L31S200S05FS
L31S200S05FS
    TAMURA
    L31S200S05FS
L31S200S05FS 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L31S***S05FS Series Features: Advantage:      Open Loop type Panel mounting Unipolar power supply Ferrite core Sulfur tolerant sensors (Resistors:Gold internal Electrodes)  Insulated plastic case according to UL94V0  UL Recognition Specifications Excellent accuracy and linearity Wide nominal current range Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability TA=25ºC, VCC=+5V, RL=10kΩ Symbol Parameters         Primary nominal current Saturation current L31S050S05FS L31S100S05FS L31S200S05FS L31S300S05FS L31S400S05FS L31S500S05FS L31S600S05FS If 50A 100A 200A 300A 400A 500A 600A Ifmax ≥ ±150A ≥ ±300A ≥ ±600A ≥ ±900A ≥ ±900A ≥ ±900A ≥ ±900A Rated output voltage Vo Vof+0.625V ± 0.015V (at If) Offset voltage1 Vof VREF ± 0.025V (at If = 0A) VREF 2.5V ± 0.020V εL ≤ ± 0.5% (at If) Power supply voltage VCC + 5V ±5 % Consumption current Icc ≤ 15mA tr ≤ 5μs (at di/dt = 100A / μs) Thermal drift of gain4 TcVo ≤ ± 1.5mV/ºC Thermal drift of offset TcVof Thermal drift of reference TcVref Reference voltage Output Linearity2 ( 0A, 0.5If , If) Response time3 ≤ ± 1.0 mV/ºC (at If = 0A) ≤ ± 0.3 mV/ºC (at If = 0A) ≤ ± 0.012% / ºC Hysteresis error (at If=0A→If→0A) VOH Insulation voltage Vd AC3300V for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of through hole  terminal TA -40ºC~+85ºC Ambient operation temperature Ambient storage temperature ≤ 10mV ≤ 2.5mV -40ºC~+85ºC TS 1 After removal of core hysteresis— drift of offset 2 3 Without offset — Time between 10% input current full scale and 90% of sensor output full scale — 4 Without Thermal Electrical Performances Frequency Characteristic (L31S***S05FS) Frequency characteristic(L31S500S05S) 6  5  4  ) B (d   n o tia u n e tt A ‐6  4  ) V  ( e 3  agt l o  vt u 2  p t u O ‐8  1  2  0  ‐2  ‐4  Saturation characteristic(L31S500S05S ) Saturation Characteristic (L31S***S05FS) TA=25ºC Pulsed ‐10  0.1 1 10 Frequency characteristic(kHz) @ If=30AT(Arms) L31SXXXS05FSrevF, Feb 2014 100 0  -2000 -1500 -1000 -500 0 500 1000 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 1500 2000 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L31S***S05FS Series Mechanical dimensions in mm Connector 18 R5.5 11 Manufacturer Part Number Old Part Number Molex 22-04-1041 5045-04A Ø2.5 S05FS L31S 20 Ø4.5 Terminal Number: 1: VREF IN / OUT 2: VOUT 3: GND 4: +VCC(+5V) L ot N o. Recommended retainer holes NOTES 1. Unit is mm 2. Tolerance is 0.5mm 20.5 2.5 20 39 MAX 9.75 30 10.5 Current direction 4.5 40 Electrical connection diagram 4 3 2 1 VREF-IN/OUT VOUT +If +VCC UL Standard UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) -If RL = 10kΩ GND • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 85˚C. Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 37g 20 200 3600 L31SXXXS05FSrevF, Feb 2014 Tamura reserve the right to modify its products in order to improve them without prior notice 4.5 5 3 4. Φ2 Φ Terminal No. 4.75 4 3 2 1
L31S200S05FS 价格&库存
很抱歉,暂时无法提供与“L31S200S05FS”相匹配的价格&库存,您可以联系我们找货
