26ASD22-01-1-AJS
26ASD22-01-1-AJS
    GRAYHILLINC.
    ENCODER MECHANICAL 16POS BCD
26ASD22-01-1-AJS 数据手册
Mechanical Encoders SERIES 26 AVAILABLE CODES • Hexadecimal • Octal • BCD (Adjusted) • Quadrative • Custom (4-Bit, 16 position maximum) • RoHS Compliant Binary and Gray Code DIMENSIONS in inches (and millimeters) CL POS. 0 CL OF BUSHING FLATS 1/4-28 UNF-2A THREAD .125 ± .003 DIA. (Ø 3,18 ± 0,10) COMMON TERMINAL .300 (7,62) .150 (3,81) 2 PLACES C L ANGLE A .025 ± .005 (0,64 ± 0,13) 3 PLACES .094 (2,39) .250 (6,35) .203 ± .003 (5,16 ± 0,10) ACROSS FLATS .250 (6,35) .200 (5,08) Angle A Rated: 25,000 cycles with logic compatible loads. Make and break 200 mA. Contact Resistance: 500 milliohms maximum (less than 100 milliohms initially) Insulation Resistance: 1000 megohms minimum (10,000 megohms initially) Dielectric Strength: 250 Vac minimum Materials and Finishes Panel Seal: Silicone Rubber Shaft Seal: Fluorosilicone Mounting Nut (mounting hardware–one per switch): Brass, tin/zinc-plated Internal Tooth Lockwasher (mounting hardware): Steel,tin/zinc-plated Detent Balls: Carbon steel, nickel-plated Detent Spring: Pretinned music wire Detent Rotor: Thermoplastic Shaft, Stop Arm and Stop Pins: Stainless steel Bushing: Zamak II tin/zinc alloy, zinc-plated Switch Base: Diallyl phthalate Printed Circuit Board: NEMA Grade FR-4. Terminals: Brass, gold-plated over nickel plate Contacts: Copper alloy, gold-plated over nickel plate Rotational Torque: 4 to 8 oz-in initial Vibration Resistance: 10 to 55 Hz at 0.060" double amplitude; no damage and no contact openings per MIL-STD-202, Method 201A Shock Resistance: Passes medium requirement MIL-DTL-3786 (MIL-STD-202, Method 213) Stop Strength: 5 in-lbs minimum Relative Humidity: 90-95% at 40 oC for Grayhill part number and date code marked on label. Customer part number marked on request. Unless specified otherwise, all tolerances are ± .015 ( 0,38) 240 hours (MIL-STD-202 Method 103, Test Condition A) Shaft and Panel Seal All switches are provided with a shaft and panel seal. OPTIONS Adjustable Stop Switches The switch may have continuous rotation, or be adjusted to limit the rotation. The panel seal ring can be removed to expose the stop pin holes on the front of the switch. Two stop pins and panel seal o-ring are supplied with the switch. One or both may be used to limit the rotation as desired. Custom encoders with options such as custom code output, 1/4” shaft diameter, factory set stops and longer shaft terminal lengths are available by contacting the Grayhill sales office at 708.482.2123. ORDERING INFORMATION Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, or an authorized local Distributor or Grayhill through grayhill.com/where-to-buy. Series Code Output Code: CODE AND TRUTH TABLE Code Position Electrical Ratings .957 (24,31) REF. Switch Position Optical and Mechanical Encoders 67.5° 33.75° CL .100 (2,54) 2 PLACES .332 (8,43) SPECIFICATIONS Additional Characteristics 2 8 C 4 .180 (4,57) .375 (9,53) .500 ± .015 (12,7 ± 0,38) DIA. Maximum Switch Positions 8 16 1 B CD Output* Gray Output* 1 2 4 8 1 2 4 8 1 0 2 1 3 2 4 3 5 4 6 5 7 6 8 7 9 8 10 9 11 10 12 11 13 12 14 13 15 14 16 15 *Dot indicates terminal tied to common. 26GSD22-01-1-16S-C G = Gray, A = BCD Sealed Positions: Stops: D = Adujustable, Blank = Continuous or Fixed C = Continuous, F = Fixed, Blank = Adjustable 08S, 16S, or AJS for adjustable Poles: 1 Decks: 1 Angle of Throw: 22 = 22.5º, 45 = 45º Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
26ASD22-01-1-AJS 价格&库存
很抱歉,暂时无法提供与“26ASD22-01-1-AJS”相匹配的价格&库存,您可以联系我们找货
