SFH2270R
SFH2270R
    AMSOSRAM(艾迈斯半导体)
    SMD2
    PHOTODIODE560NMTOPLED
SFH2270R 数据手册
2016-03-07 High Precision Ambient Light Photodiode Version 1.4 SFH 2270R Features: • Nearly perfect match with Human Eye Sensitivity (Vλ) • Black coloured TOPLED®-package • Low leakage current Applications Ambient light sensor • Ordering Information Type: Photocurrent Ordering Code IP [µA] λ = 560 nm, Ee = 0.01 mW/cm2, VR = 1 V SFH 2270R Note:: 0.0056 (≥ 0.0044) corresponds to an illuminance of app. 55 lx 2016-03-07 1 Q65110A9911 Version 1.4 SFH 2270R Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Reverse voltage VR 2 V ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Characteristics (TA = 25 °C) Parameter Symbol Values Unit (typ) 5 ... 100000 lx Recommended operating range for illuminance (typ) EV Photocurrent (VR = 1V, Ev=1000 lx, standard light A) (typ (min)) IP Photocurrent (VR =1 V,Ee = 10μW/cm2, λ = 560 nm (corresponds to an illuminance of app. 55 lx)) (typ (min)) IP Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A Dimensions of radiant sensitive area (typ) LxW Half angle (typ) ϕ Dark current (VR = 1 V) (typ (max)) IR Rise and fall time (RL = 50 kΩ; VR = 1 V, Ip=4μA, white LED) (typ) Capacitance (VR = 0 V, f = 1 MHz, E = 0) Temperature coefficient of ISC 2016-03-07 0.1 µA 0.0056 (≥ 0.0044) µA 560 (typ) 480 ... 650 nm nm 0.16 mm2 0.4 x 0.4 mm x mm ± 60 ° 0.005 (≤ 0.15) nA tr, tf 6 µs (typ) C0 42 pF (typ) TCI 0.17 2 %/K Version 1.4 SFH 2270R Relative Spectral Sensitivity 1) page 11 Srel = f(λ) Dark Current 1) page 11 IR = f(VR), E = 0 OHF04449 100 Srel % IR OHF04451 102 pA 80 70 101 60 5 50 40 100 30 5 20 10 10-1 0 400 500 600 700 800 900 nm 1100 λ C OHF04450 35 30 25 20 15 10 5 0 -3 10 10 -2 10 -1 10 0 V 10 1 VR 2016-03-07 0.5 1.0 1.5 V 2.0 VR Capacitance 1) page 11 C = f(VR), f = 1 MHz, E = 0 45 pF 0 3 Version 1.4 SFH 2270R Directional Characteristics 1) page 11 Srel = f(ϕ) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 1.0 0.8 0.6 0.4 0 20 40 60 80 100 Package Outline 2.1 (0.083) 3.0 (0.118) 2.6 (0.102) 2.3 (0.091) 1.7 (0.067) 1.0 (0.039) 0...0.1 (0.004) 0.6 (0.024) 0.4 (0.016) Cathode marking Dimensions in mm (inch). Package TOPLED Reverse Gullwing 2016-03-07 A 5.4 (0.213) 5.0 (0.197) 0.3 (0.012) min 4˚±1 (2.4 (0.094)) 3.4 (0.134) 3.0 (0.118) 0.3 (0.012) max 0.9 (0.035) 2.1 (0.083) 4 C GPLY6899 120 Version 1.4 SFH 2270R Approximate Weight: 35 mg Recommended Solder Pad Dimensions in mm. 2016-03-07 5 Version 1.4 SFH 2270R Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2016-03-07 °C 6 s Version 1.4 SFH 2270R Taping 4 (0.157) 3 (0.118) 4 (0.157) 12 (0.472) 1.75 (0.069) 5.5 (0.217) 2 (0.079) 5.6 (0.220) 1.5 (0.059) Cathode/Collector Marking OHAY2272 Dimensions are specified as follows: mm (inch). Tape and Reel 12 mm tape with 2000 pcs. on ∅ 180 mm reel, 8000 pcs. on ∅ 330 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 2016-03-07 7 Version 1.4 SFH 2270R Tape dimensions [mm] Tape dim ensions in m m W P0 12 + 0.3 / - 0.1 4 ± 0.1 P1 P2 D0 E F 4 ± 0.1 or 8 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 Reel dimensions [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 12 60 12.4 + 2 18.4 A W Nmin W1 W2max 330 12 60 12.4 + 2 18.4 Reel dim ensions in m m Barcode-Product-Label (BPL) OSRAM Opto EX AM P BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Moisture-sensitive label or print L VE el LE . see lab e If ve ati nk, bla cod bar y H) (R . dit mi hu e ed ag RH % /60 Barcode label ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < urs ). urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative 2016-03-07 8 Version 1.4 SFH 2270R references like JEDEC. Transportation Packing and Materials Barcode label D/ 8 01 Y M DE R 18 -1 P -1 + Q P: OU GR 00 C: 99 D/ 21 D) 00 (9 21 20 34 : O 12 14 2 5 H (Q )Q TY S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T T) (1 NO : TY : 20 : NO (Q )Q T LO T) (1 M RA OS (X ) PR O D 5 14 2 110 0 Packing Sealing label Dimensions of transportation box in mm Width Length Height 195 ± 5 349 ± 5 195 ± 5 349 ± 5 30 ± 5 33 ± 5 2016-03-07 OD Y DE M R 18 -1 + Q -1 P : UP RO G ) (G 44 00 C: 01 Muster O D) u d (9 A M n o : ic S R NO O 12 BA TC H 3G H S 8 NO (6 P) : 12 em 2199 34 ct pto o rs M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: (X ) PR < 2100 (G ) L el OI M TO OP : E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th ll pr tim cto ). r oo 23 wi nt tim e at l wi fa r Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk g rd M ois in r-p bla in Fl RH g, DM ba Ca bla th po If % kin life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE 44 M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 9 OHA02044 Version 1.4 SFH 2270R Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-03-07 10 Version 1.4 SFH 2270R Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-03-07 11 Version 1.4 SFH 2270R Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-03-07 12
SFH2270R 价格&库存
很抱歉,暂时无法提供与“SFH2270R”相匹配的价格&库存,您可以联系我们找货
