BPY62-3/4
BPY62-3/4
    AMSOSRAM(艾迈斯半导体)
    TO18-3
    PHOTOTRANSISTORNPN830NMTO-18
BPY62-3/4 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 BPY 62 Features: • Spectral range of sensitivity: (typ) 400 ... 1100 nm • Package: Metal Can (TO-18), hermetically sealed • Special: Base connection • Suitable up to 125 °C • HIgh photosensitivity • Available in groups Applications • Photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V BPY 62 ≥ 500 Q60215Y0062 BPY 62-3/4 800 ... 2500 Q62702P5198 BPY 62-4 1250 ... 2500 Q60215Y1113 Note: Only one bin within one packing unit (variation less than 2:1) 2016-01-04 1 Version 1.3 BPY 62 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 125 °C Collector-emitter voltage VCE 35 V Collector current IC 100 mA Collector surge current (τ < 10 µs) ICS 200 mA Emitter-collector voltage VEC 7 Total Power dissipation Ptot 200 mW ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 830 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.11 mm2 Dimensions of chip area (typ) LxW (typ) 0.55 x 0.55 mm x mm Half angle (typ) ϕ ±8 ° Photocurrent of collector-base photodiode (λ = 950 nm, Ee = 0.5 mW/cm2, VCB = 5 V) (typ) IPCB 5.5 μA Photocurrent of collector-base photodiode (EV = 1000 lx, Std. Light A, VCB = 5 V) (typ) IPCB 17 μA Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE 7.5 pF Capacitance (VCB = 0 V, f = 1 MHz, E = 0) (typ) CCB 14 pF Capacitance (VEB = 0 V, f = 1 MHz, E = 0) (typ) CEB 19 pF Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 1 (≤ 50) nA 2016-01-04 2 (typ) 400 ... 1100 nm Version 1.3 BPY 62 Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Typ Photocurrent Rise and fall time Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V EV = 1000 lx, Std. Light A, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IPCE, min [µA] IPCE, max [µA] IPCE [µA] tr, tf [µs] BPY 62-2 500 1000 2400 5 BPY 62-3 800 1600 3800 7 BPY 62-4 1250 2500 5800 9 BPY 62-5 2000 9600 12 Group Collector-emitter saturation voltage Current gain IC = IPCEmin x 0.3, Ee= 0.5 mW/cm2 Ee = 0.5 mW/cm2, VCE = 5 V VCEsat [mV] IPCE / IPCB BPY 62-2 150 140 BPY 62-3 150 220 BPY 62-4 160 340 BPY 62-5 180 550 Note.: IPCEmin is the min. photocurrent of the specified group. 2016-01-04 3 Version 1.3 BPY 62 Relative Spectral Sensitivity 1) page 9 Srel = f(λ) Photocurrent 1) page 9 IPCE = f(Ee), VCE = 5 V OHF04043 100 Srel % 80 70 60 50 40 30 20 10 0 400 500 600 700 800 900 nm 1100 λ 1) page 9 Collector Current 1) page 9 IC = f(VCE), IB = Parameter Collector Current IC = f(VCE), IB = Parameter 2016-01-04 4 Version 1.3 BPY 62 Photocurrent 1) page 9 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Dark Current 1) page 9 ICEO = f(VCE), E = 0 OHF04049 10 1 nA I CEO 10 0 10 -1 10 -2 0 5 10 15 20 25 30 V 35 VCE Dark Current 1) page 9 ICEO = f(TA), E = 0 Collector-Base Capacitance 1) page 9 CCB = f(VCB), f = 1 MHz, E = 0 OHF04050 10 4 nA OHF04053 16 pF C CB 14 I CEO 10 3 12 10 2 10 10 1 8 6 10 0 4 10 -1 2 10 -2 -25 0 25 50 0 -3 10 75 ˚C 100 10 -1 10 0 10 1 V 10 2 VCE TA 2016-01-04 10 -2 5 Version 1.3 BPY 62 Collector-Emitter Capacitance 1) page 9 CCE = f(VCE), f = 1 MHz, E = 0 Emitter-Base Capacitance 1) page 9 CEB = f(VEB), f = 1 MHz, E = 0 OHF04051 8 pF C CE 7 C EB OHF04054 22 pF 18 6 16 5 14 12 4 10 3 8 6 2 4 1 0 -3 10 2 10 -2 10 -1 10 0 0 -3 10 10 1 V 10 2 10 -1 10 0 10 1 V 10 2 VEB VCE Power Consumption Ptot = f(TA) 2016-01-04 10 -2 6 Version 1.3 BPY 62 Directional Characteristics 1) page 9 Srel = f(ϕ) Package Outline ø4.6 (0.181) ø0.45 (0.018) ø4.8 (0.189) (2.7 (0.106)) 0.9 1.1 (0 (0 .03 .04 5) 14.5 (0.571) 5.1 (0.201) 12.5 (0.492) 4.8 (0.189) 6.2 (0.244) 3) E C B ø5.6 (0.220) ø5.3 (0.209) 5.4 (0.213) GMOY6019 Dimensions in mm (inch). Package Metal Can (TO-18), hermetically sealed 2016-01-04 3) .0 04 5) ( 03 1.1 (0. 9 0. 2.54 (0.100) spacing Radiant sensitive area Chip position 7 Version 1.3 BPY 62 Approximate Weight: 0.3 g TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 8 Version 1.3 BPY 62 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 9 Version 1.3 BPY 62 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 10
BPY62-3/4 价格&库存
很抱歉,暂时无法提供与“BPY62-3/4”相匹配的价格&库存,您可以联系我们找货
