LS03/DL-1A66-PA-500W
    STANDEX-MEDER(斯丹麦德)
    DIP20_300MIL
    SENSOR FLOAT
LS03/DL-1A66-PA-500W 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – LS03 Level Sensors LS03 Series Level Sensors  Features: Single Level Horizontal Mount, High Power Switch Option, Other Cables & Connectors  Applications: Level Control, Detection and Monitoring  Markets: Automotive, Appliance, HVAC/R, Test & Measurement LS-03 0X00-XX-000X Part-Description: Contact QTY Contact Form Switch Model Material Cable Length (mm) Cable Termination 01 A (SPST-NO) B (SPST-NC) 66, 85 PA, PP 500 W = Stripped and Tinned Customer Options Contact Data 66 85 Rated Power (max.) 10 100 W 200 400 V 0.5 1.0 A 1.25 2.5 A 150 150 mOhm Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 10mA Glossary Contact Form Unit Glossary Material Form A NO = Normally Open Contacts SPST = Single Pole Single Throw PP: Polypropylene Form B NC = Normally Closed Contacts SPST = Single Pole Single Throw Form C Changeover SPDT = Single Pole Double Throw PA: Polyamide NBR: Nitrile Butadiene Rubber For water applications and dilute acids For oil For oil, gasoline & in high temperatures SS: Stainless Steel For high temp. (< 160° C) USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015 A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – LS03 Level Sensors General Sensor Data LS03 Versions Materials Standard-Version GZ-Version DK-Version DL-Version Stem, Nut PA PP Float PA PP Seal Nitrile Rubber Low voltage Nitrile Rubber High voltage (Switch Model 66) (Switch Model 66) Cross Section (mm²) 0.14 0.25 Cable material PVC Packing Bulk Cable spec Environmental Data Unit Shock Resistance (max.) 50 G 20 G -20 to 80 °C -5 to 80 °C -30 to70 °C 1/2 sine wave duration 11ms Vibration Resistance (max.) Operating Temperature Cable not moved Operating Temperature Cable moved Storage Temperature Tank wall Tank wall LS03 Level Sensor Handling & Assembly Instructions Standard  Mounting from inside, thread M16 x 2.0  Insertion hole: Ø 16.5mm GZ-Type  Mounting from outside, tapered thread ½“ (no sealing necessary)  Sealing from inside, with O-ring DK-Type  Insertion hole: 1/2“ thread  Mounting from outside, thread M16 x 2.0  Mounting from outside, thread M16 x 2.0 Life Test Data  Insertion hole: Ø 22mm  Insertion hole: Ø 22–24 mm *Load increase reduces life expectancy of Reed Switches DL-Type  5mm narrow sealing, suitable  12mm wide sealing, suitable for high filling Pressure for low filling Pressure  Wall thickness min. 4mm  Wall thickness max. 5mm USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015
物料型号:LS-030X00-XX-000X
器件简介:LS03系列液位传感器,适用于水平安装的单点液位检测,具有高功率开关选项和其他电缆及连接器。
引脚分配:文档中未明确列出引脚分配,但提到了开关型号66和85。
参数特性: - 额定功率:最大10W(DC)或100W(AC) - 开关电压:最大200V(DC)或400V(峰值AC) - 开关电流:最大0.5A(DC)或1.0A(峰值AC) - 承载电流:最大1.25A(DC)或2.5A(峰值AC) - 接触电阻:最大150mOhm
功能详解:适用于液位控制、检测和监控。
应用信息:汽车、家电、暖通空调/制冷、测试与测量。
封装信息:提供了几种不同版本的传感器,包括标准版、GZ版、DK版和DL版,每种版本都有不同的安装方式和密封要求。
LS03/DL-1A66-PA-500W 价格&库存
很抱歉,暂时无法提供与“LS03/DL-1A66-PA-500W”相匹配的价格&库存,您可以联系我们找货
