BPX38-3
BPX38-3
    AMSOSRAM(艾迈斯半导体)
    TO18-3
    PHOTOTRANSISTORNPN880NMTO-18
BPX38-3 数据手册
2016-01-04 Silicon NPN Phototransistor Version 1.3 BPX 38 Features: • Spectral range of sensitivity: (typ) 450 ... 1120 nm • Package: Metal Can (TO-18), hermetically sealed • Special: Base connection • Suitable up to 125 °C • High linearity • Available in groups Applications • Photointerrupters • Industrial electronics • For control and drive circuits Ordering Information Type: Photocurrent Ordering Code IPCE [µA] λ = 950 nm, Ee = 0.5 mW/cm2, VCE = 5 V BPX 38 ≥ 200 Q62702P0015 BPX 38-2/3 200 ... 630 Q62702P3578 BPX 38-3 320 ... 630 Q62702P0015S003 BPX 38-4 500 ... 1000 Q62702P0015S004 Note: Only one bin within one packing unit (variation less than 2:1) 2016-01-04 1 Version 1.3 BPX 38 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 125 °C Collector-emitter voltage VCE 50 V Collector current IC 50 mA Collector surge current (τ < 10 µs) ICS 200 mA Emitter-base voltage VEB 7 Total Power dissipation Ptot 220 mW Thermal resistance RthJA 450 K/W V Characteristics (TA = 25 °C) Parameter Symbol Values Unit 880 nm Wavelength of max. sensitivity (typ) λS max Spectral range of sensitivity (typ) λ10% Radiant sensitive area (typ) A 0.675 mm2 Dimensions of chip area (typ) LxW (typ) 1.02 x 1.02 mm x mm Half angle (typ) ϕ ± 40 ° Photocurrent of collector-base photodiode (λ = 950 nm, Ee = 0.5 mW/cm2, VCB = 5 V) (typ) IPCB 1.8 μA Photocurrent of collector-base photodiode (EV = 1000 lx, Std. Light A, V CB = 5 V) (typ) IPCB 5.5 μA Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE 23 pF Capacitance (VCB = 0 V, f = 1 MHz, E = 0) (typ) CCB 39 pF Capacitance (VEB = 0 V, f = 1 MHz, E = 0) (typ) CEB 47 pF Dark current (VCE = 25 V, E = 0) (typ (max)) ICE0 20 (≤ 100) nA 2016-01-04 2 (typ) 450 ... 1120 nm Version 1.3 BPX 38 Grouping (TA = 25 °C, λ = 950 nm) Group Min Photocurrent Max Photocurrent Typ Photocurrent Rise and fall time Ee = 0.5 mW/cm2, VCE = 5 V Ee = 0.5 mW/cm2, VCE = 5 V EV = 1000 lx, Std. Light A, VCE = 5 V IC = 1 mA, VCC = 5 V, RL = 1 kΩ IPCE, min [µA] IPCE, max [µA] IPCE [µA] tr, tf [µs] BPX 38-2 200 400 950 9 BPX 38-3 320 630 1500 12 BPX 38-4 500 1000 2300 15 BPX 38-5 800 3600 18 Group Collector-emitter saturation voltage Current gain IC = IPCEmin x 0.3, Ee= 0.5 mW/cm2 Ee = 0.5 mW/cm2, VCE = 5 V VCEsat [mV] IPCE / IPCB BPX 38-2 200 170 BPX 38-3 200 280 BPX 38-4 200 420 BPX 38-5 200 650 Note.: IPCEmin is the min. photocurrent of the specified group. 2016-01-04 3 Version 1.3 BPX 38 Relative Spectral Sensitivity 1) page 9 Srel = f(λ) Photocurrent 1) page 9 IPCE = f(Ee), VCE = 5 V Collector Current 1) page 9 IC = f(VCE), IB = Parameter Collector Current 1) page 9 IC = f(VCE), IB = Parameter 2016-01-04 4 Version 1.3 BPX 38 Photocurrent 1) page 9 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Dark Current 1) page 9 ICEO = f(VCE), E = 0 Dark Current 1) page 9 ICEO/ICEO(25°) = f(TA), VCE = 25 V, E = 0 Collector-Base Capacitance 1) page 9 CCB = f(VCB), f = 1 MHz, E = 0 2016-01-04 5 Version 1.3 BPX 38 Collector-Emitter Capacitance 1) page 9 CCE = f(VCE), f = 1 MHz, E = 0 Emitter-Base Capacitance 1) page 9 CEB = f(VEB), f = 1 MHz, E = 0 Power Consumption Ptot = f(TA) 2016-01-04 6 Version 1.3 BPX 38 Directional Characteristics 1) page 9 Srel = f(ϕ) Package Outline 1.1 3) ) 35 .0 (0 .04 (0 0.9 14.5 (0.571) 5.3 (0.209) 12.5 (0.492) 5.0 (0.197) 5.5 (0.217) E C B 2.54 (0.100) spacing 0.9 1.1 ø4.6 (0.181) ø0.45 (0.018) ø4.8 (0.189) (2.7 (0.106)) (0 . (0 043 .03 ) 5) Radiant sensitive area Chip position ø5.6 (0.220) ø5.3 (0.209) 5.0 (0.197) Approx. weight 1.0 g GMOY6018 Dimensions in mm (inch). Package Metal Can (TO-18), hermetically sealed 2016-01-04 7 Version 1.3 BPX 38 Approximate Weight: 0.28 g TTW Soldering IEC-61760-1 TTW OHA04645 300 10 s max., max. contact time 5 s per wave ˚C T 250 235 ˚C - 260 ˚C First wave Second wave Continuous line: typical process Dotted line: process limits ∆T < 150 K 200 Cooling Preheating ca. 3.5 K/s typical 150 ca. 2 K/s 130 ˚C 120 ˚C 100 ˚C 100 ca. 5 K/s Typical 50 0 0 20 40 60 80 100 120 140 160 180 200 220 s 240 t Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-01-04 8 Version 1.3 BPX 38 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2016-01-04 9 Version 1.3 BPX 38 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-01-04 10
BPX38-3
物料型号:BPX 38
器件简介:该光晶体管具有高线性、适合在125°C下使用,并且具有基极连接。它适用于光中断器、工业电子以及控制和驱动电路。
引脚分配:文档中未明确提供引脚分配信息,但通常TO-18封装的光晶体管有三个引脚:发射极(E)、基极(B)和集电极(C)。
参数特性:包括工作和存储温度范围(-40°C至125°C)、集电极-发射极电压(VCE最大50V)、集电极电流(Ic最大50mA)、集电极脉冲电流(Ics最大200mA)、发射极-基极电压(VEB 7V)、总功率耗散(Ptot最大220mW)和热阻(RthJA 450 K/W)。
功能详解:文档提供了光电流、暗电流、电容等参数的典型值和最大值,以及在不同条件下的特性,例如在不同温度和辐射强度下的表现。
应用信息:适用于光中断器、工业电子设备,以及控制和驱动电路。
封装信息:采用金属罐(TO-18)封装,并且是密封的。提供了封装的尺寸和重量信息。
BPX38-3 价格&库存
很抱歉,暂时无法提供与“BPX38-3”相匹配的价格&库存,您可以联系我们找货
