SFH3310
SFH3310
    AMSOSRAM(艾迈斯半导体)
    PHOTO-TR-2P_D3.8XH2.8MM_TM
    PHOTOTRANSNPN570NM3MMCLEAR
SFH3310 数据手册
2016-01-04 Silicon NPN Phototransistor with Vλ Characteristics Version 1.3 SFH 3310 Features: • Spectral range of sensitivity: (typ) 350 ... 970 nm • Package: 3mm Radial (T 1), Epoxy • Special: Adapted to human eye sensitivity (Vλ) Applications • For control and drive circuits • Ambient light detector • Exposure meter for daylight and artificial light • Sensor for backlight-dimming Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 560 nm, Ee = 10 µW/cm2, VCE =5V SFH 3310 2016-01-04 2.5 ... 8 Q65110A5343 1 Version 1.3 SFH 3310 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 5.5 V Collector current IC 20 mA Emitter-collector voltage VEC 0.5 V ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 570 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.29 mm2 Dimensions of chip area (typ) LxW (typ) 0.75 x 0.75 mm x mm Half angle (typ) ϕ ± 75 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE Dark current (VCE = 5 V, E = 0) (typ (max)) ICE0 2016-01-04 2 (typ) 350 ... 970 nm 16 pF 3 (≤ 50) nA Version 1.3 SFH 3310 Grouping (TA = 25 °C, λ = 560 nm) Group Min Photocurrent Max Photocurrent Typ Photocurrent Collector-emitter saturation voltage Ee = 10 μW/cm2, VCE = 5 V Ee = 10 μW/cm2, VCE = 5 V EV = 1000 lx, Std. Light A, VCE = 5 V IC = IPCEmin x 0.3, Ee = 10 μW/cm2 IPCE, min [µA] IPCE, max [µA] IPCE [µA] VCEsat [mV] SFH 3310-2 2.5 5 290 100 SFH 3310-3 4 8 460 100 Note.: IPCEmin is the min. photocurrent of the specified group Relative Spectral Sensitivity 1) page 8 Srel = f(λ) Photocurrent 1) page 8 IPCE = f(Ee), VCE = 5 V OHF00851 100 µA % Srel OHF00852 1000 I PCE 80 70 100 60 50 40 Vλ 10 30 20 10 1 1 0 400 500 600 700 800 900 nm 1100 λ 2016-01-04 10 100 lx 1000 EV 3 Version 1.3 SFH 3310 Collector Current 1) page 8 IC = f(VCE), IB = Parameter OHF00854 80 µA I CE Photocurrent 1) page 8 IPCE / IPCE(25°C) = f(TA), VCE = 5 V I PCE I PCE (25 ˚C) 200 lx 70 OHF01024 1.8 1.4 60 1.2 50 1.0 40 100 lx 0.8 30 0.6 20 0.4 10 0 0.2 20 lx 0 1 2 3 4 0 -50 -30 -10 V 5 VCE C CE OHF04052 3.0 2.5 2.0 1.5 1.0 0.5 0 -3 10 10 -2 10 -1 10 0 10 1 V 10 2 VCE 2016-01-04 30 50 ˚C 90 TA Collector-Emitter Capacitance 1) page 8 CCE = f(VCE), f = 1 MHz, E = 0 4.0 pF 10 4 Version 1.3 SFH 3310 Directional Characteristics 1) page 8 Srel = f(ϕ) Package Outline 0.7 (0.028) 0.4 (0.016) 0.8 (0.031) 0.4 (0.016) 3.5 (0.138) 29 (1.142) 27 (1.063) 4.5 (0.177) 4.1 (0.161) Chip position Dimensions in mm (inch). Package 3mm Radial (T 1), Epoxy 2016-01-04 5 ø2.9 (0.114) 1.8 (0.071) 1.2 (0.047) 0.6 (0.024) 0.4 (0.016) ø3.1 (0.122) 2.54 (0.100) spacing Emitter Area not flat 3.1 (0.122) 2.5 (0.098) 2.0 (0.079) 1.7 (0.067) 4.0 (0.157) 3.6 (0.142) GEOY6446 Version 1.3 SFH 3310 Approximate Weight: 0.2 g Note Packing information is available on the internet (online product catalog). Recommended Solder Pad Dimensions in mm. Note: pad 1: emitter 2016-01-04 6 Version 1.3 SFH 3310 TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 7 Version 1.3 SFH 3310 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 8 Version 1.3 SFH 3310 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 9
SFH3310 价格&库存
很抱歉,暂时无法提供与“SFH3310”相匹配的价格&库存,您可以联系我们找货
