Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensor L05Z800S15
Features:
Advantage:
Open Loop type
Panel mounting
Unipolar power supply
Industrial temperature range
JST connector
Insulated plastic case according to
UL94V0
Excellent accuracy and linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity to external Interference
Current overload capability
Regulated offset voltage
Specifications
TA=25ºC, VCC=+15V, RL=10kΩ
Parameters
Symbol
L05Z800S15
If
800AT
Ifmax
≥ ± 900AT
Rated output voltage
Vo
11V±0.110V(at If)
Offset voltage1
Vof
+ 7.0V ± 0.050V(at If=0A)
Output linearity2 (0A~If)
εL
≤ ± 1% (at If)
Power supply voltage
VCC
+ 15V ±5 %
Consumption current
Icc
≤ 20mA
Response time3
tr
≤ 10μs (at di/dt = 100A / μs)
Thermal drift of gain4
TcVo
≤ ± 0.1%/℃
Thermal drift of offset
TcVof
≤ ± 1.0mV/℃
Hysteresis allowance
VOH
≤ 20mV (at If=0A→If→0A)
Insulation voltage
Vd
AC2500V, for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of through hole terminal
Ambient operation temperature
TA
-40°C~+85°C
Ambient storage temperature
TS
-40°C~+85°C
Primary nominal current
Saturation current
1
Vof is fixed (independent of VCC) . After removal of core hysteresis— 2 Without offset — 3 Time between 90% input current full scale and 90% of
sensor output full scale— 4 Without Thermal drift of offset
Electrical Performances
Frequency characteristic
6
14
12
2
Output voltage (V)
Attenuation (dB)
4
Saturation characteristic
-4
-6
-8
10
8
6
4
TA=25ºC Pulsed
2
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=45AT
L05Z800S15revD, March 2012
100
-1200 -1000 -800 -600 -400 -200
200 400 600 800 1000 1200
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
Mechanical dimensions
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
Connector
Manufacturer
Part Number
JST
B4B-XH-A-G
(Gold plated terminal)
Terminal number:
1. +VCC(+15V)
2. GND
3. VOUT
4. GND
Electrical connection diagram
+VCC
1
2
3
4
GND
VOUT
RL = 10kΩ
+If
-If
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
50g
3600
很抱歉,暂时无法提供与“L05Z800S15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+190.76040
- 200+76.11840
- 400+73.56960
- 1000+72.31680
