Optical Encoders
Series 63R
High Resolution, Ball Bearing,
5-pin (Polarized Connection)
Features
• 25, 32, 50, 64, 100, 128 and 256
Cycles per Revolution Available
• Sealed Version Available
• Rugged Construction
• Cable or Pin Versions
• 300 Million Rotational Cycles
• 5000 RPM Shaft Rotation
• Index Pulse Available
Dimensions In Inches (and millimeters)
toP vieW
.250
(6.35)
.215
(5.46)
KEYWAY DEPTH
Optical and Mechanical
Encoders
.025 X 45˚
(.64)
CHAMFER
1.250 DIA
(31.75)
.249/.250 DIA
(6.32/6.34)
.350
(8.89)
.033
(.84)
.066
(1.68)
1/2 - 32
UN-2A
THREADS
.725.025
(18.41.64)
GRAYHILL XXXX X-X
63RXXX
XXXX X-X
XX
.776.025
(19.71.64)
.650 DIA
(16.51)
MOUNTING
SURFACE
.219
(5.57)
.501
(12.73)
PIN #1
.225
(5.71)
.100
(2.54)
.200
(5.08)
.400
(10.16)
toP vieW
.250
(6.35)
.215
(5.46)
KEYWAY DEPTH
.025 X 45˚
(.64)
CHAMFER
1.250 DIA
(31.75)
.350
(8.89)
.033
(.84)
.066
(1.68)
1/2 - 32
UN-2A
THREADS
.725.025
(18.42.64)
GRAYHILL XXXX X-X
63RXXX-XXX
.219
(5.57)
.249/.250 DIA
(6.32/6.34)
.650 DIA
(16.51)
MOUNTING
SURFACE
XXXX X-X
XX-XXX
.501
(12.73)
PIN #1
CONNECTOR IS
MOLEX P/N
14-56-3056
OR EQUIVALENT
CABLE LENGTH
6.000,25
UNLESS OTHERWISE SPECIFIED, DIMENSION TOLERANCES ARE AS FOLLOWS
LINEAR .010 (.25), DIAMETERS .010 (.25), ANGULAR 5˚
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
Circuitry and Waveform: Standard Quadrature 2-Bit Code
PIN #
GROUND
5
NO CONTACT
4
OUTPUT A
3
1 CYCLE
OUTPUT
A
OUTPUT
B
10 KΩ
POWER 5V
2
CHANNEL A LEADS CHANNEL B BY
90˚ ± 45˚ IN ALL ROTATIONS FOR
CLOCKWISE ROTATION OF SHAFT.
10 KΩ
OUTPUT B
1
Specifications
Electrical Ratings
Mechanical Ratings
Mechanical Life: 300 million revolutions
Time Life: Guaranteed for 10 years of
continuous operation (calculated from emitter
degradation data)
Mounting Torque: 20 in-lbs maximum
Terminal Strength: 5 lbs terminal pull-out
force minimum
Solderability: 95% free of pin holes and voids
Externally Applied Shaft Force:
Axial:15 lbs maximum; Radial:15 lbs
maximum
Operating Torque: 0.5 in-oz maximum (no
detents) for unsealed versions
Environmental Ratings
Operating Temperature Range: -40°C to 85°C
Storage Temperature Range: -55°C to 100°C
Relative Humidity: 90-95% at 40°C for 96 hours
Vibration Resistance: Harmonic motion with
amplitude of 15g, within a varied 10 to 2000
Hz frequency for 12 hours per MIL-STD-202,
Method 204
Shock Resistance: Test 1: 100g for 6 mS, halfsine wave with velocity change of 12.3 ft/s. Test
2: 100g for 6 mS, sawtooth wave with velocity
change of 9.7 ft/s.
Materials and Finishes
Bushing: Zinc diecast
Housing: Zytel FR-50
Shaft: Stainless steel insert molded into nylon
rotor support
Code Rotor and Aperture: Chemically
etched stainless steel/electroformed nickel
Printed Circuit Board: NEMA Grade FR-4.
Five microinches minimum gold over 100
microinches minimum nickel over copper
Optical Barrier: Polyphenylene sulfide, 94 V-0
Backplate: Polyester
Header: Phosphor bronze, 200 microinches
tin over 50 microinches nickel (pin version only)
Infrared Emitter: Gallium aluminum arsenide
Photo IC: Planar silicon
Retaining Ring: Stainless steel
Cable: 26 AWG, stranded/tinned wire, PVC
coated on .100 (2,54) centers (cable version only)
Connector: Glass-filled PCT, UL94V-0
Bearing Subassembly
Bearing: NSK ABEC 5 (stainless steel)
Preload Collar: 303 stainless steel
Spacer: 303 stainless steel
Bellville Spring: spring steel (stainless)
Ordering Information
Series
Style: R = Standard, 5-pin, high resolution
RS = Sealed, 5-pin, high resolution
Cycles: per channel per revolution = 25, 32, 50, 64, 100, 128, 256
63RS256–060
Termination:
Blank (no dash or numbers): pins as described in drawing.
Cable Termination: 060 = 6.0in. Cable is terminated with Molex Connnector P/N 14-56-3056
Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
Encoders
Operating Voltage: 5 ±.25 Vdc
Supply Current: 30 mA maximum at 5 Vdc
Logic Output Characteristics:
Output Type: Open collector with integrated
Schmitt Trigger and 10 KW pull-up resistor
Maximum Sink Current: 16 mA at .40 volts
Power Consumption: 150 mW maximum
Optical Rise Time: 500 nS typical
Optical Fall Time: 14 nS typical
很抱歉,暂时无法提供与“63R256”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1472.517471+190.86630
- 5+1248.977805+161.89131
- 10+1160.3018110+150.39721
- 25+1049.4053225+136.02291
- 50+969.9585550+125.72510
- 100+894.08384100+115.89029
