2016-01-04
Silicon NPN Phototransistor
Version 1.3
SFH 310 FA
Features:
Spectral range of sensitivity: (typ) 740 ... 1100 nm
Package: 3mm Radial (T 1), Epoxy
Special: high photosensitivity
Applications
Photointerrupters
Industrial electronics
For control and drive circuits
Ordering Information
Type:
Photocurrent
Ordering Code
IPCE [µA]
λ = 950 nm, Ee = 0.5 mW/cm2,
VCE = 5 V
SFH 310 FA
400 ... 3200
Q62702P1673
SFH 310 FA-2/3
630 ... 2000
Q62702P3596
Note:
Only one bin within one packing unit (variation less than 2:1)
2016-01-04
1
Version 1.3
SFH 310 FA
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 100
°C
Collector-emitter voltage
VCE
35
V
Collector current
IC
50
mA
Collector surge current
ICS
100
mA
Total Power dissipation
Ptot
165
mW
Thermal resistance
RthJA
450
K/W
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2000
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
890
nm
Wavelength of max. sensitivity
(typ)
λS max
(typ)
λ10%
Radiant sensitive area
(typ)
A
0.11
mm2
Dimensions of chip area
(typ)
LxW
(typ) 0.5 x
0.5
mm x
mm
Half angle
(typ)
ϕ
± 25
Capacitance
(VCE = 0 V, f = 1 MHz, E = 0)
(typ)
CCE
7.5
pF
Dark current
(VCE = 20 V, E = 0)
(typ (max)) ICE0
1 (≤ 50)
nA
2016-01-04
2
(typ) 740
... 1100
nm
Version 1.3
SFH 310 FA
Grouping (TA = 25 °C, λ = 950 nm)
Group
Min Photocurrent
Max Photocurrent Rise and fall time
Collector-emitter
saturation
voltage
Ee = 0.5 mW/cm2,
VCE = 5 V
Ee = 0.5 mW/cm2,
VCE = 5 V
IC = 1 mA, VCC = 5
V, RL = 1 kΩ
IC = IPCEmin x 0.3, Ee
= 0.5 mW/cm2
IPCE, min [µA]
IPCE, max [µA]
tr, tf [µs]
VCEsat [mV]
-2
630
1250
5
150
-3
1000
2000
8
150
-4
1600
3200
12
150
Note.:
IPCEmin is the min. photocurrent of the specified group.
Relative Spectral Sensitivity 1) page 9
Srel = f(λ)
100
Srel %
Photocurrent 1) page 9
IPCE = f(Ee), VCE = 5 V
OHF04075
80
70
60
50
40
30
400 500 600 700 800 900
nm 1100
λ
2016-01-04
3
Version 1.3
SFH 310 FA
IPCE = f(VCE), Ee = Parameter
IPCE / IPCE(25°C) = f(TA), VCE = 5 V
Ι PCE
OHF01524
1.6
Ι PCE 25
1.4
1.2
1.0
0.8
0.6
0.4
0.2
Dark Current 1) page 9
ICEO = f(VCE), E = 0
50
75 C 100
TA
ICEO = f(TA), E = 0
OHF04049
10 1
nA
OHF04050
10 4
nA
I CEO
I CEO
10 3
10 0
10 2
10 1
10 -1
10 0
10 -1
10 -2
10
15
10 -2
-25
30 V 35
VCE
2016-01-04
50
75 ˚C 100
TA
4
Version 1.3
SFH 310 FA
Collector-Emitter Capacitance 1) page 9
CCE = f(VCE), f = 1 MHz, E = 0
Power Consumption
Ptot = f(TA)
OHF04051
8
pF
C CE
7
6
5
4
3
2
1
0 -3
10
10 -2
10 -1
10 0
10 1 V 10 2
VCE
Directional Characteristics 1) page 9
Srel = f(ϕ)
2016-01-04
5
Version 1.3
SFH 310 FA
Package Outline
4.8 (0.189)
4.4 (0.173)
1.8 (0.071)
1.2 (0.047)
Collector
ø2.9 (0.114)
ø2.7 (0.106)
1.1 (0.043)
0.9 (0.035)
0.4 (0.016)
0.8 (0.031)
0.4 (0.016)
0.7 (0.028)
0.4 (0.016)
0.6 (0.024)
2.54 (0.100)
spacing
Area not flat
3.1 (0.122)
3.7 (0.146)
0.6 (0.024)
3.5 (0.138)
6.1 (0.240)
0.4 (0.016)
5.7 (0.224)
29.0 (1.142)
27.0 (1.063)
GEXY6710
Dimensions in mm (inch).
Package
Approximate Weight:
0.2 g
Note
Packing information is available on the internet (online product catalog).
2016-01-04
3.4 (0.134)
6
Version 1.3
SFH 310 FA
Recommended Solder Pad
Dimensions in mm.
Note:
pad 1: emitter
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
2016-01-04
7
Version 1.3
SFH 310 FA
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-01-04
8
Version 1.3
SFH 310 FA
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-01-04
9
Version 1.3
SFH 310 FA
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-01-04
10
很抱歉,暂时无法提供与“SFH310FA”相匹配的价格&库存,您可以联系我们找货
