A Global Leader in the Design, Development, and
Manufacture of Sensor and Magnetic Components
www.standexmeder.com
Series Datasheet – LS01 Level Sensors
LS01 Series
Level Sensors
Features: Compact Single Level Vertical Mount LS, High Power Switch Option, Other Cables & Connectors
Applications: Level Control, Detection and Monitoring
Markets: Automotive, Appliance, HVAC/R, Test & Measurement
LS-01 0X00-XX-000X
Part-Description:
Contact QTY
Contact Form
Switch Model
Material
Cable Length
(mm)
Cable
Termination
01
A (SPST-NO)
B (SPST-NC)
66, 85
PA, PP
500, 1,000,
5,000
W = Stripped
and Tinned
Customer Options
Contact Data
66
85
Rated Power (max.)
10
100
W
200
400
V
0.5
1.0
A
1.25
2.5
A
150
150
mOhm
Switch Model
Any DC combination of V&A not to exceed their individual max.’s
Switching Voltage (max.)
DC or peak AC
Switching Current (max.)
DC or peak AC
Carry Current (max.)
DC or peak AC
Contact Resistance (max.)
@ 0.5V & 10mA
Unit
Glossary Material
Glossary Contact Form
Form A
NO = Normally Open Contacts
SPST = Single Pole Single Throw
PP: Polypropylene
Form B
NC = Normally Closed Contacts
Form C
Changeover
SPDT = Single Pole Double Throw
PA: Polyamide
NBR: Nitrile
Butadiene Rubber
For water applications
and dilute acids
For oil
For oil, gasoline & in
high temperatures
SS: Stainless Steel
For high temp. (< 160° C)
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
│ salesusa@standexmeder.com
│ info@standexmeder.com
│ salesasia@standexmeder.com
Modifications in the sense of technical progress are reserved.
Version 01
27.01.2015
LS01 Level Sensor
General Sensor Data
Materials
Stem, nut
PA
Float
PA
Seal
Nitrile Rubber
Low voltage
High voltage
(Switch Model 66)
(Switch Model 85)
Cross Section (mm²)
0.14
0.25
Cable material
PVC
Packing
Bulk
Cable spec
PP
PP
NBR
Environmental Data
Unit
Shock Resistance (max.)
50
G
G
-20 to 80
°C
-5 to 80
°C
-30 to70
°C
1/2 sine wave duration 11ms
Vibration Resistance (max.)
Operating Temperature
Cable not moved
Cable moved
Storage Temperature
Life Test Data
*Load increase reduces life expectancy of Reed Switches
Handling & Assembly Instructions
Max torque of screw is 1Nm
Cable bending-radius is diameter x 15
Min. bending distance to housing is 5mm
Drag mark out of the mounting area forbidden
Decrease switching distance by mounting on iron
Series resistor recommended for > 5m cable length
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
Version 01
27.01.2015
很抱歉,暂时无法提供与“LS01-1A66-PA-500W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+59.155511+7.68400
- 5+54.022905+7.01730
- 20+48.2813420+6.27150
