2016-01-04
Silicon PIN Photodiode
Version 1.3
SFH 206 K
Features:
Especially suitable for applications from 400 nm to 1100 nm
Short switching time (typ. 20 ns)
5 mm LED plastic package
Also available on tape and reel
Applications
Photointerrupters
Industrial electronics
For control and drive circuits
Computer-controlled flashes
Ordering Information
Type:
Ordering Code
SFH 206 K
Q62702P0129
2016-01-04
1
Version 1.3
SFH 206 K
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 100
°C
Reverse voltage
VR
32
V
Total Power dissipation
Ptot
150
mW
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2000
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
80 (≥ 50)
nA/Ix
Spectral sensitivity
(VR = 5 V, standard light A, T = 2856 K)
(typ)
S
Wavelength of max. sensitivity
(typ)
λS max
Spectral range of sensitivity
(typ)
λ10%
Radiant sensitive area
(typ)
A
Dimensions of radiant sensitive area
(typ)
LxW
Half angle
(typ)
ϕ
Dark current
(VR = 10 V)
(typ (max)) IR
Spectral sensitivity of the chip
(λ = 850 nm)
(typ)
Sλ typ
0.62
A/W
Quantum yield of the chip
(λ = 850 nm)
(typ)
η
0.90
Electro
ns
/Photon
Open-circuit voltage
(Ev = 1000 lx, Std. Light A)
(typ (min))
VO
365 (≥ 310)
mV
Short-circuit current
(typ)
ISC
80
µA
Rise and fall time
(VR = 5 V, RL = 50 Ω, λ = 850 nm, IP = 800 µA)
(typ)
tr, tf
0.02
µs
Forward voltage
(IF = 100 mA, E = 0)
(typ)
VF
1.3
V
Capacitance
(VR = 0 V, f = 1 MHz, E = 0)
(typ)
C0
72
pF
Temperature coefficient of VO
(typ)
TCV
2016-01-04
2
850
(typ) 400
... 1100
nm
nm
7.02
mm2
2.65 x 2.65
mm x
mm
± 60
2 (≤ 30)
-2.6
nA
mV / K
Version 1.3
SFH 206 K
Parameter
Symbol
Values
Unit
Temperature coefficient of ISC
(Std. Light A)
(typ)
TCI
0.18
%/K
Noise equivalent power
(VR = 10 V, λ = 850 nm)
(typ)
NEP
0.041
pW /
Hz½
Detection limit
(typ)
D*
6.5e12
cm x
Hz½ / W
Relative Spectral Sensitivity 1) page 8
Srel = f(λ)
100
Photocurrent / Open-Circuit Voltage 1) page 8
IP (VR = 5 V) / VO = f(Ev)
OHF00078
S rel %
80
60
40
400 500 600 700 800 900 nm 1100
λ
2016-01-04
3
Version 1.3
SFH 206 K
Dark Current 1) page 8
IR = f(VR), E = 0
Power Consumption
Ptot = f(TA)
OHF00394
160
mW
Ptot
140
120
100
80
60
40
60
80 ˚C 100
TA
Capacitance 1) page 8
C = f(VR), f = 1 MHz, E = 0
IR = f(TA), VR = 10 V, E = 0
OHF00082
10 3
Ι R nA
10 2
10 1
10 0
10 -1
2016-01-04
4
60
80 ˚C 100
TA
Version 1.3
SFH 206 K
Directional Characteristics 1) page 8
Srel = f(ϕ)
40
30
ϕ
OHF01402
1.0
50
0.8
60
0.6
70
0.4
80
0.2
100
1.0
0.8
0.6
0.4
60
80
100
Package Outline
Area not flat
6.9 (0.272)
0.6 (0.024) x 0.5 (0.020)
0.4 (0.016) x 0.3 (0.012)
1.8 (0.071)
1.2 (0.047)
34 (1.339)
32 (1.260)
4.1 (0.161)
3.7 (0.146)
GEOY6647
Dimensions in mm (inch).
Package
5mm Radial (T 1 ¾), Epoxy
2016-01-04
4.7 (0.185)
4.0 (0.157)
Cathode
5.1 (0.201)
2.54 (0.100)
spacing
0.8 (0.031)
0.4 (0.016)
6.3 (0.248)
0.8 (0.031)
5
120
Version 1.3
SFH 206 K
Approximate Weight:
0.3 g
Note
Packing information is available on the internet (online product catalog).
Recommended Solder Pad
Dimensions in mm.
Note:
pad 1: anode
2016-01-04
6
Version 1.3
SFH 206 K
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-01-04
7
Version 1.3
SFH 206 K
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-01-04
8
Version 1.3
SFH 206 K
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-01-04
9
很抱歉,暂时无法提供与“SFH206K”相匹配的价格&库存,您可以联系我们找货
