min. Unit typ. Typical temperature coefficient for ALS measurement (1000lx; white LED; VDD = 2.5V) TCEv 0.2 Mean current consumption ((MODE_CONTROL (0x41) = 0x08) (other registers are in default) IDD 90 max. %/K Typical error by Flicker noise  (caused by bulbs (f=50 or 60Hz) or fluorescent lamps) 150 µA 3 % Diagrams for ALS sensor Relative Spectral Sensitivity of ALS_VIS Srel_VIS = f(λ) 100 Srel % Relative Spectral Sensitivity of ALS_IR Srel_IR = f(λ); 100% = maximum sensitivity of ALS_VIS diode OHF05595 80 80 70 70 60 60 50 50 40 40 30 30 20 20 10 10 0 700 0 400 500 600 700 800 900 nm 1100 800 900 1000 nm 1100 λ λ Version 1.1 OHF05596 100 Srel % 10 Version 1.1 SFH 7771 ALS_VIS sensitivity ranges ALS_VIS output f(Ev); white LED; f(sensitivity settings) Tint: integration time (register 0x41); X: gain settings (register 0x42) Direction Characteristic of ALS Vis diode Srel f(f)) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 22.04.2016 1.0 0.8 0.6 0.4 0 11 20 40 60 80 100 120 Version 1.1 SFH 7771 Diagrams for PS sensor PS sensitivity f(Ee= irradiance) VDD=2.5V; =850nm Version 1.1 12 Version 1.1 SFH 7771 Diagrams for IDD current consumption Current consumption IDD in standby mode IDD = f(VDD); Register 0x41= 0x00 IDD Current consumption IDD in PS mode IDD = f(VDD); Register 0x41= 0x03 OHF05602 4.5 µA OHF05603 120 µA IDD 100 3.5 80 3.0 60 2.5 2.0 40 1.5 20 1.0 0.5 2.2 2.5 2.8 3.1 0 2.2 3.4 V 3.7 Current consumption IDD in ALS mode IDD = f(VDD); Register 0x41= 0x08 OHF05604 160 µA IDD 120 100 80 60 40 20 0 2.2 2.5 2.8 3.1 3.4 V 3.7 VDD 22.04.2016 2.5 2.8 3.1 3.4 V 3.7 VDD VDD 13 Version 1.1 SFH 7771 Registers Register Overview Register Type 0x40 R/W SYSTEM_CONTROL System Control 0x41 R/W MODE_CONTROL ALS and PS General Control 0x42 R/W ALS_PS_CONTROL ALS Gain and PS current Control 0x43 R/W PERSISTENCE PS Interrupt Persistence Control 0x44 R PS_DATA_LSB Output data of PS measurement, LSB 0x45 R PS_DATA_MSB Output data of PS measurement, MSB 0x46 R ALS_VIS_DATA_LSB Output data of ALS_VIS measurement, LSB 0x47 R ALS_VIS_DATA_MSB Output data of ALS_VIS measurement, MSB 0x48 R ALS_IR_DATA_LSB Output data of ALS_IR measurement, LSB 0x49 R ALS_IR_DATA_MSB Output data of ALS_IR measurement, MSB 0x4A R/W INTERRUPT_CONTROL Interrupt Control 0x4B R/W PS_TH_LSB PS interrupt upper threshold level, LSB 0x4C R/W PS_TH_MSB PS interrupt upper threshold level, MSB 0x4D R/W PS_TL_LSB PS interrupt lower threshold level, LSB 0x4E R/W PS_TL_MSB PS interrupt lower threshold level, MSB 0x4F R/W ALS_VIS_TH_LSB ALS_VIS interrupt upper threshold level, LSB 0x50 R/W ALS_VIS_TH_MSB ALS_VIS interrupt upper threshold level, MSB 0x51 R/W ALS_VIS_TL_LSB ALS_VIS interrupt lower threshold level, LSB 0x52 R/W ALS_VIS_TL_MSB ALS_VIS interrupt lower threshold level, MSB Version 1.1 Name Function 14 Version 1.1 SFH 7771 SYSTEM_CONTROL register (0x40) The SYSTEM_CONTROL register is used to control the software (SW) reset and the interrupt function (INT). Manufacturer ID and Part ID can be read. R/W-Register 0x40 Bit 7 6 SW reset INT reset default 0 Initial reset is not started 0 INT pin status is not initialized 0 Initial reset is not started 0 INT pin status is not initialized 1 Initial reset started 22.04.2016 1 INT pin become inactive (high impedance) 15 5 4 3 Manufacturer ID (Read only) 001 2 1 0 Part ID (Read only) 001 Version 1.1 SFH 7771 MODE_CONTROL register (0x41) CONTROL of PS and ALS operating modes and time settings. Repetition time is the time between two separate measurements. Integration time is the duration for one measurement. ALS high sensitivity modes are 1010 and 1011 with an increased integration time of 400ms. In PS operating mode: „normal mode“ only one PS measurement is performed during one PS repetition time. In PS operating mode „twice mode“ two independent PS measurement are performed within one PS repetition time. Both measurements are independent and can trigger the interrupt. This feature can be used to decrease the interrupt update time if the persistence function (register 0x43) is used. R/W-Register 0x41 Bit 7 6 5 4 3 2 1 0 Reserved PS operating mode default Repetition time ALS PS 0 normal mode 0000 standby standby 0 normal mode 0000 standby standby 1 twice mode 0001 standby 10ms 0010 standby 40ms 0011 standby 100ms 0100 standby 400ms 0101 100ms / 100ms standby 0110 100ms / 100ms 100ms 0111 100ms / 100ms 400ms 1000 400ms / 100ms standby 1001 400ms / 100ms 100ms 1010 400ms / 400ms standby 1011 400ms / 400ms 400ms 1100 50ms / 50ms Rest forbidden Version 1.1 Repetition / Integration time 16 50ms Version 1.1 SFH 7771 ALS_PS_CONTROL register (0x42) ALS and PS Control of set the PS output mode, the ALS gain and the LED current. In the „Infrared DC level output“ PS mode (bit = 1) the sensor measures the infrared DC ambient level. The proximity value of the reflected signal is not available in this mode. R/W-Register 0x42 Bit 7 6 Reserved (read only) PS output default write 0 5 4 3 2 ALS Gain for ALS_VIS and ALS_IR 0 proximity output 0000 X1 X1 11 200mA 0000 X1 X1 00 25 mA 1 Infrared DC level output 0100 X2 X1 01 50 mA 0101 X2 X2 10 100 mA 1010 X64 X64 11 200 mA 1110 X128 X64 1111 X128 X128 17 0 LED current 0 proximity output rest forbidden 22.04.2016 1 Version 1.1 SFH 7771 PERSISTENCE Register (0x43) Settings of persistence interrupt function. Persistence function is only valid for the PS interrupt. R/W-Register 0x43 Bit 7 6 5 4 3 2 1 0 Reserved (read only) Persistence default 0000 0001 Interrupt status is updated after each measurement 0000 Interrupt becomes active after each measurement (The mode indicates that a PS or ALS measurement has been finished and can be read via the register. It is independent of the ALS & PS measurement value and threshold settings) 0001 Interrupt status is updated after each measurement (The interrupt status is updated independently after each measurement. Active or Inactive status of the interrupt is depending on the values of the last measurement in combination with the interrupt settings :“interrupt mode“ (register 0x4A) and „thresholds“ register 0x4C and following.) 0010 Interrupt status is updated if two consecutive threshold judgement are the same (The interrupt status only changes if the interrupt judgement of 2 consecutive measurement results are the same and different to the current interrupt status.) 0011 ... 1111 Interrupt status is updated if threshold judgement are the same over consecutive set times (3 ... 15) (This is the same procedure like in the 0010 persistence mode, but instead of 2 consecutive threshold judgments more are needed (3 to 15 depending on the setting) to change the interrupt status.) e.g.: 1010: 10 measurement results in a row need to fulfill the interrupt judgement to update the interrupt status PS_DATA_LSBs register (0x44) LSB of the PS output. R-Register 0x44 Bit 7 2 7 6 2 default 0 6 5 2 0 4 5 2 0 3 4 2 0 2 3 2 0 1 2 2 0 0 1 2 0 0 0 PS_DATA_MSBs register (0x45) MSB of the PS output. R-Register 0x45 Bit 7 not used default 0 Version 1.1 6 5 4 3 not used not used not used 2 0 0 0 0 18 11 2 2 0 10 1 2 0 9 0 2 0 8 Version 1.1 SFH 7771 ALS_VIS_DATA_LSBs register (0x46) LSB of the ALS_VIS output. R-Register 0x46 Bit 7 2 7 6 2 default 0 6 5 2 0 5 4 2 0 4 3 2 0 3 2 2 0 2 1 2 1 0 0 2 0 0 0 ALS_VIS_DATA_MSBs register (0x47) MSB of the ALS_VIS output. R-Register 0x47 Bit 7 2 15 6 2 default 0 14 5 2 0 13 4 2 0 12 3 2 0 11 2 2 0 10 1 2 9 0 0 2 0 8 0 ALS_IR_DATA_LSBs register (0x48) LSB of the ALS_IR output. R-Register 0x48 Bit 7 2 7 6 2 default 0 6 5 2 0 5 4 2 0 4 3 2 0 3 2 2 0 2 1 2 1 0 0 2 0 0 0 ALS_IR_DATA_MSBs register (0x49) MSB of the ALS_IR output. R-Register 0x49 Bit 7 2 default 0 22.04.2016 15 6 2 0 14 5 2 13 0 4 2 12 3 2 0 11 0 19 2 2 10 0 1 2 9 0 0 2 0 8 Version 1.1 SFH 7771 INTERRUPT_CONTROL register (0x4A) Setting of the interrupt functions. R/W-Register 0x4A Bit 7 6 PS INT status ALS INT status 5 4 PS INT mode 3 2 1 INT assert INT latch 0 INT trigger (read only) (read only) default 0 inactive 0 inactive 00 PS_TH is only active 0 INT „L“ is stable 0 INT is latched 00 inactive 0 inactive 0 inactive 00 PS_TH (PS high threshold 0x4B & 0x4C) is only active 0 INT „L“ is stable if newer measurement results is also interrupt active 0 INT is latched until INT register is read or initialize 00 INT pin is inactive 1 active 1active 01 PS_TH & PS_TL (PS high & low threshold) are active as hysteresis 1 INT “L“ is de-assert and re-assert if newer measurement results is also interrupt active 1INT is updated after each measurement 01 triggered by PS only 10 PS_TH & PS_TL (PS high & low threshold) are active as outside detection 10 triggered by ALS only 11 forbidden 11 triggered by PS or ALS PS INT and ALS INT status (bit ): Directly after reading the register the interrupt status for PS and ALS and the INT Pin of the sensor is automatically set back to inactive status independent on the measurement results. PS INT mode (bit ): The INT modes are only valid for the PS interrupt function. For description please see extra chapter „PS INT Modes“ (at the end of the register chapter). INT assert (bit ): Is used to adjust the sensor behaviour to the used micro controller trigger settings. In case a repeated trigger in low state is needed the INT assert can be set to 1. INT trigger (bit ): defines the source / sources for the interrupt. INT latched (bit ): In latched mode the interrupt status stays active after the first activation. It is only released by reading the status are performing an interrupt reset. . PS_TH_LSBs register (0x4B) LSB for the PS threshold „HIGH“. R/W-Register 0x4B Bit 7 27 default 1 Version 1.1 6 5 4 3 2 1 0 26 25 24 23 22 21 20 1 1 1 1 1 1 1 20 Version 1.1 SFH 7771 PS_TH_MSBs register (0x4C) MSB for the PS threshold „HIGH“. R/W-Register 0x4C Bit 7 6 5 4 3 2 default 0 0 0 0 11 2 2 1 10 1 2 9 1 0 2 1 8 1 PS_TL_LSBs register (0x4D) LSB for the PS threshold „LOW“. R/W-Register 0x4D Bit 7 2 7 6 2 default 0 6 5 2 0 5 4 2 0 4 3 2 0 3 2 2 0 2 1 2 1 0 0 2 0 0 0 PS_TL_MSBs register (0x4E) MSB for the PS threshold „LOW“. R/W-Register 0x4E Bit 7 6 5 4 3 2 default 0 0 0 0 11 2 2 0 10 1 2 9 0 0 2 0 8 0 ALS_VIS_TH_LSBs register (0x4F) LSB for the ALS_VIS threshold „HIGH“. R/W-Register 0x4F Bit 7 2 7 6 2 default 1 6 5 2 1 5 4 2 1 4 3 2 1 3 2 2 1 2 1 2 1 1 0 2 1 0 1 ALS_VIS_TH_MSBs register (0x50) MSB for the ALS_VIS threshold „HIGH“. R/W-Register 0x50 Bit 7 2 default 1 22.04.2016 15 6 2 1 14 5 2 13 1 4 2 12 3 2 1 11 1 21 2 2 10 1 1 2 9 1 0 2 1 8 Version 1.1 SFH 7771 ALS_VIS_TL_LSBs register (0x51) LSB for the ALS_VIS threshold „LOW“. R/W-Register 0x51 Bit 7 2 7 6 2 default 0 6 5 2 0 5 4 2 0 4 3 2 0 3 2 2 0 2 1 2 1 0 0 2 0 0 0 ALS_VIS_TL_MSBs register (0x52) MSB for the ALS_VIS threshold „LOW“. R/W-Register 0x52 Bit 7 2 15 default 0 6 2 0 14 5 2 13 0 4 2 12 3 2 0 11 0 2 2 10 0 1 2 9 0 0 2 8 0 INT modes The Interrupt function compares ALS and PS measurement values with the current interrupt threshold level. PS and ALS_VIS Interrupt status is readable via register 0x4A or at the INT pin of the sensor. The Interrupt persistence function is only valid for PS measurements and is defined in register (0x43). The INT pin of the SFH 7771 is open drain output and should be pulled up to VINT,pullup by an external resistor. When VDD is supplied the INT pin is high impedance (inactive). The INT status becomes inactive by writing INT reset command, reading the INT status register or performing a software reset. The INT status stays in its last state when the sensor is set to the standby mode. In the INT active state „low“ the sensor consumes ~25µA extra current. Therefore OSRAM recommends to set the INT state to high impedance before setting the sensor in standby mode. Following ALS and PS INT modes are described for the unlatched mode. In latched mode the switching back to the „inactive“ INT state is depending on a interrupt reset or the read of the INT status register. ALS INT mode: The ALS_VIS threshold levels high (register 0x4F & 0x50) and low (register 0x4F & 0x50) are only valid for the ALS_VIS measurement values. The ALS_VIS INT mode is fixed and can not be adapted via register. The thresholds define a window with following functionality: ALS INT is active, if the ALS_VIS measurement values are outside the window ALS INT is inactive, if the ALS_VIS measurement results are inside the window. PS INT Modes: Bit of INTERRUPT_CONTROL register (0x4A) 00 PS_TH is only active: The INT state is active, if the PS measurement result is equal or higher than the set PS_TH high threshold. The INT state is inactive, if the PS measurement result is lower than the set PS_TH high thresh- Version 1.1 22 Version 1.1 SFH 7771 old. PS INT active PS INT inactive PS_TH PS signal 01 PS_TH & PS_TL (PS high & low threshold) are active as hysteresis: PS_TH and PS_TL are working as a hysteresis. If the PS measurement signal is higher than the PS high threshold (PS_TH) the INT state is switched to active. If the PS measurement signal is lower than the PS low threshold (PS_TL) the INT state is inactive. If once interrupt signal becomes active, INT status is kept active until measurement result becomes less than PS_TL register value. PS INT active PS INT inactive PS_TL PS_TH PS signal 10 PS_TH & PS_TL (PS high & low threshold) are active as outside detection: In case of „PS outside detection“ mode interrupt signal inactive means that measurement result is within registered threshold level and interrupt signal active means measurement result is out of registered threshold level. PS INT active PS INT inactive PS_TL 22.04.2016 23 PS_TH PS signal Version 1.1  SFH 7771 Package Outline Dimensions in mm Contact pins and heatsink are marked as shaded areas in bottom view. Package: Chipled Approximate Weight: 5.9mg Version 1.1 24 Version 1.1 SFH 7771 Recommended solder pad design Dimensions in mm [inch]. 22.04.2016 25 Version 1.1 SFH 7771 Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Version 1.1 °C 26 s Version 1.1 SFH 7771 Method of Taping Dimensions in mm. 22.04.2016 27 Version 1.1 SFH 7771 Reel 8mm tape with 4000 pcs. on ∅ 180 mm reel Dimensions in mm Reel Dimensions [mm] A 180 C Nmin W1 W2max 130 ±0.2 60 +1.0 13 +1.0 15.4 ±1.0 EX AM PL E Barcode-Product-Label (BPL) OSRAM Opto po BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors tors ors r RoHS Compliant (6P) BATCH NO: NO:: 1234567 1234567890 234 7890 890 ML Temp ST X XXX °C X (1T) LOT NO: 1234567890 (9D) (9D D) D/ D) D/C: D/C: 123 1234 234 34 RXX Pack: RX R XX DEMY XXX X XX X_X123_1234.1234 X_X123_1 12 _123 123 12 234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X XX-XX XX XXX-X-X OHA04563 Version 1.1 28 Version 1.1 SFH 7771 Dry Packing Process and Materials Note: Moisture-sensitive product is packed in a dry bag containing desiccant. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. Transportation Packing and Materials Dimensions of transportation box in mm Width 195 ±5 22.04.2016 Length Height 195 ±5 42 ±5 29 Version 1.1 SFH 7771 Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization.?If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. ?By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED and photodiodes, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. Version 1.1 30
SFH7771 价格&库存
很抱歉,暂时无法提供与“SFH7771”相匹配的价格&库存,您可以联系我们找货
