LPT80A
LPT80A
    AMSOSRAM(艾迈斯半导体)
    DIP
    PHOTOTRANSNPN850NMSIDELOOKER
LPT80A 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 LPT 80 A Features: • Spectral range of sensitivity: (typ) 450 ... 1100 nm • Package: Sidelooker, Epoxy • Special: High photosensitivity • Same package as IR emitter IRL 81 A Applications • A variety of manufacturing and monitoring applications • Photointerrupters Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V LPT 80A 2016-01-04 ≥ 250 Q68000A7852 1 Version 1.3 LPT 80 A Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 30 V Collector current IC 50 mA Collector surge current (τ < 10 µs) ICS 100 mA Emitter-collector voltage VEC 7 Total Power dissipation Ptot 100 mW Thermal resistance RthJA 750 K/W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 880 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.11 mm2 Dimensions of chip area (typ) LxW (typ) 0.55 x 0.55 mm x mm Half angle (typ) ϕ ± 35 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE 7.5 pF IPCE ≥ 250 µA IPCE 3200 µA 1 (≤ 50) nA Photocurrent (λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V) (typ) 450 ... 1100 nm Photocurrent (EV = 1000 lx, Std. Light A, VCE = 5 V) (typ) Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 Rise and fall time (IC = 1 mA, VCC = 5 V, RL = 1 kΩ) (typ) tr, tf 10 µs Collector-emitter saturation voltage (Threefold saturated) (typ) VCEsat 150 mV 2016-01-04 2 Version 1.3 LPT 80 A Relative Spectral Sensitivity 1) page 8 Srel = f(λ) Photocurrent 1) page 8 IPCE = f(Ee), VCE = 5 V OHF04042 100 OHFD1422 10 1 mA Srel % Ι PCE 80 10 0 70 L K J H 60 10 -1 50 40 30 10 -2 20 10 0 400 500 600 700 800 900 10 -3 -3 10 nm 1100 10 -2 10 -1 mW/cm 2 10 0 Ee λ 1) page 8 Dark Current 1) page 8 ICEO = f(VCE), E = 0 Photocurrent IPCE / IPCE(25°C) = f(TA), VCE = 5 V Ι PCE Ι PCE 25 OHF04049 10 1 nA OHF01524 1.6 I CEO 1.4 1.2 10 0 1.0 0.8 0.6 10 -1 0.4 0.2 0 -25 2016-01-04 0 25 50 10 -2 75 C 100 TA 0 5 10 15 20 25 30 V 35 VCE 3 Version 1.3 LPT 80 A Dark Current 1) page 8 ICE0 = f(TA), E = 0, VCE = 5 V Collector-Emitter Capacitance 1) page 8 CCE = f(VCE), f = 1 MHz, E = 0 OHF04050 10 4 nA OHF04051 8 pF C CE 7 I CEO 10 3 6 10 2 5 10 1 4 3 10 0 2 10 -1 1 10 -2 -25 0 25 50 0 -3 10 75 ˚C 100 TA OHR01425 Ι F mA 100 75 50 25 0 0 20 40 60 80 C 100 TA 2016-01-04 10 -1 10 0 10 1 V 10 2 VCE Power Consumption Ptot = f(TA) 125 10 -2 4 Version 1.3 LPT 80 A Directional Characteristics 1) page 8 Srel = f(ϕ) 40˚ 30˚ 20˚ 10˚ 0˚ ϕ OHF00345 1.0 50˚ 0.8 60˚ 0.6 70˚ 0.4 80˚ 0.2 0 90˚ 100˚ 1.0 0.8 0.6 0.4 0˚ 20˚ 40˚ 60˚ 80˚ 100˚ 1.52 (0.060) Plastic marking 2.54 (0.100) 2.03 (0.080) 1.70 (0.067) 1.45 (0.057) R = 0.76 (0.030) Approx. weight 0.2 g GEOY6391 Dimensions in mm (inch). Package Sidelooker, Epoxy 2016-01-04 2.08 (0.082) 0.46 (0.018) 0.64 (0.025) 0.46 (0.018) Collector 1.52 (0.060) 0.64 (0.025) 2.54 (0.100) spacing 1.52 (0.060) 5.84 (0.230) 5.59 (0.220) 1.29 (0.051) 1.14 (0.045) 2.34 (0.092) 16.51 (0.650) 16.00 (0.630) 4.57 (0.180) 4.32 (0.170) Package Outline 5 120˚ Version 1.3 LPT 80 A Approximate Weight: 85 mg Recommended Solder Pad Dimensions in mm. 2016-01-04 6 Version 1.3 LPT 80 A TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 7 Version 1.3 LPT 80 A Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 8 Version 1.3 LPT 80 A Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 9
LPT80A 价格&库存
很抱歉,暂时无法提供与“LPT80A”相匹配的价格&库存,您可以联系我们找货
