SDP36-500PA-TR-250PCS 数据手册
Datasheet SDP3x-Analog
Differential Pressure Sensor with Analog Output
Smallest size enables portable applications
Reflow solderable – Pick & Place
Configurable analog output
Calibrated and temperature compensated
Excellent repeatability, no drift
Product Summary
The SDP3x sensor family is Sensirion’s series of small differential pressure sensors designed for high-volume applications
where size is a key requirement. It builds on the next generation CMOSens® sensor chip that is at the heart of Sensirion’s
new differential pressure and flow sensing platform.
The analog SDP3x sensors offer a calibrated and temperature compensated analog voltage output. The output signal is
configurable: different measurement speeds, output curves and temperature compensations can be selected – even
dynamically during operation mode.
Benefits of Sensirion’s CMOSens® Technology
High reliability and long-term stability
Best signal to noise ratio
Industry-proven technology with a track record of more
than 15 years
Designed for mass production
High process capability
Content
1.
Sensor Performance .............................................................. 2
2.
Specifications ......................................................................... 3
3.
Pin Assignment ...................................................................... 4
4.
Package Outline..................................................................... 6
5.
Soldering................................................................................ 7
6.
Shipping Package .................................................................. 8
7.
Ordering Information .............................................................. 8
Revision History.............................................................................. 8
Important Notices ........................................................................... 9
Headquarters and Subsidiaries ...................................................... 9
www.sensirion.com
Version 1 – December 2017
1/9
1. Sensor Performance
1.1
Differential Pressure Specification1
Parameter
Measurement range 2
Configuration
Linear
Square Root
Zero point accuracy 3,4,5
Span accuracy 3,4,5
Zero point repeatability 4,5
Span repeatability 4,5
Span shift due to temperature
variation
Offset stability
Response time (τ63)
Internal digital resolution
Calibrated for
Media compatibility
Calibrated temperature range
SDP36
- 50 to 500 Pa
SDP37
- 12.5 to 125 Pa
(-0.2 to 2 inH2O)
(-0.05 to 0.5 inH2O)
- 500 to 500 Pa
- 125 to 125 Pa
(- 2 to 2 inH2O)
(- 0.5 to 0.5 inH2O)
0.1 Pa 5
3% of reading 5
0.03 Pa 5
0.5% of reading 5
0.08 Pa 5
3% of reading 5
0.025 Pa 5
0.5% of reading 5
< 0.5% of reading per 10°C
< 0.01 Pa/year
< 0.01 Pa/year
Slow
< 9 ms
Fast
< 5 ms
16 bit
Air, N2
Air, N2, O2, non-condensing
-40 °C to +85 °C
1
Unless otherwise noted, all sensor specifications are valid at 25°C with VDD = 3.3 V and absolute pressure = 966 mbar.
For other pressure ranges contact Sensirion
3 Includes repeatability
4 Total accuracy/repeatability is a sum of zero-point and span accuracy/repeatability.
5 Output voltage integral non linearity and output voltage noise are not included and defined later in chapter 2.1. Note that the effect of output voltage
integral non linearity and output voltage noise on accuracy is highly dependent on the output configuration (linear or square root).
2
www.sensirion.com
2/9
2. Specifications
2.1
Electrical Specifications
Parameter
Symbol
Supply
Supply Voltage
VDD
Power-up/down level
VPOR
Supply current
IDD
Ratiometric analog voltage output
Output range
Resistive load to GND
Resistive load to VDD
Capacitive load
Cload
Output voltage Integral
Non Linearity (INL)
Output voltage noise
(RMS)
2.2
Power-up time
Max.
Units
2.7
2.3
3.3
2.5
3.8
5.5
2.7
5.5
V
V
mA
90%
100
VDD
kOhm
kOhm
nF
5
mV
10%
10 1
1000
100
0.5
Comments
mV
Symbol
Condition
Min.
Typ.
tPU
Max.
Units
25
ms
Max.
Units
bar
bar
g
Comments
Time to first reliable
measurement
Symbol
Pmax
Pburst
W
Condition
Min.
Typ.
1
3
0.2
Comments
Materials
Parameter
Wetted materials
REACH, RoHS
2.5
Typ.
Mechanical Specifications
Parameter
Allowable overpressure2
Rated burst pressure
Weight
2.4
Min.
Timing Specifications
Parameter
2.3
Condition
glass (silicon nitride, silicon oxide), LCP, green epoxy-based mold compound, epoxy-based resins
REACH and RoHS compliant
Absolute Maximum Ratings
Parameter
Supply Voltage VDD
Max Voltage on pins (Inputs)
Input current on any pin
Operating temperature range3
Storage temperature range4
Max. humidity for long term exposure
ESD HBM (human body model)
Rating
-0.3 to 5.5
-0.3 to VDD+0.3
±70
-40 to +85
-40 to +85
40°C dew point
2
Units
V
V
mA
°C
°C
kV
1
For a resistive load to GND less than 100kOhm a 1nF capacitor to GND on the AOUT is recommended
Allowable overpressure during operation. Refer to the SDP selection guide for pressure dependency of the measured signal. Fast absolute pressure
changes on both ports can result in dynamic effects on the sensor signal. For higher overpressures or continuous high overpressures contact Sensirion.
3 For Air and N2. Long term exposure to high temperatures and (high concentrations of) O2 can reduce the product lifetime
4 For long term storage in Tape and Reel refer to the SDP3x handling instructions
2
www.sensirion.com
3/9
3. Pin Assignment
The SDP3x consists of a QFN package with a plastic cap covering the top and providing the pneumatic connections to the
sensor. Table 1 shows the pin assignments of the SDP3x-Analog sensor.
Pin no. Name Description
1
GND
Connect to ground
2
GND
Connect to ground
3
GND
Connect to ground
4
BWS Bandwidth selection input
5
TCS
Temperature compensation selection input
6
GND
Connect to ground
7
VDD
VDD Supply
8
OCS
Output curve selection input
9
AOut Ratiometric analog voltage output
10
GND
Connect to ground
11
GND
Connect to ground
12-16
Reserved. Do not connect
Table 1: SDP3x-Analog pin assignment (bottom view).
3.1
Power Pins (VDD, GND)
The power supply pins must be decoupled with a 100 nF capacitor that shall be placed as close to the sensor as possible.
3.2
Config.
OCS: Output Curve Selection Input
Polarity Description
Conversion to physical values
AOut[V], VDD[V], Differential Pressure (DP) [Pa]
Analog output is configured as a linear
output. The sensor is not fully bidirectional in this configuration: -10% full- SDP36
(500Pa)
scale to 100% full scale.
Linear
𝐷𝑃 =
750 ∙ 𝐴𝑂𝑢𝑡
− 150
𝑉𝐷𝐷
𝐷𝑃 =
190 ∙ 𝐴𝑂𝑢𝑡
− 38
𝑉𝐷𝐷
Low
(GND)
SDP37
(125Pa)
Analog output is a fully bi-directional
output with square root conversion. The
2
benefits are that the bidirectional output SDP36
𝐴𝑂𝑢𝑡
𝐴𝑂𝑢𝑡
𝐷𝑃
𝑠𝑖𝑔𝑛
0.5)
1.25)
∙ 525
has a more stable zero point and higher (500Pa)
𝑉𝐷𝐷
𝑉𝐷𝐷 ∙ 0.4
sensitivity at lower pressures
Square High
Root
(VDD)
SDP37
(125Pa)
www.sensirion.com
2
𝐴𝑂𝑢𝑡
𝐴𝑂𝑢𝑡
𝐷𝑃 = 𝑠𝑖𝑔𝑛 (
− 0.5) ∙ (
− 1.25) ∙ 133
𝑉𝐷𝐷
𝑉𝐷𝐷 ∙ 0.4
4/9
3.3
TCS: Temperature Compensation Selection Input
Configuration
Polarity
Description
Temperature
Low (GND)
In this configuration temperature compensation is optimized for applications where
compensation for
mass flow measurements in bypass are performed
mass flow
Temperature
High (VDD)
In this configuration the analog output signal is temperature compensated for
compensation for
differential pressure. This configuration is recommended for applications where real
differential pressure measurements are required.
For more information about temperature compensation for differential pressure sensors, for example volume flow
measurements in bypass, refer to the selection guide in the differential pressure download center on our website.
3.4
BWS: Bandwidth Selection Input
Configuration
Fast
Polarity
Low (GND)
Slow
High (VDD)
3.5
Description
In this configuration the chip will output the differential pressure value on the analog
output with the highest possible bandwidth and lowest latency. This configuration is
recommended to be used in use cases where small changes need to be detected
as quickly as possible.
The response time in this configuration is less than 5ms
In this configuration extra averaging is in place in order to achieve an excellent
signal to noise ratio.
The response time in this configuration is less than 9ms
AOut Pin
The AOut pin gives out an analog ratiometric voltage, representing the measured differential pressure value. Please note the
resistive and capacitive loads as mentioned in section 2.1.
Formulas for converting AOut [V] to differential pressure [Pa] can be found in section 3.2.
3.6
Die Pad (Center Pad)
The die pad or center pad is visible from below and located in the center of the package. It is internally connected to GND and
therefore there are no electrical constraints on connecting or not connecting the die pad to GND. For mechanical stability it is
recommended to solder the center pad to the PCB.
The hole in the middle of the die pad must stay open during and after soldering.
www.sensirion.com
5/9
4. Package Outline
Figure 1: SDP3x. All dimensions in mm.
www.sensirion.com
6/9
5.
Soldering
Recommended land pattern
The solder mask is understood to be the insulating layer on top of the PCB covering the copper traces. It is recommended to
design the land pattern as a Non- Solder Mask Defined (NSMD) type.
Recommended stencil aperture
The sensor must enter the reflow process only once and with a minimal temperature and exposure time. When both sides of
the PCB are reflow soldered or multiple reflow runs are required, the sensor must be soldered in the last soldering run. In any
case the temperature should not exceed 260°C; temperatures above 200°C should be limited in time to a maximum of 150
seconds.
Ensure that the ports of the sensor are well protected during assembly and soldering so that no dust, solder flux or other
liquids can enter the flow channel. In no case, a board wash shall be applied. It is strongly recommended to use “no-clean”
solder paste.
It is important to note that the diced edge or side faces of the I/O pads may oxidize over time, therefore a solder fillet may or
may not form. Hence there is no guarantee for solder joint fillet heights of any kind.
Refer to the SDP3x handling instructions on our website for more details.
www.sensirion.com
7/9
6. Shipping Package
SDP3x are provided in tape & reel shipment packaging. Standard packaging size is 1500 or 250 units per reel. The drawing of
the packaging tapes with sensor orientation is shown in Figure 2.
Figure 2: Packaging tape and sensor orientation. Header tape is to the right and trailer tape to the left on this drawing
7. Ordering Information
Use the part names and product numbers shown in the following table when ordering SDP3x differential pressure sensor. For
the latest product information and local distributors, visit www.sensirion.com.
Part name Description / Output
SDP36
Analog, 500Pa
SDP37
Analog, 125Pa
Product number
Packaging
Tape & Reel size
1-101471-02
Tape & Reel (QFN Quad 2 configuration)
1500
1-101571-02
250
1-101497-02
1500
1-101572-02
250
Revision History
Date
Author Version Changes
14.12.2017 ANB
www.sensirion.com
V1
Released. Chip revision update. Product numbers updated. Voltage
range extended. Operating temperature extended. TCS now
available.
8/9
Important Notices
Warning, personal injury
Do not use this product as safety or emergency stop devices or in
any other application where failure of the product could result in
personal injury (including death). Do not use this product for
applications other than its intended and authorized use. Before
installing, handling, using or servicing this product, please
consult the datasheet and application notes. Failure to comply
with these instructions could result in death or serious injury.
If the Buyer shall purchase or use SENSIRION products for any
unintended or unauthorized application, Buyer shall defend, indemnify
and hold harmless SENSIRION and its officers, employees,
subsidiaries, affiliates and distributors against all claims, costs,
damages and expenses, and reasonable attorney fees arising out of,
directly or indirectly, any claim of personal injury or death associated
with such unintended or unauthorized use, even if SENSIRION shall be
allegedly negligent with respect to the design or the manufacture of the
product.
ESD Precautions
The inherent design of this component causes it to be sensitive to
electrostatic discharge (ESD). To prevent ESD-induced damage and/or
degradation, take customary and statutory ESD precautions when
handling this product.
See application note “Handling Instructions” for more information.
Warranty
SENSIRION warrants solely to the original purchaser of this product for
a period of 12 months (one year) from the date of delivery that this
product shall be of the quality, material and workmanship defined in
SENSIRION’s published specifications of the product. Within such
period, if proven to be defective, SENSIRION shall repair and/or
replace this product, in SENSIRION’s discretion, free of charge to the
Buyer, provided that:
notice in writing describing the defects shall be given to
SENSIRION within fourteen (14) days after their appearance;
such defects shall be found, to SENSIRION’s reasonable
satisfaction, to have arisen from SENSIRION’s faulty design,
material, or workmanship;
the defective product shall be returned to SENSIRION’s factory at
the Buyer’s expense; and
the warranty period for any repaired or replaced product shall be
limited to the unexpired portion of the original period.
This warranty does not apply to any equipment which has not been
installed and used within the specifications recommended by
SENSIRION for the intended and proper use of the equipment.
EXCEPT FOR THE WARRANTIES EXPRESSLY SET FORTH
HEREIN, SENSIRION MAKES NO WARRANTIES, EITHER EXPRESS
OR IMPLIED, WITH RESPECT TO THE PRODUCT. ANY AND ALL
WARRANTIES, INCLUDING WITHOUT LIMITATION, WARRANTIES
OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR
PURPOSE, ARE EXPRESSLY EXCLUDED AND DECLINED.
SENSIRION is only liable for defects of this product arising under the
conditions of operation provided for in the datasheet and proper use of
the goods. SENSIRION explicitly disclaims all warranties, express or
implied, for any period during which the goods are operated or stored
not in accordance with the technical specifications.
SENSIRION does not assume any liability arising out of any application
or use of any product or circuit and specifically disclaims any and all
liability, including without limitation consequential or incidental damages.
All operating parameters, including without limitation recommended
parameters, must be validated for each customer’s applications by
customer’s technical experts. Recommended parameters can and do
vary in different applications.
SENSIRION reserves the right, without further notice, (i) to change the
product specifications and/or the information in this document and (ii) to
improve reliability, functions and design of this product.
Copyright © 2016-2017, SENSIRION.
CMOSens® is a trademark of Sensirion
All rights reserved
Sensirion AG
Laubisruetistr. 50
CH-8712 Staefa ZH
Switzerland
Sensirion Inc., USA
phone: +1 312 690 5858
info-us@sensirion.com
www.sensirion.com
Sensirion Korea Co. Ltd.
phone: +82 31 337 7700~3
info-kr@sensirion.com
www.sensirion.co.kr
phone: +41 44 306 40 00
fax:
+41 44 306 40 30
info@sensirion.com
www.sensirion.com
Sensirion Japan Co. Ltd.
phone: +81 3 3444 4940
info-jp@sensirion.com
www.sensirion.co.jp
Sensirion China Co. Ltd.
phone: +86 755 8252 1501
info-cn@sensirion.com
www.sensirion.com.cn
Sensirion Taiwan Co. Ltd
phone: +886 3 5506701
info@sensirion.com
www.sensirion.com
To find your local representative, please visit www.sensirion.com/distributors
www.sensirion.com
9/9
