LS02-1A66-PP-5000W
LS02-1A66-PP-5000W
    STANDEX-MEDER(斯丹麦德)
    SENSOR LEVEL FLOAT M10
LS02-1A66-PP-5000W 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – LS02 Level Sensors LS02 Series Level Sensors  Features: IP68-only up to Screw in Thread, High Power Switch Option, Other Cables & Connectors  Applications: Level Control, Detection and Monitoring  Markets: Automotive, Appliance, HVAC/R, Test & Measurement LS-02 0X00-XX-000X Part-Description: Contact QTY Contact Form Switch Model Material Cable Length (mm) Cable Termination 01 A (SPST-NO) B (SPST-NC) 66, 85 PA, PP 500, 1,000, 5,000 W = Stripped and Tinned Customer Options Contact Data 66 85 Rated Power (max.) 10 100 W 200 400 V 0.5 1.0 A 1.25 2.5 A 150 150 mOhm Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 10mA Unit Glossary Material Glossary Contact Form Form A NO = Normally Open Contacts SPST = Single Pole Single Throw PP: Polypropylene Form B NC = Normally Closed Contacts SPST = Single Pole Single Throw Form C Changeover SPDT = Single Pole Double Throw PA: Polyamide NBR: Nitrile Butadiene Rubber For water applications and dilute acids For oil For oil, gasoline & in high temperatures SS: Stainless Steel For high temp. (< 160° C) USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015 A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – LS02 Level Sensors LS02 Level Sensor General Sensor Data Materials Stem, nut PA Float PA Seal Nitrile Rubber Low voltage High voltage (Switch Model 66) (Switch Model 85) Cross Section (mm²) 0,14 0,25 Cable material PVC Packing Bulk Cable spec PP PP NBR Environmental Data Unit Shock Resistance (max.) 50 G 20 G -30 to 80 °C -5 to 80 °C -30 to 80 °C 1/2 sine wave duration 11ms Vibration Resistance (max.) Operating Temperature Cable not moved Operating Temperature Cable moved Storage Temperature Life Test Data *Load increase reduces life expectancy of Reed Switches Handling & Assembly Instructions  Max torque of screw is 1Nm  Cable bending-radius is diameter x 15  Min. bending distance to housing is 5mm  Drag mark out of the mounting area forbidden  Decrease switching distance by mounting on iron  Series resistor recommended for > 5m cable length USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015
LS02-1A66-PP-5000W 价格&库存
很抱歉,暂时无法提供与“LS02-1A66-PP-5000W”相匹配的价格&库存,您可以联系我们找货
