Optical Encoders
SERIES 62SG
Compact / Cost Effective
FEATURES
• Just 0.3-inch behind panel depth
• Over 1 million rotational cycles
• 2-bit gray code output
• Quadrature coding
• Available in 16, 24 and 32 detent positions
• Optional integrated pushbutton
• Light pipe technology
• Cost competitive with mechanical
encoders at higher volumes
APPLICATIONS
• Automotive
- audio systems
- navigation systems
• Medical
- patient monitoring systems
• Test & Measurement
- analyzers
- oscilloscopes
• Audio & Video
- consumer electronics
- professional editing equipment
Optical and Mechanical
Encoders
DIMENSIONS in inches (and millimeters)
.050” Cable Connector
.050” Pin Header
Connector
NEW
P/N JST SHROUDED HEADER SM08B-GHS-TB
MATING CONNECTOR P/N JST HOUSING GHR-08V-S
Unless otherwise specified, standard tolerances are:
Linear ± .025
Diameter ± .010
Angle ± 2.0 0
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
WAVEFORM AND TRUTH TABLE
SPECIFICATIONS
Environmental Specifications
Rotary Electrical and
Mechanical Specifications
Operating Voltage: 5.00 ± 0.25 Vdc
Supply Current: 30 mA maximum
Logic Output Characteristics:
Logic high: no less than 3.0 Vdc
Logic low: no greater than 1.0 Vdc
Output: Open Collector Phototransistor
Optical Rise Time: 30ms maximum
Optical Fall Time: 30ms maximum
AVERAGE ROTATIONAL TORQUE SPECIFICATIONS
LOW
MEDIUM
HIGH
16 POSITION
24 POSITION
32 POSITION
±0.50 IN-OZ
1.40
1.25
0.95
±1.40 IN-OZ
2.35
1.95
1.40
±1.60 IN-OZ
3.40
2.95
2.15
Mechanical Life: 1,000,000 cycles of
operation. 1 cycle is a rotation through all
positions and a full return
Mounting Torque: 15in-lbs. maximum
Shaft Pushout Force: 45 lbs. minimum
Terminal Strength: 15 lbs. cable pull out
force minimum
Solderability: 95% free of pin holes & voids
Pushbutton Electrical and
Rating: 30 mA @ 5 Vdc
Contact Resistance:
很抱歉,暂时无法提供与“62SG22-M0-060C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+364.939721+47.27455
- 5+311.189695+40.31173
- 10+289.9379110+37.55876
- 25+263.4042025+34.12157
- 50+244.4345950+31.66423
- 100+226.34139100+29.32043
- 250+203.67997250+26.38485
