Data Sheet SHTW2
WLCSP Humidity and Temperature Sensor IC
Ultra-small flip chip package: 1.3 × 0.7 × 0.5 mm3
Fully calibrated and reflow solderable
Ultra-low power consumption
Power-up and measurement within 1 ms
1.8 V supply voltage
Typical accuracy: ±3 %RH and ±0.4 °C
Product Summary
The SHTW2 is a digital humidity and temperature sensor
in a flip chip package. This type of package opens up a
new category of ultra-small humidity sensors which are
suitable for applications with the tightest space
constraints. At the same time, the flip chip package
impresses with its pure simplicity.
The sensor is based on Sensirion’s CMOSens®
technology, which offers a complete sensor system on a
single chip, consisting of a capacitive humidity sensor, a
bandgap temperature sensor, analog and digital signal
processing, A/D converter, calibration data memory, and
a digital communication interface supporting I2C fast
mode.
Block diagram
Benefits of Sensirion’s CMOSens® Technology
The sensor covers a humidity measurement range of 0 to
100 %RH and a temperature measurement range of -30
to 100 °C with a typical accuracy of ±3 %RH and ±0.4°C.
The operation voltage of 1.8 V and the low power
consumption make the SHTW2 suitable for mobile or
wireless applications running on the tightest power
budgets. With the industry-proven quality and reliability of
Sensirion’s humidity and temperature sensors and
constant accuracy over a large measurement range, the
SHTW2 offers an unprecedented performance-to-price
ratio. Tape and reel packaging together with suitability for
standard SMD assembly processes make the SHTW2
predestined for high-volume applications.
High reliability and long-term stability
Industry-proven technology with a track record of
more than 10 years
Designed for mass production
Optimized for lowest cost
Best signal-to-noise ratio
RH sensor
T sensor
Signal conditioning
Signal conditioning
analog
ADC
digital
Contents of this Data Sheet
1
Humidity and Temperature Sensor Specifications ... 2
2
Electrical Specifications ........................................... 3
3
Timing Specifications ............................................... 4
4
Interface Specifications ............................................ 5
5
Operation and Communication ................................ 6
6
Quality ...................................................................... 9
7
Package and Traceability ......................................... 9
8
Technical Drawings................................................ 10
9
Further Information ................................................ 12
Important Notices............................................................ 14
www.sensirion.com
Data processing and system control
Calibration mem.
VDD
VSS
I2C interface
SDA
SCL
Figure 1 Functional block diagram of the SHTW2.
Version 1 – May 2016
1/14
1
Relative Humidity
Temperature
Parameter
Accuracy tolerance1
Conditions
Value
Units
Typ.
3.0
see Figure 2
0.1
0.01
%RH
1
0 to 100
%RH
Resolution3
Specified range4
%RH
Response time8
Resolution3
Max.
Hysteresis
Repeatability2
Specified
range4
Response
extended5
63%
Typ.
time6
Long-term drift7
%RH
%RH
%RH
8
s
很抱歉,暂时无法提供与“SHTW2”相匹配的价格&库存,您可以联系我们找货
