2016-01-04
Silicon NPN Phototransistor
Version 1.3
BPX 38
Features:
Spectral range of sensitivity: (typ) 450 ... 1120 nm
Package: Metal Can (TO-18), hermetically sealed
Special: Base connection
Suitable up to 125 °C
High linearity
Available in groups
Applications
Photointerrupters
Industrial electronics
For control and drive circuits
Ordering Information
Type:
Photocurrent
Ordering Code
IPCE [µA]
λ = 950 nm, Ee = 0.5 mW/cm2,
VCE = 5 V
BPX 38
≥ 200
Q62702P0015
BPX 38-2/3
200 ... 630
Q62702P3578
BPX 38-3
320 ... 630
Q62702P0015S003
BPX 38-4
500 ... 1000
Q62702P0015S004
Note:
Only one bin within one packing unit (variation less than 2:1)
2016-01-04
1
Version 1.3
BPX 38
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 125
°C
Collector-emitter voltage
VCE
50
V
Collector current
IC
50
mA
Collector surge current
(τ < 10 µs)
ICS
200
mA
Emitter-base voltage
VEB
7
Total Power dissipation
Ptot
220
mW
Thermal resistance
RthJA
450
K/W
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
880
nm
Wavelength of max. sensitivity
(typ)
λS max
(typ)
λ10%
Radiant sensitive area
(typ)
A
0.675
mm2
Dimensions of chip area
(typ)
LxW
(typ) 1.02 x
1.02
mm x
mm
Half angle
(typ)
ϕ
± 40
Photocurrent of collector-base photodiode
(λ = 950 nm, Ee = 0.5 mW/cm2, VCB = 5 V)
(typ)
IPCB
1.8
μA
(EV = 1000 lx, Std. Light A, V CB = 5 V)
(typ)
IPCB
5.5
μA
Capacitance
(VCE = 0 V, f = 1 MHz, E = 0)
(typ)
CCE
23
pF
Capacitance
(VCB = 0 V, f = 1 MHz, E = 0)
(typ)
CCB
39
pF
Capacitance
(VEB = 0 V, f = 1 MHz, E = 0)
(typ)
CEB
47
pF
Dark current
(VCE = 25 V, E = 0)
(typ (max)) ICE0
20 (≤ 100)
nA
2016-01-04
2
(typ) 450
... 1120
nm
Version 1.3
BPX 38
Grouping (TA = 25 °C, λ = 950 nm)
Group
Min Photocurrent
Max Photocurrent Typ Photocurrent Rise and fall time
Ee = 0.5 mW/cm2,
VCE = 5 V
Ee = 0.5 mW/cm2,
VCE = 5 V
EV = 1000 lx, Std.
Light A, VCE = 5 V
IC = 1 mA, VCC = 5
V, RL = 1 kΩ
IPCE, min [µA]
IPCE, max [µA]
IPCE [µA]
tr, tf [µs]
BPX 38-2
200
400
950
9
BPX 38-3
320
630
1500
12
BPX 38-4
500
1000
2300
15
BPX 38-5
800
3600
18
Group
Collector-emitter saturation
voltage
Current gain
IC = IPCEmin x 0.3,
Ee= 0.5 mW/cm2
Ee = 0.5 mW/cm2, VCE = 5 V
VCEsat [mV]
IPCE / IPCB
BPX 38-2
200
170
BPX 38-3
200
280
BPX 38-4
200
420
BPX 38-5
200
650
Note.:
IPCEmin is the min. photocurrent of the specified group.
2016-01-04
3
Version 1.3
BPX 38
Relative Spectral Sensitivity 1) page 9
Srel = f(λ)
Photocurrent 1) page 9
IPCE = f(Ee), VCE = 5 V
Collector Current 1) page 9
IC = f(VCE), IB = Parameter
2016-01-04
4
Version 1.3
BPX 38
IPCE / IPCE(25°C) = f(TA), VCE = 5 V
Dark Current 1) page 9
ICEO = f(VCE), E = 0
ICEO/ICEO(25°) = f(TA), VCE = 25 V, E = 0
Collector-Base Capacitance 1) page 9
CCB = f(VCB), f = 1 MHz, E = 0
2016-01-04
5
Version 1.3
BPX 38
Collector-Emitter Capacitance 1) page 9
CCE = f(VCE), f = 1 MHz, E = 0
Emitter-Base Capacitance 1) page 9
CEB = f(VEB), f = 1 MHz, E = 0
Power Consumption
Ptot = f(TA)
2016-01-04
6
Version 1.3
BPX 38
Directional Characteristics 1) page 9
Srel = f(ϕ)
Package Outline
1.1
3)
35
.0
(0
.04
(0
0.9
14.5 (0.571)
5.3 (0.209)
12.5 (0.492)
5.0 (0.197)
5.5 (0.217)
E C B
2.54 (0.100)
spacing
0.9
1.1
ø4.6 (0.181)
ø0.45 (0.018)
ø4.8 (0.189)
(2.7 (0.106))
(0
(0 043
.03 )
5)
Radiant
sensitive area
Chip position
ø5.6 (0.220)
ø5.3 (0.209)
5.0 (0.197)
Approx. weight 1.0 g
GMOY6018
Dimensions in mm (inch).
Package
2016-01-04
7
Version 1.3
BPX 38
Approximate Weight:
0.28 g
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-01-04
8
Version 1.3
BPX 38
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-01-04
9
Version 1.3
BPX 38
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-01-04
10
