CTANK-M120
CTANK-M120
    DIGIINTERNATIONAL
CTANK-M120 数据手册
Digi Connect® Tank Fully integrated, Cellular Enabled Tank Level Sensor Monitor tank level and location remotely using cellular technologies to optimize operations. Overview Digi Connect Tank is a fully integrated cellular-enabled tank level sensor providing remote access to deployed tanks, totes and containers. Part of the Digi Tank solutions offer, it leverages Digi Device Cloud and integration services, enabling customers who own or manage large numbers of tanks to easily integrate into existing applications or work with 3rd party applications. Application Highlight Diesel Exhaust Fluid (DEF) Distributor Tank Monitoring or Supply Chain Managment Application Cellular/ VPN Digi Connect Tank provides logistical and operational optimization via tank level and location data. Customers can route feet and personnel efficiently, reduce transportation and fuel costs, and increase supply chain predictability. Digi Connect® Tank Ultrasonic DEF Level Sensing top kS uc Tr Using 3G/2G cellular technologies, Digi Connect Tank can be installed in locations where network infrastructure may not available. Its small form factor, durable NEMA 4X enclosure, industry safety ratings and long-life battery make this product ideal for use in a broad range of tank applications. Remote Site Features/Benefits Target Applications • Remote access to tanks located virtually anywhere • Fully integrated sensor/long life-battery/ global cellular in NEMA 4X enclosure for broad tank application support • Tank location and level provides logistical and operational optimization Cooking Oil Recycling Chemicals Water/Waste Water - Reduced transportation/fuel costs via efficient routing of fleet and personnel - Predictable and efficient supply chain management Waste Oil Agriculture Diesel Exhaust Fluid • Integrated ultrasonic sensor for non-contact liquid level measurements - Includes temp/sound speed compensation www.digi.com Specifications Digi Connect® Tank WWAN Carriers AT&T, International GSM Carriers* North American Version: Dual Band UMTS/HSPA+ (850,1900 MHZ) International Version: Dual Band UMTS/HSPA+ (900/2100 MHZ) Dual-Band GSM (900/1800 MHZ) Frequency Band Data Rate HSDPA Cat. 10 / HSUPA Cat.6 data rates DL: max. 14.4 Mbps, UL: max. 5.76 Mbps >> EDGE class 12 data rates: DL: max. 237 kbps, UL: max. 237 kbps >> GPRS class 12 data rates DL: max. 85.6 kbps, UL: max. 85.6 kbps Antenna Built-in SIM Slots 1 Short Range Sensor Model Massa M-300/150 Type Range Mid Range Massa M-300/95 Ultrasonic, Built-in temperature/sound speed compensation Range at -20˚ C to +65˚ C: 4 inches (100 mm) to 7 feet (2.1 meters) Range at -20˚ C to +65˚ C: 1 feet (0.3meters) to 13 feet (4 meters) Range at -30˚ C to -20˚ C: 4 inches (100 mm) to 5 feet (1.5 meters) Range at -30˚ C to -20˚ C: 1 feet (0.3meters) to 12 feet (3.7 meters) GPS/Glonass Channels Tracking Sensitivity TTFF (Typical) Horizontal Accuracy Antenna 56 GPS: -161 dBm; Glonass: -158 dBm Cold Start: 30 seconds, Warm Start: 28 seconds; Glonass: Cold Start: 32s, Warm Start 25s GPS: 2.5m; Glonass: 4m Built-in Management Configuration & Management Protocol Device Cloud/Local USB to Serial CLI TCP Power Battery Battery Life 7.2V, 14.5 Ah, Lithium Thionyl Chloride, non-rechargeable, replaceable Approximately 2 years (@ 2 reads/transmits per day) Environmental Operating Temperature Storage Temperature -30˚ C to +65˚ C (See range limitations in Sensor section above) -30˚ C to +50˚ C (for ATEX rated applications) -40˚ C to +85˚ C Relative Humidity 90% (Non-condensing after 90%) Battery Discharge
CTANK-M120 价格&库存
很抱歉,暂时无法提供与“CTANK-M120”相匹配的价格&库存,您可以联系我们找货
