SHT21P
SHT21P
    SENSIRION(盛思锐)
    TDFN6_EP
SHT21P 数据手册
Datasheet SHT21P Humidity and Temperature Sensor IC      Fully calibrated Analog output, PWM interface Low power consumption Excellent long term stability DFN type package – reflow solderable Product Summary The SHT21 humidity and temperature sensor of Sensirion has become an industry standard in terms of form factor and intelligence: Embedded in a reflow solderable Dual Flat No leads (DFN) package of 3 x 3mm foot print and 1.1mm height it provides calibrated, linearized sensor signals in analog Pulse Width Modulated (PWM) format. PWM signal runs on a base frequency of 120Hz, the data signal is provided on SDA line. Pulling SCL high or low allows for switching between humidity and temperature, respectively. The sensor measures twice per second. The PWM signal may be converted to an analog ratiometric interface by adding a low pass filter. The SHT2x sensors contain a capacitive type humidity sensor, a band gap temperature sensor and specialized analog and digital integrated circuit – all on a single CMOSens® chip. This yields in an unmatched sensor performance in terms of accuracy and stability as well as minimal power consumption. Every sensor is individually calibrated and tested. Lot identification is printed on the sensor. Dimensions Sensor Chip 3.0 SHT21P features a generation 4C CMOSens® chip. Besides the capacitive relative humidity sensor and the band gap temperature sensor, the chip contains an amplifier, A/D converter, OTP memory and a digital processing unit. 3.0 SHT21 P0AC4 0.3 typ 2.4 max With this set of features and the proven reliability and long-term stability, the SHT2x sensors offer an outstanding performance-to-price ratio. For testing SHT2x two evaluation kits EK-H4 and EK-H5 are available. 1.4 max 1.1 2.2 0.2 0.3 NC VDD SCL 0.75 0.4 Bottom View Material Contents While the sensor itself is made of Silicon the sensors’ housing consists of a plated Cu lead-frame and green epoxy-based mold compound. The device is free of Pb, Cd and Hg – hence it is fully RoHS and WEEE compliant. 0.4 1.5 2.4 1.0 Additional Information 1.0 NC VSS SDA Figure 1: Drawing of SHT21P sensor package, dimensions are given in mm (1mm = 0.039inch), tolerances are ±0.1mm. The die pad (center pad) is internally connected to VSS. The NC pads must be left floating. Numbering of E/O pads starts at lower right corner (indicated by notch in die pad) and goes clockwise (compare Table 2). www.sensirion.com Additional information such as Application Notes is available from the web page www.sensirion.com/sht21. For more information please contact Sensirion via info@sensirion.com. Version 4 – May 2014 1/10 Sensor Performance Relative Humidity123 Temperature456 Parameter Resolution Condition 12 bit Value 0.04 Units %RH Parameter Resolution Condition 14 bit Value 0.01 Units °C Accuracy tolerance 1 typ 2.0 see Figure 2 %RH typ 0.3 see Figure 3 °C %RH Accuracy tolerance 1 Repeatability 0.1 %RH Repeatability °C Hysteresis 1 80%RH). For more details please see Section 1.1 of the Users Guide. www.sensirion.com Typical value for operation in normal RH/T operating range. Max. value is < 0.5 %RH/y. Value may be higher in environments with vaporized solvents, outgassing tapes, adhesives, packaging materials, etc. For more details please refer to Handling Instructions. 5 Values of Supply Current and Power Dissipation are based upon fixed VDD = 3.0V and T = 25°C. 6 Response time depends on heat conductivity of sensor substrate. 7 Max. value is < 0.04°C/y. Version 4 – May 2014 2/10 Users Guide SHT21P 1 Extended Specifications Normal Range 40 Max. Range 20 0 -40 -20 0 20 40 60 80 100 120 Temperature (°C) Figure 4 Operating Conditions Relative Humidity [%RH] 1.2 RH accuracy at various temperatures Typical RH accuracy at 25°C is defined in Figure 2. For other temperatures, typical accuracy has been evaluated to be as displayed in Figure 5. 100 90 80 70 60 50 40 30 20 10 0 ±3.5 ±3.5 ±3 ±3 ±2.5 ±2.5 ±2.5 ±2.5 ±2.5 ±3 ±3.5 ±3 ±3 ±2.5 ±2.5 ±2 ±2 ±2 ±2 ±2.5 ±3 ±3.5 ±3 ±2.5 ±2 ±2 ±2 ±2 ±2 ±2 ±2 ±2.5 ±3 0 10 20 ±3 ±2.5 ±2 ±2 ±2 ±2 ±2 ±2 ±2 ±2.5 ±3 ±3 ±2.5 ±2 ±2 ±2 ±2 ±2 ±2 ±2 ±2.5 ±3 ±3 ±2.5 ±2.5 ±2 ±2 ±2 ±2 ±2 ±2 ±2.5 ±3 ±3.5 ±3 ±2.5 ±2.5 ±2 ±2 ±2 ±2 ±2 ±2.5 ±3 30 40 50 60 Temperature [°C] ±4 ±3.5 ±3 ±2.5 ±2.5 ±2 ±2 ±2 ±2 ±2.5 ±3 ±4 ±4 ±3.5 ±3 ±2.5 ±2.5 ±2 ±2 ±2 ±2.5 ±3 70 80 Figure 5 Typical accuracy of relative humidity measurements given in %RH for temperatures 0 – 80°C. The solder mask9 design for the land pattern preferably is of type Non-Solder Mask Defined (NSMD) with solder mask openings larger than metal pads. For NSMD pads, the solder mask opening should be about 120μm to 150μm larger than the pad size, providing a 60μm to 75μm design clearance between the copper pad and solder mask. Rounded portions of package pads should have a matching rounded solder mask-opening shape to minimize the risk of solder bridging. For the actual pad dimensions, each pad on the PCB should have its own solder mask opening with a web of solder mask between adjacent pads. 0.4 0.3 0.2 60 0.4 80 On the PCB the I/O lands8 should be 0.2mm longer than the package I/O pads. Inward corners may be rounded to match the I/O pad shape. The I/O land width should match the DFN-package I/O-pads width 1:1 and the land for the die pad should match 1:1 with the DFN package – see Figure 6. 2.4 0.2 100 2.1 Soldering Instructions The DFN’s die pad (centre pad) and perimeter I/O pads are fabricated from a planar copper lead-frame by overmolding leaving the die pad and I/O pads exposed for mechanical and electrical connection. Both the I/O pads and die pad should be soldered to the PCB. In order to prevent oxidation and optimize soldering, the bottom side of the sensor pads is plated with Ni/Pd/Au. 0.7 Relative Humidity (%) 1.1 Operating Range The sensor works stable within recommended Normal Range – see Figure 4. Long term exposure to conditions outside Normal Range, especially at humidity >80%RH, may temporarily offset the RH signal (+3%RH after 60h). After return into the Normal Range it will slowly return towards calibration state by itself. Prolonged exposure to extreme conditions may accelerate ageing. 2 Application Information 1.5 For details on how Sensirion is specifying and testing accuracy performance please consult Application Note “Statement on Sensor Specification”. 1.0 1.0 Figure 6 Recommended metal land pattern for SHT2x. Values in mm. Die pad (centre pad) may be left floating or be connected to ground, NC pads shall be left floating. The outer dotted line represents the outer dimension of the DFN package. For solder paste printing a laser-cut, stainless steel stencil with electro-polished trapezoidal walls and with 0.125mm stencil thickness is recommended. For the I/O pads the 8 The land pattern is understood to be the metal layer on the PCB, onto which the DFN pads are soldered to. 9 The solder mask is understood to be the insulating layer on top of the PCB covering the connecting lines. www.sensirion.com Version 4 – May 2014 3/10 Datasheet SHT21P stencil apertures should be 0.1mm longer than PCB pads and positioned with 0.1mm offset away from the centre of the package. The die pad aperture should cover about 70 – 90% of the pad area – say up to 1.4mm x 2.3mm centered on the thermal land area. It can also be split in two openings. Due to the low mounted height of the DFN, “no clean” type 3 solder paste10 is recommended as well as Nitrogen purge during reflow. Temperature TP tP TL TS (max) critical zone It is of great importance to understand that a humidity sensor is not a normal electronic component and needs to be handled with care. Chemical vapors at high concentration in combination with long exposure times may offset the sensor reading. For this reason it is recommended to store the sensors in original packaging including the sealed ESD bag at following conditions: Temperature shall be in the range of 10°C – 50°C and humidity at 20 – 60%RH (sensors that are not stored in ESD bags). For sensors that have been removed from the original packaging we recommend to store them in ESD bags made of metal-in PE-HD11. tL preheating 2.2 Storage Conditions and Handling Instructions Moisture Sensitivity Level (MSL) is 1, according to IPC/JEDEC J-STD-020. At the same time, it is recommended to further process the sensors within 1 year after date of delivery. Time Figure 7 Soldering profile according to JEDEC standard. TP 50°C for 24h to outgas contaminants before packing. VDD SCL SHT2x PWM bit stream C = 100nF Select RH or T SDA VSS Figure 9 Typical application circuit, including decoupling of VDD and VSS by a capacitor. 2.8 SDA – Bit Stream Pad On SDA the sensor is providing PWM output. The signal is carrying humidity or temperature data depending on SCL being high or low, respectively. See Table 4 for detailed I/O characteristic of the sensor. 3 Electrical Characteristics 3.1 Absolute Maximum Ratings The electrical characteristics of SHT21P are defined in Table 1. The absolute maximum ratings as given in Table 3 are stress ratings only and give additional information. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect the sensor reliability (e.g. hot carrier degradation, oxide breakdown). www.sensirion.com Version 4 – May 2014 5/10 Datasheet SHT21P Parameter VDD to VSS Digital IO Pins (SDA, SCL) to VSS Input Current on any Pin min -0.3 max 5 Units V -0.3 VDD + 0.3 V -100 100 mA ESD immunity is qualified according to JEDEC JESD22A114 method (Human Body Model at 4kV), JEDEC JESD22-A115 method (Machine Model 200V) and ESDA ESD-STM5.3.1-1999 and AEC-Q100-011 (Charged Device Model, 750V corner pins, 500V other pins). Latchup immunity is provided at a force current of 100mA with Tamb = 125°C according to JEDEC JESD78. For exposure beyond named limits the sensor needs additional protection circuit. 3.2 Input / Output Characteristics The electrical characteristics such as power consumption, low and high level input and output voltages depend on the supply voltage. For proper communication with the sensor it is essential to make sure that signal design is strictly within the limits given in Table 4. Output Low Voltage, VOL Output High Voltage, VOH Output Sink Current, IOL min typ max Units 40 V V µA 0 VDD tPW VDD SDA Table 3 Electrical absolute maximum ratings Parameter tF 0V Figure 10 PWM signal. Base frequency runs constantly at approximately 120 Hz, hence tF is about 8.3ms. The signal is provided on tPW as a ratio of tF. The measured data – either humidity or temperature – is provided as ratio of tPW and tF. tPW shall always be given as ratio of tF to make it independent of variations of the base frequency. 5 Conversion of Signal Output Resolution is set to 10 bit relative humidity and 12 bit temperature reading and cannot be changed. The sensor reading is linear and hence it can be converted to a physical value by an easy linear equation. 5.1 Relative Humidity Conversion With the relative humidity signal output the relative humidity RH is obtained by the following formula (result in %RH): RH  6  125  t PW tF Table 4 DC characteristics of output pad. VDD = 2.1 V to 3.6 V, T = -40 °C to 125 °C, unless otherwise noted. The physical value RH given above corresponds to the relative humidity above liquid water according to World Meteorological Organization (WMO). For 4 Communication with Sensor relative humidity values above ice RHi the values need to be transformed as from relative humidity above water RHw at a certain temperature t follows – compare also Application Note “Introduction to Humidity”: 4.1 Start up Sensor As a first step, the sensor is powered up to VDD (between 2.1V and 3.6V). After power-up, the sensor needs at most 150ms for reaching idle state. During that time SDA is in undefined state. Then the sensor starts measuring and providing data on PWM bit-stream. 4.2 PWM Specification Pulse Width Modulation runs on a constant frequency and the measured information is provided as duty cycle on that frequency – see Figure 10. Such information is measured humidity for SCL pulled high and temperature for SCL pulled low.  β t   β t  RH i  RH w  exp w  exp i   λw  t   λi  t  Units are %RH for relative humidity and °C for temperature. The corresponding coefficients are defined as follows: βw = 17.62, λw = 243.12°C, βi = 22.46, λi = 272.62°C. 5.2 Temperature Conversion The temperature T is calculated by inserting the ratio of tPW and tF into the following formula (result in °C): T  46.85  175.72  www.sensirion.com Version 4 – May 2014 t PW tF 6/10 Datasheet SHT21P 6 Environmental Stability The SHT2x sensor series were tested based on AECQ100 Rev. G qualification test method where applicable. Sensor specifications are tested to prevail under the AECQ100 temperature grade 1 test conditions listed in Table 513. Sensor performance under other test conditions cannot be guaranteed and is not part of the sensor specifications. Especially, no guarantee can be given for sensor performance in the field or for customer’s specific application. Environment Standard HTOL 125°C, 408 hours TC -50°C - 125°C, 1000 cycles Results17 Pass Pass UHST 130°C / 85%RH / ≈2.3bar, 96h Pass THB 85°C / 85%RH, 1000h Pass HTSL 150°C, 1000h Pass ELFR 125°C, 48h Pass ESD immunity HBM 4kV, MM 200V, CDM Pass 750V/500V (corner/other pins) Latch-up force current of ±100mA with Tamb Pass = 125°C Table 5: Qualification tests: HTOL = High Temperature Operating Lifetime, TC = Temperature Cycles, UHST = Unbiased Highly accelerated Stress Test, THB = Temperature Humidity Biased, HTSL = High Temperature Storage Lifetime, ELFR = Early Life Failure Rate. For details on ESD see Sect. 4.1. If sensors are qualified for reliability and behavior in extreme conditions, please make sure that they experience same conditions as the reference sensor. It should be taken into account that response times in assemblies may be longer, hence enough dwell time for the measurement shall be granted. For detailed information please consult Application Note “Qualification Guide”. frame at diced edge is not covered with respective protective coating. The total weight of the sensor is 25mg. 7.2 Filter Cap and Sockets For SHT2x a filter cap SF2 is available. It is designed for fast response times and compact size. Please find the datasheet on Sensirion’s web page. For testing of SHT2x sensors sockets, such as from Plastronics, part number 10LQ50S13030 are recommended (see e.g. www.locknest.com). 7.3 Traceability Information All SHT21 are laser marked with an alphanumeric, fivedigit code on the sensor – see Figure 11. SHT21 P0AC4 Figure 11 Laser marking on sensor. For details see text. The marking on the sensor consists of two lines with five digits each. The first line denotes the sensor type (SHT21). The first digit of the second line defines the output mode (D = digital, Sensibus and I2C, P = PWM, S = SDM). The second digit defines the manufacturing year (0 = 2010, 1 = 2011, etc.). The last three digits eventually represent an alphanumeric tracking code. That code can be decoded by Sensirion only and allows for tracking on batch level through production, calibration and testing – and will be provided upon justified request. Reels are also labeled, as displayed in Figure 12 and Figure 13, and give additional traceability information. Lot No.: Quantity: RoHS: XXO-NN-YRRRTTTTT RRRR Compliant Lot No. 7 Packaging 7.1 Packaging Type SHT2x sensors are provided in DFN packaging (in analogy with QFN packaging). DFN stands for Dual Flat No leads. The sensor chip is mounted to a lead frame made of Cu and plated with Ni/Pd/Au. Chip and lead frame are over molded by green epoxy-based mold compound. Please note that side walls of sensors are diced and hence lead Figure 12: First label on reel: XX = Sensor Type (21 for SHT21), O = Output mode (D = Digital, P = PWM, S = SDM), NN = product revision no., Y = last digit of year, RRR = number of sensors on reel divided by 10 (200 for 2000 units), TTTTT = Traceability Code. 13 Sensor operation temperature range is -40 to 125°C (AEC-Q100 temperature grade 1). 17 According to accuracy and long term drift specification given on Page 2. www.sensirion.com Version 4 – May 2014 7/10 Datasheet SHT21P Device Type: Description: 1-100PPP-NN Humidity & Temperature Sensor SHTxx Part Order No. 1-100PPP-NN or Customer Number Date of Delivery: DD.MM.YYYY Order Code: 46CCCC / 0 Figure 13: Second label on reel: For Device Type and Part Order Number (See Packaging Information on page 2), Delivery Date (also Date Code) is date of packaging of sensors (DD = day, MM = month, YYYY = year), CCCC = Sensirion order number. 7.4 Shipping Package SHT2x are provided in tape & reel shipment packaging, sealed into antistatic ESD bags. For SHT21P standard packaging sizes are 400, 1500 and 5000 units per reel. Each reel contains 440mm (55 pockets) header tape and 200mm (25 pockets) trailer tape. 0.3 Ø1.5 MIN Ø1.5 MIN 3.3 5.5 R0.3 MAX 12.0 8.0 2.0 4.0 1.75 The drawing of the packaging tapes with sensor orientation is shown in Figure 13. The reels are provided in sealed antistatic bags. 1.3 3.3 0.25 R0.25 Figure 14 Sketch of packaging tape and sensor orientation. Header tape is to the right and trailer tape to the left on this sketch. www.sensirion.com Version 4 – May 2014 8/10 Datasheet SHT21P Revision History Date 19 Aug 2009 29 Jan 2010 5 May 2010 31 May 2011 December 2011 May 2014 www.sensirion.com Version 0.6 1.0 1.1 2 3 4 Page(s) 1, 6 1–9 1–9 1 – 4, 6 – 10 Changes Figure 1 adapted, add details to Section 1.2, 5.1 and Chapter 7 Completely revised version. Require Change Protocol for details. Elimination of errors and addition of information (ask for change protocol) Updated temperature accuracy specifications, MSL and standards. Elimination of errors. For detailed information, please require complete change list at info@sensirion.com. 1, 7 Minor text adaptations and corrections. 1-4, 7-8 Sensor window dimension updated, several minor adjustments Version 4 – May 2014 9/10 Datasheet SHT21P Warning, Personal Injury Important Notices Do not use this product as safety or emergency stop devices or in any other application where failure of the product could result in personal injury. Do not use this product for applications other than its intended and authorized use. Before installing, handling, using or servicing this product, please consult the data sheet and application notes. Failure to comply with these instructions could result in death or serious injury. If the Buyer shall purchase or use SENSIRION products for any unintended or unauthorized application, Buyer shall defend, indemnify and hold harmless SENSIRION and its officers, employees, subsidiaries, affiliates and distributors against all claims, costs, damages and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if SENSIRION shall be allegedly negligent with respect to the design or the manufacture of the product. ESD Precautions The inherent design of this component causes it to be sensitive to electrostatic discharge (ESD). To prevent ESD-induced damage and/or degradation, take customary and statutory ESD precautions when handling this product. See application note “ESD, Latchup and EMC” for more information. Warranty SENSIRION warrants solely to the original purchaser of this product for a period of 12 months (one year) from the date of delivery that this product shall be of the quality, material and workmanship defined in SENSIRION’s published specifications of the product. Within such period, if proven to be defective, SENSIRION shall repair and/or replace this product, in SENSIRION’s discretion, free of charge to the Buyer, provided that:  notice in writing describing the defects shall be given to SENSIRION within fourteen (14) days after their appearance;  such defects shall be found, to SENSIRION’s reasonable satisfaction, to have arisen from SENSIRION’s faulty design, material, or workmanship;  the defective product shall be returned to SENSIRION’s factory at the Buyer’s expense; and  the warranty period for any repaired or replaced product shall be limited to the unexpired portion of the original period. This warranty does not apply to any equipment which has not been installed and used within the specifications recommended by SENSIRION for the intended and proper use of the equipment. EXCEPT FOR THE WARRANTIES EXPRESSLY SET FORTH HEREIN, SENSIRION MAKES NO WARRANTIES, EITHER EXPRESS OR IMPLIED, WITH RESPECT TO THE PRODUCT. ANY AND ALL WARRANTIES, INCLUDING WITHOUT LIMITATION, WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, ARE EXPRESSLY EXCLUDED AND DECLINED. SENSIRION is only liable for defects of this product arising under the conditions of operation provided for in the data sheet and proper use of the goods. SENSIRION explicitly disclaims all warranties, express or implied, for any period during which the goods are operated or stored not in accordance with the technical specifications. SENSIRION does not assume any liability arising out of any application or use of any product or circuit and specifically disclaims any and all liability, including without limitation consequential or incidental damages. All operating parameters, including without limitation recommended parameters, must be validated for each customer’s applications by customer’s technical experts. Recommended parameters can and do vary in different applications. SENSIRION reserves the right, without further notice, (i) to change the product specifications and/or the information in this document and (ii) to improve reliability, functions and design of this product. © Copyright 2014 by Sensirion. CMOSens® is a trademark of Sensirion All rights reserved Headquarters and Subsidiaries SENSIRION AG Laubisruetistr. 50 CH-8712 Staefa ZH Switzerland Sensirion Inc., USA phone: +1 805 409 4900 info_us@sensirion.com www.sensirion.com Sensirion Korea Co. Ltd. phone: +82 31 337 7700~3 info@sensirion.co.kr www.sensirion.co.kr phone: +41 44 306 40 00 fax: +41 44 306 40 30 info@sensirion.com www.sensirion.com Sensirion Japan Co. Ltd. phone: +81 3 3444 4940 info@sensirion.co.jp www.sensirion.co.jp Sensirion China Co. Ltd. phone: +86 755 8252 1501 info@sensirion.com.cn www.sensirion.com.cn Sensirion AG (Germany) phone: +41 44 927 11 66 info@sensirion.com www.sensirion.com To find your local representative, please visit www.sensirion.com/contact www.sensirion.com Version 4 – May 2014 10/10
SHT21P 价格&库存
很抱歉,暂时无法提供与“SHT21P”相匹配的价格&库存,您可以联系我们找货
