SDP2000-L
SDP2000-L
    SENSIRION(盛思锐)
    Module
    1-100113-03 SDP2000-L
SDP2000-L 数据手册
Datasheet SDP2000-L Differential Pressure Sensor with Analog Output  Calibrated and temperature compensated  Excellent repeatability, no drift Product Summary The SDP2000-L differential pressure sensor for air covers a measurement range of 3500 Pa (14 inch H2O). Mounted in a PPS housing the SDP2000-L differential pressure sensor features a unique dynamic range, zero offset and unsurpassed long term stability. This makes it an ideal fit for demanding yet cost sensitive OEM applications in HVAC and medical equipment. The device is supplied with 5 V and provides a 0.25…4 V output. Although the output of the SDP2000-L differential pressure sensor is analog, the internal linearization and temperature compensation is performed digitally. This results in superior accuracy, outstanding resolution, and lowest temperature dependence. The outstanding performance of the sensor is based on Sensirion’s patented CMOSens® sensor technology, which combines the sensor element, signal processing and digital calibration on a small CMOS chip. The differential pressure is measured by a thermal sensor element using flow-through technology. The well-proven CMOS technology is perfectly suited for high-quality mass production and is the ideal choice for demanding and cost-sensitive OEM applications. Benefits of Sensirion’s CMOSens® Technology      High reliability and long-term stability Best signal to noise ratio Industry-proven technology with a track record of more than 15 years Designed for mass production High process capability Content 1. Sensor Performance............................................................... 2 2. Electrical Specifications .......................................................... 4 3. Physical Dimensions and Mounting Information ..................... 5 4. Shipping Package .................................................................. 7 5. Ordering Information............................................................... 7 Revision History .............................................................................. 7 Important Notices ............................................................................ 8 Headquarters and Subsidiaries ....................................................... 8 www.sensirion.com Version 1 – April 2017 1/8 Datasheet SDP2000-L 1. Sensor Performance Table 1: Sensor specifications (at 23°C and Pabsolute = 966 mbar, VDD = 5.0 V unless otherwise noted) SDP2000-L Parameter Measurement range Min Typ Unit Max -100 3500 Pa -0.4 14 Inch water 0 3500 Pa 5.25 V Calibrated range Power supply 4.75 5.00 Full scale output (100 k load) 4.00 V Zero Pressure Output 0.250 V 0.1 0.2 % FS (1) 1 1.5 % m.v. (2) Repeatability 0.3 0.5 % m.v. (2) Offset stability 0 0.3 Pa / year Additional error over temperature (T ≠ 23°C) 0 0 % FS/°C 0.03 0.05 % m.v./°C 0.2 0.5 1 Pa 1 2.5 8 Pa 8 11 14 Pa Accuracy Resolution < 30% FS(1) Resolution 30..70% Resolution > 70% (1) (2) FS(1) FS(1) FS = full scale or span. For the SDP2000-L it is 3500 Pa m.v. = measured value, i.e. reading Table 2: Additional sensor specifications (1) Media Air, N2 – for other gases contact Sensirion. Operating Conditions: - Temperature - Humidity -10 °C … +60 °C / 14°F … 140 °F non-condensing Ambient storage conditions(1) -40 °C … +80 °C / -40°F … 176 °F Orientation sensitivity below resolution Response time 40 ms Admissible overpressure (short term) 1 bar (14.5 PSI) Burst Pressure Capability 2 bar (29 PSI) Weight 14 g Protection Class IP 20 Wetted materials Glass (silicon nitride, silicon oxide), Silicon, PPS (Polyphenylene Sulfide), PEEK (Polyetheretherketone), FR4, Silicone as static sealing, Epoxy, Gold Gas flow through sensor see Figure 4 REACH and RoHS REACH and RoHS compliant For maximum 2 weeks www.sensirion.com Version 1 – April 2017 2/8 Datasheet SDP2000-L 1.1 Temperature Compensation The SDP2000-L differential pressure sensor features a sophisticated built-in temperature compensation circuit. The temperature is measured on the CMOSens chip by means of a bandgap reference temperature sensor. Its data is fed into a compensation circuit which is also integrated on the CMOSens ® sensor chip. No external temperature compensation is therefore required. 1.2 Altitude Correction The SDP2000-L differential pressure sensor achieves its unsurpassed performance by using a dynamic measurement principle, i.e. an applied differential pressure forces a small air flow through the sensor. This results in a dependence of the indicated differential pressure on the ambient air density. While the temperature effect is compensated (see Paragraph 1.1) the altitude above sea level has an influence on the SDP2000-L output. If desired, this effect can be compensated by a correction factor according to the following equation: Dpeff = Dpsensor * Pcal / Pamb where Dpeff is the effective differential pressure, Dpsensor the differential pressure indicated by the SDP2000-L, Pcal the absolute pressure during calibration (966 mbar) and Pamb the actual ambient absolute pressure. Note: For more detailed information about temperature and pressure compensation, refer to the selection guide in the differential pressure download center on the Sensirion website. www.sensirion.com Version 1 – April 2017 3/8 Datasheet SDP2000-L 2. Electrical Specifications 2.1 Power Supply The SDP2000-L differential pressure sensor requires a stable voltage supply of 5V. Influence of the supply voltage variation on the offset and the sensitivity are given in Table 4 2.2 Voltage Output The SDP2000-L features a voltage output from 0.25V to 4.0V (Figure 1). An output voltage below 0.25V indicates a negative differential pressure. This range is not calibrated however. The resistive load at the output pin should be larger than 20kOhm. The capacitive load at the output pin must not be larger than 200pF. If the design shows a larger capacity at the output pin an additional resistor is required in series at the output (e.g. 620Ohm). 4.00 output voltage [V] 3.00 Formula: P = lfactor * (voltage(1) – 0.250)/3.750 lfactor = Pascal Inch water 2.00 1.00 (1) 3500 14 voltage: measured output voltage in Volt. 0.00 0 20 40 60 80 100 differential pressure [% full scale] Figure 1: Linear output at 5V supply of the SDP2000-L. The fine lines indicate the maximum tolerances including a temperature variation from 0 to 50°C. Table 3: Electrical characteristics Parameter Conditions Min. Power Supply Voltage VDD Operating Current 4.75 5 V, no load, zero flow Output capacitive load Cload Recommended load Rload To GND 20 Typ. Max. Units 5.0 5.25 VDC 4.3 5.2 mA 20 200 pF 100  k Table 4: Typical power supply dependence of the offset and the sensitivity Parameter 4.75 V Offset - 10.3 Sensitivity 1.01 www.sensirion.com Version 1 – April 2017 5.0 V 1.07 5.25 V Units + 10.3 Pa 1.13 mV/Pa 4/8 Datasheet SDP2000-L 3. Physical Dimensions and Mounting Information 3.1 Housing The SDP2000-L differential pressure sensor is mounted in a PPS housing. The package has been designed to withstand continuous overpressures of at least 1 bar (14.5 PSI). Burst pressure is > 2 bar (29 PSI) The physical dimensions and mounting information is given in Figure 2 and Figure 3. Pin# Function 1 2 3 VDD (5V) Ground OUT (0.25…4V) Figure 2: Pin out and physical dimensions in mm (inch). The drawing is not to scale www.sensirion.com Version 1 – April 2017 5/8 Datasheet SDP2000-L Dim. A B C D E F G H I [mm] 3.00 3.30 1.20 10.20 28.20 2.54 0.60 0.50 22.70 [inch] 0.118 0.130 0.047 0.402 1.110 0.100 0.024 0.020 0.894 [mil] 118 130 47 402 1110 100 24 20 894 Figure 3: SDP2000-L PCB footprint. The drawing is not to scale 3.2 Soldering Instructions The SDP2000-L differential pressure sensor can be wave soldered. Direct reflow soldering is not recommended since it may affect the accuracy. If reflow soldering is required Sensirion recommends to use an SMD connector (e.g. type Samtec SSM103-L-SV) and to mount the SDP2000-L after soldering. 3.3 Connecting Hose Sensirion recommends a hose with an inner diameter of 1/8 to 3/20 inch (3.18 to 3.8mm). Due to the dynamic measurement principle, a small air flow is required (Figure 4) which leads to a dependence on the length of the hose (Figure 5). Tubes up to 1 m show less than 1 % error of the measured value. gas flow [sccm] 120 100 80 60 40 20 0 0 50 Length of the connecting hose 0.5 m (20 inch) Deviation of Measured Value - 0.4 % 1.0 m (40 inch) - 0.8 % 2.0 m (80 inch) - 1.6 % 4.0 m (160 inch) - 3.2 % 100 differential pressure [% full scale] Figure 4: Typical air flow through the SDP2000-L. Please note: 1 sccm = 1 cm3/min at 0°C and 1013 mbar pressure (1 sccm = 0.001 norm liter) www.sensirion.com Figure 5: Influence of the length of the connecting hose on the accuracy (using 3/16 inch inner diameter). Example: a 50 Pa difference pressure is shown as 49.8 Pa when using 0.5 m tube with 3/16 inch diameter Version 1 – April 2017 6/8 Datasheet SDP2000-L 4. Shipping Package SDP2000-L is shipped in trays of 25pcs. 5. Ordering Information Use the part names and item numbers shown in the following table when ordering SDP2000-L differential pressure sensor. For the latest product information and local distributors, visit www.sensirion.com. Part name Description / Output Product number SDP2000-L 3500Pa, Analog linear voltage output 1-100113-03 Revision History Date Author Version Changes April 2017 ANB www.sensirion.com 1 Separate datasheet for SDP2000-L. Specifications are unchanged. Version 1 – April 2017 7/8 Datasheet SDP2000-L Important Notices  Warning, personal injury Do not use this product as safety or emergency stop devices or in any other application where failure of the product could result in personal injury (including death). Do not use this product for applications other than its intended and authorized use. Before installing, handling, using or servicing this product, please consult the datasheet and application notes. Failure to comply with these instructions could result in death or serious injury. If the Buyer shall purchase or use SENSIRION products for any unintended or unauthorized application, Buyer shall defend, indemnify and hold harmless SENSIRION and its officers, employees, subsidiaries, affiliates and distributors against all claims, costs, damages and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if SENSIRION shall be allegedly negligent with respect to the design or the manufacture of the product. ESD Precautions The inherent design of this component causes it to be sensitive to electrostatic discharge (ESD). To prevent ESD-induced damage and/or degradation, take customary and statutory ESD precautions when handling this product. See application note “Handling Instructions” for more information. Warranty SENSIRION warrants solely to the original purchaser of this product for a period of 12 months (one year) from the date of delivery that this product shall be of the quality, material and workmanship defined in SENSIRION’s published specifications of the product. Within such period, if proven to be defective, SENSIRION shall repair and/or replace this product, in SENSIRION’s discretion, free of charge to the Buyer, provided that:  notice in writing describing the defects shall be given to SENSIRION within fourteen (14) days after their appearance;   such defects shall be found, to SENSIRION’s reasonable satisfaction, to have arisen from SENSIRION’s faulty design, material, or workmanship; the defective product shall be returned to SENSIRION’s factory at the Buyer’s expense; and the warranty period for any repaired or replaced product shall be limited to the unexpired portion of the original period. This warranty does not apply to any equipment which has not been installed and used within the specifications recommended by SENSIRION for the intended and proper use of the equipment. EXCEPT FOR THE WARRANTIES EXPRESSLY SET FORTH HEREIN, SENSIRION MAKES NO WARRANTIES, EITHER EXPRESS OR IMPLIED, WITH RESPECT TO THE PRODUCT. ANY AND ALL WARRANTIES, INCLUDING WITHOUT LIMITATION, WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, ARE EXPRESSLY EXCLUDED AND DECLINED. SENSIRION is only liable for defects of this product arising under the conditions of operation provided for in the datasheet and proper use of the goods. SENSIRION explicitly disclaims all warranties, express or implied, for any period during which the goods are operated or stored not in accordance with the technical specifications. SENSIRION does not assume any liability arising out of any application or use of any product or circuit and specifically disclaims any and all liability, including without limitation consequential or incidental damages. All operating parameters, including without limitation recommended parameters, must be validated for each customer’s applications by customer’s technical experts. Recommended parameters can and do vary in different applications. SENSIRION reserves the right, without further notice, (i) to change the product specifications and/or the information in this document and (ii) to improve reliability, functions and design of this product. Copyright © 2017, SENSIRION. CMOSens® is a trademark of Sensirion All rights reserved Headquarters and Subsidiaries SENSIRION AG Laubisruetistr. 50 CH-8712 Staefa ZH Switzerland Sensirion Inc., USA phone: +1 312 690 5858 info-us@sensirion.com www.sensirion.com Sensirion Korea Co. Ltd. phone: +82 31 337 7700~3 info-kr@sensirion.com www.sensirion.co.kr phone: +41 44 306 40 00 fax: +41 44 306 40 30 info@sensirion.com www.sensirion.com Sensirion Japan Co. Ltd. phone: +81 3 3444 4940 info-jp@sensirion.com www.sensirion.co.jp Sensirion China Co. Ltd. phone: +86 755 8252 1501 info-cn@sensirion.com www.sensirion.com.cn Sensirion Taiwan Co. Ltd. phone: +41 44 306 40 00 info@sensirion.com To find your local representative, please visit www.sensirion.com/contact www.sensirion.com Version 1 – April 2017 8/8
SDP2000-L 价格&库存
很抱歉,暂时无法提供与“SDP2000-L”相匹配的价格&库存,您可以联系我们找货
