SFH309-5/6
SFH309-5/6
    AMSOSRAM(艾迈斯半导体)
    DIP
    PHOTOTRANSISTORNPN3MM860NM
SFH309-5/6 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 SFH 309 Features: • Spectral range of sensitivity: (typ) 380 ... 1150 nm • Package: 3mm Radial (T 1), Epoxy • Special: High photosensitivity • High linearity • Available in groups Applications • Photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V SFH 309 400 ... 5000 Q62702P0859 SFH 309-3/4 630 ... 2000 Q62702P3592 SFH 309-4 1000 ... 2000 Q62702P0998 SFH 309-4/5 1000 ... 3200 Q62702P3593 SFH 309-5 1600 ... 3200 Q62702P0999 SFH 309-5/6 1600 ... 5000 Q62702P3594 Note: Only one bin within one packing unit (variation less than 2:1) 2016-01-04 1 Version 1.3 SFH 309 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 35 V Collector current IC 15 mA Collector surge current (τ < 10 µs) ICS 75 mA Total Power dissipation Ptot 165 mW Thermal resistance RthJA 450 K/W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 860 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (∅ 220 μm) (typ) A 0.038 mm2 Dimensions of chip area (typ) LxW (typ) 0.45 x 0.45 mm x mm Distance chip front to case surface (min ... max) H (min ... max) 2.4 ... 2.8 Half angle (typ) ϕ ± 12 Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 2016-01-04 2 (typ) 380 ... 1150 nm mm ° 5 pF 1 (≤ 50) nA Version 1.3 SFH 309 Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Typ Photocurrent Rise and fall time Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V EV = 1000 lx, Std. Light A, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IPCE, min [µA] IPCE, max [µA] IPCE [µA] tr, tf [µs] -2 400 800 1500 5 -3 630 1250 2800 6 -4 1000 2000 4500 7 -5 1600 3200 7200 8 -6 2500 5000 11200 9 Group Collector-emitter saturation voltage IC = IPCEmin x 0.3, Ee = 0.5 mW/cm2 VCEsat [mV] -2 200 -3 200 -4 200 -5 200 -6 200 Note.: IPCEmin is the min. photocurrent of the specified group. 2016-01-04 3 Version 1.3 SFH 309 Relative Spectral Sensitivity 1) page 9 Srel = f(λ) Photocurrent 1) page 9 IPCE = f(Ee), VCE = 5 V OHF01121 100 S rel % 80 60 40 20 0 400 600 800 1000 nm 1200 λ Photocurrent 1) page 9 IPCE = f(VCE), Ee = Parameter Photocurrent 1) page 9 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Ι PCE OHF01524 1.6 Ι PCE 25 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 -25 2016-01-04 4 0 25 50 75 C 100 TA Version 1.3 SFH 309 Dark Current 1) page 9 ICEO = f(VCE), E = 0 Dark Current 1) page 9 ICE0 = f(TA), VCE = 20 V, E = 0 OHF01527 10 1 nA Ι CEO Ι CEO 10 0 10 2 10 -1 10 1 10 -2 10 0 10 -3 0 5 10 15 20 25 10 -1 -25 30 V 35 V CE Collector-Emitter Capacitance 1) page 9 CCE = f(VCE), f = 1 MHz, E = 0 C CE pF 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 10 -2 10 -1 10 0 0 Power Consumption Ptot = f(TA) OHF01528 5.0 2016-01-04 OHF01530 10 3 nA 10 1 V 10 2 V CE 5 25 50 75 ˚C 100 TA Version 1.3 SFH 309 Directional Characteristics 1) page 9 Srel = f(ϕ) Package Outline Collector (Transistor) Cathode (Diode) ø3.1 (0.122) ø2.9 (0.114) 0.7 (0.028) 0.4 (0.016) 0.8 (0.031) 0.4 (0.016) 2.54 (0.100) spacing Area not flat 5.2 (0.205) 4.5 (0.177) 4.1 (0.161) 3.9 (0.154) 4.0 (0.157) 3.6 (0.142) 3.5 (0.138) 1.8 (0.071) 1.2 (0.047) 29 (1.142) 27 (1.063) 0.6 (0.024) 0.4 (0.016) Chip position 6.3 (0.248) 5.9 (0.232) GEOY6653 Dimensions in mm (inch). Package 3mm Radial (T 1), Epoxy 2016-01-04 6 Version 1.3 SFH 309 Approximate Weight: 0.2 g Note Packing information is available on the internet (online product catalog). Recommended Solder Pad Dimensions in mm. Note: pad 1: emitter 2016-01-04 7 Version 1.3 SFH 309 TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 8 Version 1.3 SFH 309 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 9 Version 1.3 SFH 309 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 10
SFH309-5/6 价格&库存
很抱歉,暂时无法提供与“SFH309-5/6”相匹配的价格&库存,您可以联系我们找货
