SFH300
SFH300
    AMSOSRAM(艾迈斯半导体)
    DIP
    PHOTOTRANSISTORNPN5MM880NM
SFH300 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 SFH 300 Features: • Spectral range of sensitivity: (typ) 450 ... 1100 nm • Package: 5mm Radial (T 1 ¾), Epoxy • Special: High linearity • Available in groups Applications • Photointerrupters • Industrial electronics • For control and drive circuits • Computer-controlled flashes Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V SFH 300 ≥ 630 Q62702P1189 SFH 300-3/4 ≥ 1000 Q62702P3586 Note: Only one bin within one packing unit (variation less than 2:1) 2016-01-04 1 Version 1.3 SFH 300 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 35 V Collector current IC 50 mA Collector surge current (τ < 10 µs) ICS 100 mA Emitter-collector voltage VEC 7 Total Power dissipation Ptot 200 mW Thermal resistance RthJA 375 K/W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 880 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.11 mm2 Dimensions of chip area (typ) LxW (typ) 0.55 x 0.55 mm x mm Half angle (typ) ϕ ± 25 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE 7.5 pF Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 1 (≤ 50) nA Rise and fall time (IC = 1 mA, VCC = 5 V, RL = 1 kΩ) (typ) 10 µs 2016-01-04 2 tr, tf (typ) 450 ... 1100 nm Version 1.3 SFH 300 Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Typ Photocurrent Rise and fall time Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V SFH 300: EV = 1000 lx, Std. Light A, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IPCE, min [µA] IPCE, max [µA] IPCE [µA] tr, tf [µs] -2 630 1250 3000 7.5 -3 1000 2000 4800 10 -4 1600 7700 10 Group Collector-emitter saturation voltage IC = IPCEmin x 0.3, Ee = 0.5 mW/cm2 VCEsat [mV] -2 130 -3 140 -4 150 Note.: IPCEmin is the min. photocurrent of the specified group. Relative Spectral Sensitivity 1) page 8 Srel = f(λ) 100 Photocurrent 1) page 8 IPCE = f(Ee), VCE = 5 V OHF04042 Srel % 80 70 60 50 40 30 20 10 0 400 500 600 700 800 900 nm 1100 λ 2016-01-04 3 Version 1.3 SFH 300 Photocurrent 1) page 8 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Dark Current 1) page 8 ICEO = f(VCE), E = 0 OHF04049 10 1 nA I CEO 10 0 10 -1 10 -2 0 5 10 15 20 25 30 V 35 VCE Dark Current 1) page 8 ICEO = f(TA), E = 0 Collector-Emitter Capacitance 1) page 8 CCE = f(VCE), f = 1 MHz, E = 0 OHF04050 10 4 nA OHF04051 8 pF C CE 7 I CEO 10 3 6 10 2 5 10 1 4 3 10 0 2 10 -1 1 10 -2 -25 0 25 50 0 -3 10 75 ˚C 100 TA 2016-01-04 10 -2 10 -1 10 0 10 1 V 10 2 VCE 4 Version 1.3 SFH 300 Directional Characteristics 1) page 8 Srel = f(ϕ) Package Outline 7.8 (0.307) 7.5 (0.295) 25.2 (0.992) 24.2 (0.953) 9.0 (0.354) 8.2 (0.323) Collector Dimensions in mm (inch). Package 5mm Radial (T 1 ¾), Epoxy 2016-01-04 5 5.9 (0.232) 5.5 (0.217) ø5.1 (0.201) 1.2 (0.047) 1.0 (0.039) 1.8 (0.071) 1.3 (0.051) 2.54 (0.100) spacing Emitter 0.6 (0.024) 0.4 (0.016) 1.0 (0.039) 0.7 (0.028) Area not flat Chip position 11.6 (0.457) 11.2 (0.441) 4.5 (0.177) 4.2 (0.165) 0.6 (0.024) 0.4 (0.016) GEOY6652 Version 1.3 SFH 300 Approximate Weight: 0.3 g Note Packing information is available on the internet (online product catalog). Recommended Solder Pad Dimensions in mm. 2016-01-04 6 Version 1.3 SFH 300 TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 7 Version 1.3 SFH 300 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 8 Version 1.3 SFH 300 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 9
SFH300 价格&库存
很抱歉,暂时无法提供与“SFH300”相匹配的价格&库存,您可以联系我们找货
