2016-01-04
Silicon NPN Phototransistor
Version 1.3
SFH 309
Features:
Spectral range of sensitivity: (typ) 380 ... 1150 nm
Package: 3mm Radial (T 1), Epoxy
Special: High photosensitivity
High linearity
Available in groups
Applications
Photointerrupters
Industrial electronics
For control and drive circuits
Ordering Information
Type:
Photocurrent
Ordering Code
IPCE [µA]
λ = 950 nm, Ee = 0.5 mW/cm2,
VCE = 5 V
SFH 309
400 ... 5000
Q62702P0859
SFH 309-3/4
630 ... 2000
Q62702P3592
SFH 309-4
1000 ... 2000
Q62702P0998
SFH 309-4/5
1000 ... 3200
Q62702P3593
SFH 309-5
1600 ... 3200
Q62702P0999
SFH 309-5/6
1600 ... 5000
Q62702P3594
Note:
Only one bin within one packing unit (variation less than 2:1)
2016-01-04
1
Version 1.3
SFH 309
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 100
°C
Collector-emitter voltage
VCE
35
V
Collector current
IC
15
mA
Collector surge current
(τ < 10 µs)
ICS
75
mA
Total Power dissipation
Ptot
165
mW
Thermal resistance
RthJA
450
K/W
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2000
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
860
nm
Wavelength of max. sensitivity
(typ)
λS max
(typ)
λ10%
Radiant sensitive area
(∅ 220 μm)
(typ)
A
0.038
mm2
Dimensions of chip area
(typ)
LxW
(typ) 0.45 x
0.45
mm x
mm
Distance chip front to case surface
(min ...
max)
H
(min ... max)
2.4 ... 2.8
Half angle
(typ)
ϕ
± 12
Capacitance
(VCE = 0 V, f = 1 MHz, E = 0)
(typ)
CCE
Dark current
(VCE = 20 V, E = 0)
(typ (max)) ICE0
2016-01-04
2
(typ) 380
... 1150
nm
mm
5
pF
1 (≤ 50)
nA
Version 1.3
SFH 309
Grouping (TA = 25 °C, λ = 950 nm)
Group
Min Photocurrent
Max Photocurrent Typ Photocurrent Rise and fall time
Ee = 0.5 mW/cm2,
VCE = 5 V
Ee = 0.5 mW/cm2,
VCE = 5 V
EV = 1000 lx, Std.
Light A, VCE = 5 V
IC = 1 mA, VCC = 5
V, RL = 1 kΩ
IPCE, min [µA]
IPCE, max [µA]
IPCE [µA]
tr, tf [µs]
-2
400
800
1500
5
-3
630
1250
2800
6
-4
1000
2000
4500
7
-5
1600
3200
7200
8
-6
2500
5000
11200
9
Group
Collector-emitter saturation voltage
IC = IPCEmin x 0.3, Ee = 0.5 mW/cm2
VCEsat [mV]
-2
200
-3
200
-4
200
-5
200
-6
200
Note.:
IPCEmin is the min. photocurrent of the specified group.
2016-01-04
3
Version 1.3
SFH 309
Relative Spectral Sensitivity 1) page 9
Srel = f(λ)
Photocurrent 1) page 9
IPCE = f(Ee), VCE = 5 V
OHF01121
100
S rel %
80
60
40
600
800
1000 nm 1200
λ
IPCE = f(VCE), Ee = Parameter
IPCE / IPCE(25°C) = f(TA), VCE = 5 V
Ι PCE
OHF01524
1.6
Ι PCE 25
1.4
1.2
1.0
0.8
0.6
0.4
0.2
2016-01-04
4
50
75 C 100
TA
Version 1.3
SFH 309
Dark Current 1) page 9
ICEO = f(VCE), E = 0
ICE0 = f(TA), VCE = 20 V, E = 0
OHF01527
10 1
nA
Ι CEO
Ι CEO
10 0
10 2
10 -1
10 1
10 -2
10 0
10 -3
10
15
10 -1
-25
30 V 35
V CE
Collector-Emitter Capacitance 1) page 9
CCE = f(VCE), f = 1 MHz, E = 0
C CE pF
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
10 -1
10 0
Power Consumption
Ptot = f(TA)
OHF01528
5.0
2016-01-04
OHF01530
10 3
nA
10 1 V 10 2
V CE
5
25
50
75 ˚C 100
TA
Version 1.3
SFH 309
Directional Characteristics 1) page 9
Srel = f(ϕ)
Package Outline
Collector (Transistor)
Cathode (Diode)
ø3.1 (0.122)
ø2.9 (0.114)
0.7 (0.028)
0.4 (0.016)
0.8 (0.031)
0.4 (0.016)
2.54 (0.100)
spacing
Area not flat
5.2 (0.205)
4.5 (0.177)
4.1 (0.161)
3.9 (0.154)
4.0 (0.157)
3.6 (0.142)
3.5 (0.138)
1.8 (0.071)
1.2 (0.047)
29 (1.142)
27 (1.063)
0.6 (0.024)
0.4 (0.016)
Chip position
6.3 (0.248)
5.9 (0.232)
GEOY6653
Dimensions in mm (inch).
Package
2016-01-04
6
Version 1.3
SFH 309
Approximate Weight:
0.2 g
Note
Packing information is available on the internet (online product catalog).
Recommended Solder Pad
Dimensions in mm.
Note:
pad 1: emitter
2016-01-04
7
Version 1.3
SFH 309
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-01-04
8
Version 1.3
SFH 309
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-01-04
9
Version 1.3
SFH 309
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-01-04
10
很抱歉,暂时无法提供与“SFH309-4/5”相匹配的价格&库存,您可以联系我们找货
