60C22-M7-4-040C
60C22-M7-4-040C
    GRAYHILLINC.
    ENCODER OPT 4POS JOYSTICK & PB
60C22-M7-4-040C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 60C Multi-Function Joystick FEATURES • Three-in-One Joystick, Optical Encoder and Pushbutton • Compact Packaging • Choices of Cable Length and Termination • Customized Solutions Available APPLICATIONS • Avionics • Medical Equipment • Automotive Navigation, Information & Entertainment Equipment The 60C is a cost-effective replacement of a stationary mouse or trackball with improved control over cursor movement. An integral Schmitt Trigger is used to stabilize against noise and vibration. Optical and Mechanical Encoders As a compact cursor control device, Grayhill's Series 60C is ideally suited for automotive and aviation dashboards, where use of separate joysticks, encoders and pushbuttons might be impractical. It provides all the functionality of a stationary mouse or trackball in a single unit with a 1"x1"x .661" deep housing. The joystick manipulates a cursor left, right, up and down; the rotary encoder facilitates sequential scrolling through menu options; and the pushbutton performs on-screen menu selects. DIMENSIONS in inches (and millimeters) Unless otherwise specified, standard tolerance are: Linear ± .025 Diameter ± .010 Angle ± 2.0° Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders MOUNTING DETAILS in inches (and millimeters) FRONT MOUNTING REAR MOUNTING Optical and Mechanical Encoders JOYSTICK OPERATION + ENCODER WAVEFORM AND TRUTH TABLE Standard Quadrature 2-Bit Code JOYSTICK ENCODER Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SWITCH SCHEMATIC SPECIFICATIONS Rotary Electrical and Mechanical Ratings Optical and Mechanical Encoders Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 35mA TYP at 5 Vdc Power Consumption: 175mW TYP at 5Vdc Output: Direct output from inverting Schmitt trigger Output Code: 2-Bit quadrature, channel A leads channel B by 90° in cw rotation Logic Output Characteristics: High: No less than 3.5 Vdc Low: No greater than 1.0 Vdc Mechanical Life: 500K rotational cycles (through all positions and a full return) Rotational Torque: medium torque option 3.00+2.00 in-oz, torque shall be within 50% of initial value throughout life Mounting Torque: 15 in-oz. maximum Shaft Push/Pull Out Force: 25 lbs minimum Terminal Strength: 15 lbs terminal minimum Joystick Electrical and Mechanical Ratings Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 35mA at TYP at 5 Vdc Power Consumption: 175mW TYP at 5Vdc Output: Direct output from inverting Schmitt trigger Logic Output Characteristics: High: No less than 3.5 Vdc Low: No greater than 1.0 Vdc Mechanical Life: 500K cycles (through all positions and a full return) Angle of Throw: 8° max. in all directions Pushbutton Electrical and Mechanical Ratings Rating: 10 mA at 5 Vdc resistive Contact Resistance: less than 10 ohms Contact Bounce: < 4ms make, 10 ms break Mechanical Life: 500K actuations minimum Actuation Force: option 7 = 485 ± 115grams Pushbutton Travel: 0.033 ± 0.015 inches to contact; 0.075 inches maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 96 hours at 90-95% humidity at 40°C Vibration: Harmonic motion with amplitude of 15g, within a varied 10 to 2000 Hz Mechanical Shock: Test 1: 100g for 6ms half-sine wave with a velocity change of 12.3 ft/s Test 2: 100g for 6ms sawtooth wave with a velocity change of 9.7 ft/s Thermocycle: 4 hours cycling between -40°C to 85°C Materials and Finishes Bushing: Thermoplastic Shaft Outer: Thermoplastic Upper Housing: Thermoplastic Pushbutton Rocker: Thermoplastic Pushbutton Actuator: Thermoplastic Inner Shaft Slide: Thermoplastic Slider Plate: Thermoplastic Backplate: Thermplastic Lightpipe, Joystick: Thermoplastic Lightpipe, 16 pos: Thermoplastic Centering Profile: Thermoplastic Shaft Inner: Aluminum Pins: Stainless steel Barbed Rivet: Stainless steel Detent Balls: Carbon steel 100 with nickel finish Centering Balls: Carbon steel 100 with nickel finish Detent Springs: Tinned music wire Centering Springs: Tinned music wire Cable ASM: .050 round conductor flat cable, PVC coated. Conductors are stranded, topcoated wire Solder: 95.5% SN, 4% AG, 0.5% CU Dome: Stainless steel PCB 16 Pos: NEMA grade FR-4. Plating is gold or palladium over nickel Infrared Emitter: Gallium aluminum arsenide Phototransistor: Planar silicon Resistor: Carbon film Schmitt Trigger: RoHS Compliant TSSOP, 14 pin Lubricating Grease: Nyogel 774L Label: TT406 Thermal transfer cast film OPTIONS Contact Grayhill for custom terminations, rotational torque, number of positions, shaft configurations, and resolutions. Control knobs are also available. ORDERING INFORMATION 60C22-M7-4-060S Series Angle of Throw: 22= 22.5° or 16 positions Rotation Torque: M= Medium torque Pushbutton: 7= 485 grams Joystick: 4= Four directions Termination: 0.050" center ribbon cable with; C= Connector; S= 0.1" stripped end Cable Length: 025 thru 250 in 1/2 inch increments, 060= 6.0 inch cable Available from your local Grayhill Distributor. For prices and discounts, contact a local sales office, an authorized distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
60C22-M7-4-040C 价格&库存
很抱歉,暂时无法提供与“60C22-M7-4-040C”相匹配的价格&库存,您可以联系我们找货
