SFH320FA-3-Z
SFH320FA-3-Z
    AMSOSRAM(艾迈斯半导体)
    LCC-2
    PHOTOTRANSISTORNPN980NM2PLCC
SFH320FA-3-Z 数据手册
2015-12-08 Silicon NPN Phototransistor in SMT TOPLED®-Package Version 1.4 SFH 320 FA Features: • Spectral range of sensitivity: (typ) 750 ... 1120 nm • Package: TOPLED • Special: High linearity • P-LCC-2 package • Available in groups • Suitable for all soldering methods • The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification for Automotive Grade Discrete Semiconductors. Applications • Miniature photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.1 mW/cm2, VCE = 5 V SFH 320 FA 16 ... 80 Q65110A2472 SFH 320 FA-3 25 ... 50 Q65110A2470 SFH 320 FA-3/4 25 ... 80 Q65110A2475 SFH 320 FA-4 40 ... 80 Q65110A1836 Note: Only one bin within one packing unit (variation less than 2:1) 2015-12-08 1 Version 1.4 SFH 320 FA Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Collector-emitter voltage VCE 35 V Collector current IC 15 mA Collector surge current (τ < 10 µs) ICS 75 mA Total Power dissipation Ptot 165 mW ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Thermal resistance for mounting on pcb RthJA 450 K/W Characteristics (TA = 25 °C) Parameter Symbol Values Unit 980 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (ø 220µm) (typ) A 0.038 mm2 Dimensions of chip area (typ) LxW (typ) 0.45 x 0.45 mm x mm Half angle (typ) ϕ ± 60 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE Dark current (VCE = 20 V, E = 0) (typ (max)) ICE0 2015-12-08 2 (typ) 750 ... 1120 nm 5 pF 1 (≤ 50) nA Version 1.4 SFH 320 FA Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Rise and fall time Collector-emitter saturation voltage Ee = 0.1 mW/cm2, VCE = 5 V Ee = 0.1 mW/cm2, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IC = IPCEmin x 0.3, Ee = 0.1 mW/cm2 IPCE, min [µA] IPCE, max [µA] tr, tf [µs] VCEsat [mV] -2 16 32 6 150 -3 25 50 7 150 -4 40 80 8 150 Note.: IPCEmin is the min. photocurrent of the specified group. Relative Spectral Sensitivity 1) page 13 Srel = f(λ) 100 Photocurrent 1) page 13 IPCE = f(Ee), VCE = 5 V OHF01924 10 3 µA OHF00468 Ι PCE S rel % 80 10 2 60 10 4 3 2 1 40 10 0 20 0 400 500 600 700 800 900 2015-12-08 10 -1 -3 10 nm 1100 λ 10 -2 10 0 mW/cm 2 Ee 3 Version 1.4 SFH 320 FA Photocurrent 1) page 13 IPCE = f(VCE), Ee = Parameter Photocurrent 1) page 13 IPCE / IPCE(25°C) = f(TA), VCE = 5 V OHF01529 10 0 mA Ι PCE mW 1 2 cm Ι PCE OHF01524 1.6 Ι PCE 25 1.4 mW 0.5 2 cm 1.2 mW cm 2 1.0 0.25 10 -1 0.8 mW 0.1 2 cm 0.6 0.4 0.2 10 -2 0 5 10 15 20 25 0 -25 30 V 35 V CE Dark Current 1) page 13 ICEO = f(VCE), E = 0 OHF01527 50 75 C 100 TA OHF01530 10 3 nA Ι CEO Ι CEO 10 0 10 2 10 -1 10 1 10 -2 10 0 2015-12-08 25 Dark Current 1) page 13 ICEO = f(TA), E = 0 10 1 nA 10 -3 0 0 5 10 15 20 25 10 -1 -25 30 V 35 V CE 4 0 25 50 75 ˚C 100 TA Version 1.4 SFH 320 FA Collector-Emitter Capacitance 1) page 13 CCE = f(VCE), f = 1 MHz, E = 0 Power Consumption Ptot = f(TA), RthJA = 450 K / W OHF01528 5.0 OHF00871 200 C CE pF mW P tot 4.0 160 3.5 120 3.0 2.5 80 2.0 1.5 1.0 40 0.5 0 10 -2 10 -1 10 0 0 10 1 V 10 2 V CE 0 20 40 60 80 ˚C 100 TA Directional Characteristics 1) page 13 Srel = f(ϕ) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 2015-12-08 1.0 0.8 0.6 0.4 0 5 20 40 60 80 100 120 Version 1.4 SFH 320 FA Package Outline 2.1 (0.083) 3.0 (0.118) 2.6 (0.102) 2.3 (0.091) 1.7 (0.067) 0.1 (0.004) (typ.) 0.9 (0.035) 0.7 (0.028) 0.5 (0.020) 3.7 (0.146) 3.3 (0.130) 4˚±1 1.1 (0.043) Collector marking (2.4) (0.095) 3.4 (0.134) 3.0 (0.118) 2.1 (0.083) 0.18 (0.007) 0.12 (0.005) 0.6 (0.024) 0.4 (0.016) GPLY6030 Dimensions in mm (inch). Package TOPLED Approximate Weight: 35 mg 2015-12-08 6 Version 1.4 SFH 320 FA Recommended Solder Pad Dimensions in mm. Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t 2015-12-08 7 Version 1.4 SFH 320 FA OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum 2 3 100 120 2 3 ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C °C 480 Time 25 °C to TP s All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Taping 2.9 (0.114) 4 (0.157) Dimensions in mm (inch). 2015-12-08 8 8 (0.315) Cathode/Collector Marking 1.75 (0.069) 2 (0.079) 3.5 (0.138) 4 (0.157) 3.6 (0.142) 1.5 (0.059) OHAY2271 Version 1.4 SFH 320 FA Tape and Reel 8 mm tape with 2000 pcs. on ∅ 180 mm reel, 8000 pcs. on ∅ 330 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Tape dim ensions in m m W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 A W Nmin W1 W2max 330 8 60 8.4 + 2 14.4 Reel dim ensions in m m 2015-12-08 9 Version 1.4 SFH 320 FA Barcode-Product-Label (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Moisture-sensitive label or print L VE el see lab e LE If nk, bla cod bar . H) y (R . dit RH mi % hu e ve ed ag ati /60 Barcode label ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < urs ). urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk rd g -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. 2015-12-08 10 Version 1.4 SFH 320 FA Transportation Packing and Materials Barcode label D/ 8 Y M DE R 18 -1 P -1 + Q C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : TY : 20 (Q )Q : NO M RA OS (X ) PR O D 5 14 2 110 0 Packing Sealing label Dimensions of transportation box in mm Width Length Height 200 ± 5 352 ± 5 195 ± 5 352 ± 5 30 ± 5 33 ± 5 2015-12-08 OD PR ) (X (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 00 C: 01 44 Muster O ct pto o rs u M (9 D) d A n o : 34 ic S R NO O BA TC H 3G H (1 T) LO T NO (6 P) S 8 12 2199 : 12 em 2100 01 44 el OU P: L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is en ing be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed is re qu ty 2. JE bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 11 OHA02044 Version 1.4 SFH 320 FA Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-12-08 12 Version 1.4 SFH 320 FA Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2015-12-08 13 Version 1.4 SFH 320 FA Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-12-08 14
SFH320FA-3-Z 价格&库存
很抱歉,暂时无法提供与“SFH320FA-3-Z”相匹配的价格&库存,您可以联系我们找货
