SFH313FA-2/3
SFH313FA-2/3
    AMSOSRAM(艾迈斯半导体)
    DIP
    PHOTOTRANSISTORNPN5MM870NM
SFH313FA-2/3 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 SFH 313 FA Features: • Spectral range of sensitivity: (typ) 740 ... 1080 nm • Package: 5mm Radial (T 1 ¾), Epoxy • Special: 5 mm plastic package • High photosensitivity • Especially suitable for applications from 740 nm to 1080 nm Applications • Computer-controlled flashes • Photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V SFH 313 FA ≥ 2500 Q62702P1674 SFH 313 FA-2/3 4000 ... 12500 Q62702P3597 SFH 313 FA-3/4 ≥ 6300 Q62702P5196 2016-01-04 1 Version 1.3 SFH 313 FA Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 70 V Collector current IC 50 mA Collector surge current (τ < 10 µs) ICS 100 mA Emitter-collector voltage VEC 7 Total Power dissipation Ptot 200 mW Thermal resistance RthJA 375 K/W ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V V Characteristics (TA = 25 °C, λ = 950 nm) Parameter Symbol Values Unit 870 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.55 Dimensions of chip area (typ) LxW (typ) 1 x 1 mm x mm Half angle (typ) ϕ ± 10 Capacitance (VCE = 5 V, f = 1 MHz, E = 0) (typ) CCE Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 2016-01-04 2 (typ) 740 ... 1080 nm mm2 ° 10 pF 3 (≤ 200) nA Version 1.3 SFH 313 FA Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Rise and fall time Collector-emitter saturation voltage Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IC = IPCEmin x 0.3, Ee = 0.5 mW/cm2 IPCE, min [µA] IPCE, max [µA] tr, tf [µs] VCEsat [mV] -1 2500 5000 8 150 -2 4000 8000 10 150 -3 6300 12500 12 150 -4 10000 14 150 Note.: IPCEmin is the min. photocurrent of the specified group. Photocurrent 1) page 9 IPCE = f(Ee), VCE = 5 V Relative Spectral Sensitivity 1) page 9 SFH 313 FA Srel = f(λ) OHF02337 10 2 mA OHF02331 100 Ι PCE S rel % 80 10 1 60 10 0 40 10 -1 20 0 400 2016-01-04 600 800 10 -2 -3 10 1000 nm 1200 λ 3 10 -2 mW/cm 2 Ee 10 0 Version 1.3 SFH 313 FA Photocurrent 1) page 9 IPCE = f(VCE), Ee = Parameter Photocurrent 1) page 9 IPCE / IPCE(25°C) = f(TA), VCE = 5 V OHF02336 10 2 mA Ι PCE Ι PCE OHF01524 1.6 Ι PCE 25 1 1.4 mW cm 2 1.2 0.5 mW cm 2 1.0 10 1 0.25 0.8 mW cm 2 0.6 mW 0.1 2 cm 0.4 0.2 10 0 0 10 20 30 40 50 0 -25 V 70 VCE Dark Current 1) page 9 ICEO = f(VCE), E = 0 OHF02341 50 75 C 100 TA OHF02342 10 3 nA Ι CEO Ι CEO 10 1 10 2 10 0 10 1 10 -1 10 0 10 -2 10 -1 0 2016-01-04 25 Dark Current 1) page 9 ICEO = f(TA), E = 0 10 2 nA 0 0 10 20 30 40 50 V 70 V CE 4 20 40 60 80 ˚C 100 TA Version 1.3 SFH 313 FA Collector-Emitter Capacitance 1) page 9 CCE = f(VCE), f = 1 MHz, E = 0 CCE Power Consumption Ptot = f(TA) OHF00349 18 pF 16 Ptot OHF02340 250 mW 200 14 12 150 10 8 100 6 4 50 2 0 -2 10 10 -1 10 0 10 1 0 V 10 2 0 20 40 60 80 ˚C 100 TA V CE Directional Characteristics 1) page 9 Srel = f(ϕ) 40 30 20 10 ϕ 0 OHF02330 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 2016-01-04 1.0 0.8 0.6 0.4 0 5 20 40 60 80 100 120 Version 1.3 SFH 313 FA Package Outline 9.0 (0.354) 1.8 (0.071) 1.2 (0.047) 29 (1.142) 27 (1.063) ø4.8 (0.189) 7.5 (0.295) 0.8 (0.031) 0.5 (0.020) 2.54 (0.100) spacing 0.6 (0.024) 0.4 (0.016) Area not flat 7.8 (0.307) ø5.1 (0.201) 8.2 (0.323) 5.7 (0.224) 0.6 (0.024) 5.1 (0.201) Chip position 0.4 (0.016) Cathode (Diode) Collector (Transistor) GEXY6260 Dimensions in mm (inch). Package 5mm Radial (T 1 ¾), Epoxy Approximate Weight: 0.4 g Note Packing information is available on the internet (online product catalog). 2016-01-04 5.9 (0.232) 5.5 (0.217) 6 Version 1.3 SFH 313 FA Recommended Solder Pad Dimensions in mm. Note: pad 1: emitter TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t 2016-01-04 7 Version 1.3 SFH 313 FA Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 8 Version 1.3 SFH 313 FA Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 9 Version 1.3 SFH 313 FA Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 10
SFH313FA-2/3
1. 物料型号:SFH 313 FA,它是一个硅NPN光电晶体管,具有高光敏性,特别适用于740 nm至1080 nm的应用领域。
2. 器件简介:SFH 313 FA是一个5毫米的塑料封装光电晶体管,具有高光敏性,适用于计算机控制的闪光灯、光电中断器、工业电子以及控制和驱动电路。
3. 引脚分配:文档中没有直接提供引脚分配的具体信息,但根据其5mm Radial (T 1 ¾)封装类型,我们可以推断它可能具有典型的NPN晶体管引脚配置,即包括发射极(Emitter)、基极(Base)和集电极(Collector)。
4. 参数特性:文档列出了包括工作和存储温度范围(-40°C至+100°C)、集电极-发射极电压(VCE最大70V)、集电极电流(Ic最大50mA)、集电极脉冲电流(Ics最大100mA)、发射极-集电极电压(VEC最大7V)、总功率耗散(Ptot最大200mW)和热阻(RthJA 375 K/W)等参数。
5. 功能详解:文档提供了关于光电晶体管的光谱响应范围、最大灵敏度波长、光敏面积、芯片尺寸、半角、暗电流、饱和电压等特性的详细描述。
6. 应用信息:SFH 313 FA适用于计算机控制的闪光灯、光电中断器、工业电子等领域。
7. 封装信息:提供了5mm Radial (T 1 ¾)环氧树脂封装的详细尺寸和推荐焊接垫尺寸。
SFH313FA-2/3 价格&库存
很抱歉,暂时无法提供与“SFH313FA-2/3”相匹配的价格&库存,您可以联系我们找货
