2015-12-23
Silicon PIN Photodiode with Daylight Blocking Filter
Version 1.3
SFH 225 FA
Features:
Especially suitable for applications of 880 nm
Short-switching time (typ. 20 ns)
5 mm LED plastic package
Also available on tape and reel
The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification
for Automotive Grade Discrete Semiconductors.
Applications
Photointerrupters
IR remote control of hi-fi and TV sets, dimmers, remote controls of various equipment
Ordering Information
Type:
Photocurrent
Ordering Code
IP [µA]
λ = 870 nm, Ee = 1 mW/cm2,
VR = 5 V
SFH 225 FA
2015-12-23
34 (≥ 25)
Q62702P1051
1
Version 1.3
SFH 225 FA
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 100
°C
Reverse voltage
VR
V
Total Power dissipation
Ptot
150
mW
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2000
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
Photocurrent
(VR = 5 V, Ee = 1 mW/cm2 , λ = 870 nm)
(typ (min))
IP
Wavelength of max. sensitivity
(typ)
λS max
Spectral range of sensitivity
(typ)
λ10%
Radiant sensitive area
(typ)
A
Dimensions of radiant sensitive area
(typ)
LxW
Half angle
(typ)
ϕ
Dark current
(VR = 10 V)
(typ (max)) IR
Spectral sensitivity of the chip
(λ = 870 nm)
(typ)
Sλ typ
0.65
A/W
Quantum yield of the chip
(λ = 870 nm)
(typ)
η
0.93
Electro
ns
/Photon
Open-circuit voltage
(Ee = 0.5 mW/cm2, λ = 870 nm)
(typ (min))
VO
330 (≥ 250)
mV
Short-circuit current
(typ)
ISC
17
µA
Rise and fall time
(VR = 5 V, RL = 50 Ω, λ = 850 nm)
(typ)
tr, tf
0.02
µs
Forward voltage
(IF = 100 mA, E = 0)
(typ)
VF
1.3
V
Capacitance
(VR = 0 V, f = 1 MHz, E = 0)
(typ)
C0
48
pF
Temperature coefficient of VO
(typ)
TCV
2015-12-23
2
34 (≥ 25)
µA
900
nm
(typ) 740
... 1120
nm
4.84
mm2
2.2 x 2.2
mm x
mm
± 60
2 (≤ 30)
-2.6
nA
mV / K
Version 1.3
SFH 225 FA
Parameter
Symbol
Values
Unit
Temperature coefficient of ISC
(λ = 870 nm)
(typ)
TCI
0.1
%/K
Noise equivalent power
(VR = 10 V, λ = 870 nm)
(typ)
NEP
0.039
pW /
Hz½
Detection limit
(typ)
D*
5.6e12
cm x
Hz½ / W
Relative Spectral Sensitivity 1) page 9
Srel = f(λ)
Photocurrent / Open-Circuit Voltage 1) page 9
IP (VR = 5 V) / VO = f(Ee)
OHF01430
100
ΙP
Srel %
80
OHF01056
10 3
µA
10 4
mV
VO
10 2
10 3
70
VO
60
10 1
50
10 2
40
ΙP
30
10 0
10 1
2015-12-23
600
800
10 -1
10 0
1000 nm 1200
λ
10
1
10
2
µW/cm
2
Ee
3
10 0
10 4
Version 1.3
SFH 225 FA
Dark Current 1) page 9
IR = f(VR), E = 0
Power Consumption
Ptot = f(TA)
OHF00394
160
mW
Ptot
140
OHF00080
4000
ΙR
120
pA
3000
100
80
2000
60
40
1000
60
80 ˚C 100
TA
IR = f(VR), E = 0
OHF02284
nA
ΙR
10 1
10 0
4
6
8 10 12 14 16 V 20
VR
2015-12-23
5
10
Capacitance 1) page 9
C = f(VR), f = 1 MHz, E = 0
10 2
10 -1
15
V
VR
Version 1.3
SFH 225 FA
IR = f(TA), VR = 10 V, E = 0
OHF00082
10 3
Ι R nA
10 2
10 1
10 0
10 -1
60
80 ˚C 100
TA
Directional Characteristics 1) page 9
Srel = f(ϕ)
40
30
ϕ
OHF01402
1.0
50
0.8
60
0.6
70
0.4
80
0.2
100
2015-12-23
1.0
0.8
0.6
0.4
60
80
100
120
Version 1.3
SFH 225 FA
Package Outline
1.1 (0.043)
0.7 (0.028)
1.2 (0.047)
5.1 (0.201)
4.6 (0.181)
0.75 (0.030)
0.45 (0.018)
0.4 (0.016)
1.8 (0.071)
0.6 (0.024)
2.54 (0.100)
spacing
35.5 (1.398)
33.5 (1.319)
3.8 (0.150)
7.2 (0.283)
6.6 (0.260)
3.1 (0.122)
2.6 (0.102)
Cathode
Photosensitive
area
Surface
not flat
GEOY6422
Dimensions in mm (inch).
Package
5mm Radial (T 1 ¾), Epoxy
Approximate Weight:
0.1 g
Note
Packing information is available on the internet (online product catalog).
2015-12-23
0.5 (0.020)
0.3 (0.012)
6
Version 1.3
SFH 225 FA
Recommended Solder Pad
Dimensions in mm.
Note:
pad 1: anode
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
2015-12-23
7
Version 1.3
SFH 225 FA
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2015-12-23
8
Version 1.3
SFH 225 FA
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2015-12-23
9
Version 1.3
SFH 225 FA
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2015-12-23
10
很抱歉,暂时无法提供与“SFH225FA”相匹配的价格&库存,您可以联系我们找货
