SFH310-2/3
SFH310-2/3
    AMSOSRAM(艾迈斯半导体)
    DIP
    PHOTOTRANSISTORNPN780NM3MM
SFH310-2/3 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 SFH 310 FA Features: • Spectral range of sensitivity: (typ) 740 ... 1100 nm • Package: 3mm Radial (T 1), Epoxy • Special: high photosensitivity Applications • Photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V SFH 310 FA 400 ... 3200 Q62702P1673 SFH 310 FA-2/3 630 ... 2000 Q62702P3596 Note: Only one bin within one packing unit (variation less than 2:1) 2016-01-04 1 Version 1.3 SFH 310 FA Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 35 V Collector current IC 50 mA Collector surge current ICS 100 mA Total Power dissipation Ptot 165 mW Thermal resistance RthJA 450 K/W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 890 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.11 mm2 Dimensions of chip area (typ) LxW (typ) 0.5 x 0.5 mm x mm Half angle (typ) ϕ ± 25 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE 7.5 pF Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 1 (≤ 50) nA 2016-01-04 2 (typ) 740 ... 1100 nm Version 1.3 SFH 310 FA Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Rise and fall time Collector-emitter saturation voltage Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IC = IPCEmin x 0.3, Ee = 0.5 mW/cm2 IPCE, min [µA] IPCE, max [µA] tr, tf [µs] VCEsat [mV] -2 630 1250 5 150 -3 1000 2000 8 150 -4 1600 3200 12 150 Note.: IPCEmin is the min. photocurrent of the specified group. Relative Spectral Sensitivity 1) page 9 Srel = f(λ) 100 Srel % Photocurrent 1) page 9 IPCE = f(Ee), VCE = 5 V OHF04075 80 70 60 50 40 30 20 10 0 400 500 600 700 800 900 nm 1100 λ 2016-01-04 3 Version 1.3 SFH 310 FA Photocurrent 1) page 9 IPCE = f(VCE), Ee = Parameter Photocurrent 1) page 9 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Ι PCE OHF01524 1.6 Ι PCE 25 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 -25 Dark Current 1) page 9 ICEO = f(VCE), E = 0 0 25 50 75 C 100 TA Dark Current 1) page 9 ICEO = f(TA), E = 0 OHF04049 10 1 nA OHF04050 10 4 nA I CEO I CEO 10 3 10 0 10 2 10 1 10 -1 10 0 10 -1 10 -2 0 5 10 15 20 25 10 -2 -25 30 V 35 VCE 2016-01-04 0 25 50 75 ˚C 100 TA 4 Version 1.3 SFH 310 FA Collector-Emitter Capacitance 1) page 9 CCE = f(VCE), f = 1 MHz, E = 0 Power Consumption Ptot = f(TA) OHF04051 8 pF C CE 7 6 5 4 3 2 1 0 -3 10 10 -2 10 -1 10 0 10 1 V 10 2 VCE Directional Characteristics 1) page 9 Srel = f(ϕ) 2016-01-04 5 Version 1.3 SFH 310 FA Package Outline 4.8 (0.189) 4.4 (0.173) 1.8 (0.071) 1.2 (0.047) Collector ø2.9 (0.114) ø2.7 (0.106) 1.1 (0.043) 0.9 (0.035) 0.4 (0.016) 0.8 (0.031) 0.4 (0.016) 0.7 (0.028) 0.4 (0.016) 0.6 (0.024) 2.54 (0.100) spacing Area not flat 3.1 (0.122) 3.7 (0.146) 0.6 (0.024) 3.5 (0.138) 6.1 (0.240) 0.4 (0.016) 5.7 (0.224) 29.0 (1.142) 27.0 (1.063) GEXY6710 Dimensions in mm (inch). Package 3mm Radial (T 1), Epoxy Approximate Weight: 0.2 g Note Packing information is available on the internet (online product catalog). 2016-01-04 3.4 (0.134) 6 Version 1.3 SFH 310 FA Recommended Solder Pad Dimensions in mm. Note: pad 1: emitter TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t 2016-01-04 7 Version 1.3 SFH 310 FA Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 8 Version 1.3 SFH 310 FA Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 9 Version 1.3 SFH 310 FA Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 10
SFH310-2/3 价格&库存
很抱歉,暂时无法提供与“SFH310-2/3”相匹配的价格&库存,您可以联系我们找货
