2016-04-01
Silicon NPN Phototransistor with Vλ Characteristics
Version 1.3
SFH 3410
Features:
Spectral range of sensitivity: (typ) 350 ... 970 nm
Package: Smart DIL
Especially suitable for applications from 350 nm to 970 nm
Adapted to human eye sensitivity (Vλ)
SMT package without base connection, suitable for IR reflow soldering
Only available on tape and reel
The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification
for Automotive Grade Discrete Semiconductors.
Applications
For control and drive circuits
Exposure meter for daylight and artificial light
Sensor for backlight-dimming
Ambient light detector
Ordering Information
Type:
Photocurrent
Ordering Code
IPCE [µA]
Ev = 20 lx, Std. Light A, VCE = 5 V
SFH 3410
3.2 ... 25
Q65110A1211
SFH 3410-1/2
3.2 ... 10
Q65110A2653
SFH 3410-2/3
5 ... 16
Q65110A2654
SFH 3410-3/4
8 ... 25
Q65110A2655
2016-04-01
1
Version 1.3
SFH 3410
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Unit
Operating and storage temperature range
Top; Tstg
-40 ... 100
°C
Collector-emitter voltage
VCE
5.5
V
Collector current
IC
mA
Emitter-collector voltage
VEC
0.5
V
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2000
V
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
570
nm
Wavelength of max. sensitivity
(typ)
λS max
(typ)
λ10%
Radiant sensitive area
(typ)
A
0.29
mm2
Dimensions of chip area
(typ)
LxW
(typ) 0.75 x
0.75
mm x
mm
Half angle
(typ)
ϕ
± 60
Capacitance
(VCE = 0 V, f = 1 MHz, E = 0)
(typ)
CCE
3.9
pF
IPCE
> 3.2
µA
3 (≤ 50)
nA
Photocurrent
(Ev = 20 lx, Std. Light A, VCE = 5 V)
Dark current
(VCE = 5 V, E = 0)
2016-04-01
(typ (max)) ICE0
2
(typ) 350
... 970
nm
Version 1.3
SFH 3410
Grouping (TA = 25 °C)
Group
Min Photocurrent
Max Photocurrent
Collector-emitter
saturation voltage
EV = 20 lx, Std. Light A, EV = 20 lx, Std. Light A, IC = IPCEmin x 0.3,
VCE = 5 V
VCE = 5 V
EV = 20 lx
IPCE, min [µA]
IPCE, max [µA]
VCEsat [mV]
SFH 3410-1
3.2
6.3
100
SFH 3410-2
5
10
100
SFH 3410-3
8
16
100
SFH 3410-4
12.5
25
100
Note.:
IPCEmin is the min. photocurrent of the specified group
Relative Spectral Sensitivity 1) page 12
Srel = f(λ)
Photocurrent 1) page 12
IPCE = f (EV), VCE = 5 V
OHF00851
100
µA
Srel
OHF00852
1000
I PCE
80
70
100
60
50
40
Vλ
10
30
1
1
400 500 600 700 800 900 nm 1100
λ
2016-04-01
10
100
lx 1000
EV
3
Version 1.3
SFH 3410
IPCE / IPCE(25°C) = f(TA), EV = 20 lx, VCE = 1 V ... 5 V
Collector-Emitter Capacitance 1) page 12
CCE = f(VCE), f = 1 MHz, E = 0
OHF05722
2.4
I PCE
I PCE (25 ˚C)
C CE
OHF04052
4.0
pF
3.0
1.8
1.6
2.5
1.4
2.0
1.2
1.0
1.5
0.8
1.0
0.6
0.4
0.5
0.2
-25
50
0 -3
10
˚C 100
Collector-Emitter Current 1) page 12
ICE = f(VCE; EV)
I CE
OHF00854
200 lx
70
60
50
40
100 lx
30
20 lx
2
3
4
V 5
VCE
2016-04-01
10 -1
10 0
10 1 V 10 2
VCE
TA
80
µA
10 -2
4
Version 1.3
SFH 3410
Directional Characteristics 1) page 12
Srel = f(ϕ)
40
30
ϕ
OHF01402
1.0
50
0.8
60
0.6
70
0.4
80
0.2
100
1.0
0.8
0.6
0.4
60
80
100
Package Outline
0.8 (0.031)
(not connected)
0.5 (0.020)
0.3 (0.012)
0.1 (0.004)
Emitter
1.1 (0.043)
0.9 (0.035)
1.7 (0.067)
0.3 (0.012)
0.2 (0.008)
0.0 (0.000)
2.1 (0.083)
1.9 (0.075)
GEOY6028
Dimensions in mm (inch).
Package
Smart DIL
2016-04-01
1.9 (0.075)
1.15 (0.045)
0.95 (0.037)
4.8 (0.189)
4.4 (0.173)
1.1 (0.043)
2.5 (0.098)
2.7 (0.106)
Collector
0.8 (0.031)
0.4 (0.016)
0.7 (0.028)
0.6 (0.024)
5
120
Version 1.3
SFH 3410
Approximate Weight:
12 mg
Recommended Solder Pad
2016-04-01
6
Version 1.3
SFH 3410
Reflow Soldering Profile
Product complies to MSL Level 4 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
s 300
250
t
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2016-04-01
°C
7
s
Version 1.3
SFH 3410
Taping
Tape and Reel
12 mm tape with 2000 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
2016-04-01
8
Version 1.3
SFH 3410
Tape dimensions [mm]
Tape dim ensions in m m
W
P0
12 + 0.3 / - 0.1 4 ± 0.1
P1
P2
D0
E
F
4 ± 0.1
or
8 ± 0.1
2 ± 0.05
1.5 ± 0.1
1.75 ± 0.1
5.5 ± 0.05
Reel dimensions [mm]
Reel dim ensions in m m
A
W
Nmin
W1
W2max
180
12
60
12.4 + 2
18.4
Barcode-Product-Label (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Dry Packing Process and Materials
Moisture-sensitive label or print
L
VE
el
LE
see
lab
e
If
ve
ati
nk,
bla cod
bar
y
H)
(R
dit
mi
hu
e
ed ag
RH
/60
Barcode label
˚C
rar ck
rel
30
N s VE RS
inf pa
ainITI TO
of
to ak
90
d
ntNSUC
ns
(pe
TIO
or
d
cte
itio
U g coSEND
an bje ing
˚C
nd
5
˚C su ss
CO
Ais baRE
co
ce
y
40 be
TU MI
CThIS
˚C
tor
ll pro
SE
_
urs
urs
Ho
de
urs
Ho
co
72
Ho urs
te
48
e
Ho
24 6
da
e
tim
e
th
tim
or
23
wi nt
tim e
or
l wi
fac
˚C
Flo
tim
at
or
ca
at
re.
Flo
d
tha ale el
or
nth
nti
Flo
uiv
du
if: rea
es
l 4 5
Flo
lab
mo
ide
ce
eq
low
g,
l
ve
vic
is
be
or
de
24
tin en
l 5a6
pro
ve
Le
de ,
e
te
co
g:
ve l
un wh
Le
ke
r
se
da
ure
ba ed low ba
Le ve
mo %
ba
e
al
d
ure
Le
ist
en ref e
e 10
tim
ure
se
for
ist
ale op se
for >
Mo
se
3
ist ure
is
or .
is ha
se
Mo
nk
be
ist
nk
g
rd
-03
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
kin Ca
life s
(if
ar
t.
wi
10 ba tor
J-S
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
Ye ee urs
Sh terlow tem ted at
ed
uir
1
W
no
un
DE
Ho
Af
Ind
1.
d
e
4 8
uir
ref dy
reqy is
2.
JE
bo
e
Mo ore
tim
16
req
C/
e
es dit2b
a)
St
tim
or
mi
IP
ed
or g is
tim e
vic
b)
or
e
Hu
Flo
en
tim
or
De
2a kin nc
te
Flo
a)
op
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a3
ve
Le
g
an
ve l
Le
Ba
te
ure
Le ve
ure
Le
ist
Da
ure
ist
Mo
ist ure
Mo
ist
Mo
Mo
MO
TO
OP
s
at
t
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
OSR
Desiccant
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet. Here you will also find the normative
references like JEDEC.
2016-04-01
9
Version 1.3
SFH 3410
Transportation Packing and Materials
Barcode label
D/
8
Y
M
DE
R
18
-1
P
-1
Q
C:
99
D/
21
00
(9
D)
21
14
2
5
(Q
)Q
TY
O
H
12
34
S S
em R
ic AM
on
du O
p
ct to
or
H
NO
s
TC
3G
BA
(6
P)
NO
: 12
11
00
LO
T
(1
T)
NO
TY
: 20
(Q
)Q
NO
M
RA
OS
(X
PR
O
D
5
14 2
110 0
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
195 ± 5
195 ± 5
30 ± 5
2016-04-01
OD
PR
(X
(G
G
RO
UP
P
-1
Q
-1
R
18
DE
M
Y
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
M
u L
lt S
iT Y
O T
P 67
L 6
E Bi
D Bi n1
00
C:
01
44
Muster
O
ct pto
o
rs
u
M
(9
D)
d
A
n
o
34
ic
S
R
NO
O
BA
TC
H
3G
H
(1
T)
LO
T
NO
(6
P)
S
8
12
2199
: 12
em
2100
01
44
el
OU
P:
L
GR
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur
s
d
ns
(p
or
ur
s
d
Ho
de
cteg
itio
ur s
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
e
40 be oc
ry
tim
˚C
e
r
th
ll pr
tim
cto
r
OI
oo
23
wi nt
tim e
at
l wi
fa
r
M TO
Fl
oo
tim
s
at
at ale ˚C at
e.
ica
Fl
th
oo r
th
ur
el
OP
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
l
oc
ve
vic
is
en
ing
be
or
de
24
l 5a6
pr
ve
Le
de
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo
Le ve
tu
re
m %
ba
e
ba
al
d
Le
r
en re
tu
re
e
re 10
ois
tim
se
fo
tu re
ale op se
fo >
M
r
se
ois
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
rd
g
M ois
in
r-p
bla
in Fl RH g,
DM
ba
po If blath
kin Ca
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
4 8
ou
re
ed
is
re
qu
ty
2.
JE
bo
e
M
or
tim
16
re C/
e
es idi 2b
r
a)
St
tim
mor
is IP
ed
r
oo
tim e
vic
b)
g e
r
Hu
Fl
en
oo
tim
De
2a kin nc
te
Fl
oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1 2
Fl
If
al
re
tim ve
l
4.
se
d
l 2a3
ve
Le
g
an
ve l
Le
re
Ba
te
Le ve
tu
re
Le
tu
Da ois
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E Bi
D Bi n1
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
10
OHA02044
Version 1.3
SFH 3410
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-04-01
11
Version 1.3
SFH 3410
Glossary
1)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-04-01
12
Version 1.3
SFH 3410
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-04-01
13
