63R128
63R128
    GRAYHILLINC.
    ENCODER OPTICAL 128PPR PC MNT
63R128 数据手册
Optical Encoders Series 63R High Resolution, Ball Bearing, 5-pin (Polarized Connection) Features • 25, 32, 50, 64, 100, 128 and 256 Cycles per Revolution Available • Sealed Version Available • Rugged Construction • Cable or Pin Versions • 300 Million Rotational Cycles • 5000 RPM Shaft Rotation • Index Pulse Available Dimensions In Inches (and millimeters) toP vieW .250 (6.35) .215 (5.46) KEYWAY DEPTH Optical and Mechanical Encoders .025 X 45˚ (.64) CHAMFER 1.250 DIA (31.75) .249/.250 DIA (6.32/6.34) .350 (8.89) .033 (.84) .066 (1.68) 1/2 - 32 UN-2A THREADS .725.025 (18.41.64) GRAYHILL XXXX X-X 63RXXX XXXX X-X XX .776.025 (19.71.64) .650 DIA (16.51) MOUNTING SURFACE .219 (5.57) .501 (12.73) PIN #1 .225 (5.71) .100 (2.54) .200 (5.08) .400 (10.16) toP vieW .250 (6.35) .215 (5.46) KEYWAY DEPTH .025 X 45˚ (.64) CHAMFER 1.250 DIA (31.75) .350 (8.89) .033 (.84) .066 (1.68) 1/2 - 32 UN-2A THREADS .725.025 (18.42.64) GRAYHILL XXXX X-X 63RXXX-XXX .219 (5.57) .249/.250 DIA (6.32/6.34) .650 DIA (16.51) MOUNTING SURFACE XXXX X-X XX-XXX .501 (12.73) PIN #1 CONNECTOR IS MOLEX P/N 14-56-3056 OR EQUIVALENT CABLE LENGTH 6.000,25 UNLESS OTHERWISE SPECIFIED, DIMENSION TOLERANCES ARE AS FOLLOWS LINEAR .010 (.25), DIAMETERS .010 (.25), ANGULAR 5˚ Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders Circuitry and Waveform: Standard Quadrature 2-Bit Code PIN # GROUND 5 NO CONTACT 4 OUTPUT A 3 1 CYCLE OUTPUT A OUTPUT B 10 KΩ POWER 5V 2 CHANNEL A LEADS CHANNEL B BY 90˚ ± 45˚ IN ALL ROTATIONS FOR CLOCKWISE ROTATION OF SHAFT. 10 KΩ OUTPUT B 1 Specifications Electrical Ratings Mechanical Ratings Mechanical Life: 300 million revolutions Time Life: Guaranteed for 10 years of continuous operation (calculated from emitter degradation data) Mounting Torque: 20 in-lbs maximum Terminal Strength: 5 lbs terminal pull-out force minimum Solderability: 95% free of pin holes and voids Externally Applied Shaft Force: Axial:15 lbs maximum; Radial:15 lbs maximum Operating Torque: 0.5 in-oz maximum (no detents) for unsealed versions Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 90-95% at 40°C for 96 hours Vibration Resistance: Harmonic motion with amplitude of 15g, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Shock Resistance: Test 1: 100g for 6 mS, halfsine wave with velocity change of 12.3 ft/s. Test 2: 100g for 6 mS, sawtooth wave with velocity change of 9.7 ft/s. Materials and Finishes Bushing: Zinc diecast Housing: Zytel FR-50 Shaft: Stainless steel insert molded into nylon rotor support Code Rotor and Aperture: Chemically etched stainless steel/electroformed nickel Printed Circuit Board: NEMA Grade FR-4. Five microinches minimum gold over 100 microinches minimum nickel over copper Optical Barrier: Polyphenylene sulfide, 94 V-0 Backplate: Polyester Header: Phosphor bronze, 200 microinches tin over 50 microinches nickel (pin version only) Infrared Emitter: Gallium aluminum arsenide Photo IC: Planar silicon Retaining Ring: Stainless steel Cable: 26 AWG, stranded/tinned wire, PVC coated on .100 (2,54) centers (cable version only) Connector: Glass-filled PCT, UL94V-0 Bearing Subassembly Bearing: NSK ABEC 5 (stainless steel) Preload Collar: 303 stainless steel Spacer: 303 stainless steel Bellville Spring: spring steel (stainless) Ordering Information Series Style: R = Standard, 5-pin, high resolution RS = Sealed, 5-pin, high resolution Cycles: per channel per revolution = 25, 32, 50, 64, 100, 128, 256 63RS256–060 Termination: Blank (no dash or numbers): pins as described in drawing. Cable Termination: 060 = 6.0in. Cable is terminated with Molex Connnector P/N 14-56-3056 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Operating Voltage: 5 ±.25 Vdc Supply Current: 30 mA maximum at 5 Vdc Logic Output Characteristics: Output Type: Open collector with integrated Schmitt Trigger and 10 KW pull-up resistor Maximum Sink Current: 16 mA at .40 volts Power Consumption: 150 mW maximum Optical Rise Time: 500 nS typical Optical Fall Time: 14 nS typical
63R128 价格&库存
很抱歉,暂时无法提供与“63R128”相匹配的价格&库存,您可以联系我们找货
63R128
  • 1+1163.523321+150.96619
  • 5+998.273905+129.52522
  • 10+934.1464610+121.20473
  • 25+855.2079625+110.96253
  • 50+799.5751750+103.74422
  • 100+748.68214100+97.14089
库存:293
