62A15-02-060C
62A15-02-060C
    GRAYHILLINC.
    ENCODER OPT 1/2" 24POS PB 6" CBL
62A15-02-060C 数据手册
Optical Encoders SERIES 62A,V,D 1/2'' Package APPLICATIONS • Global Positioning/Driver Information Systems • Medical Equipment Optical and Mechanical Encoders FEATURES • Low Cost • Long Life • Available in 3.3 or 5.0 Vdc Operating Voltages • High Torque Version to Emphasize Rotational Feel • Economical Size • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic • Available in 12,16, 20, 24 and 32 Detent Positions (Non-detent Also Available) • Choices of Cable Length and Terminations DIMENSIONS In inches (and millimeters) Cable Version Connector Version Top Views .010 /025 (0,25/0,64) PUSHBUTTON TRAVEL 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0,76) OF SHOULDER .219 ±.003 (5,56 ±.076) .066 ± .002 (1,68 ± 0,05) .050 (1,27) Center Connector .219 ± .003 (5,56 ± 0,08) PART NUMBER AND DATE CODE LABEL .250 ± .002 (6,35 ± 0,05) DIA. .580 .540 (14,73) (13,72) for "D" style .390 (9,91) .250 (6,35) .250 ± .005 (6,35 ± 0,13) .500 (12,70) Board shown is for .050 (1,27) centers connector see top views for board dimensions (both connector options) .510 ± .015 (12,95 ± 0,38) .375 ± .015 (9,52 ± 0,38) .152 ± .002 (3,86 ± 0,05) .100 (2,54) STRIPPED AND TINNED 6 5 4 3 2 1 .525 (13,34) GRAYHILL DIM. XXX ± .20 (DIM. XXX ± 5,08) (SEE ORDERING INFORMATION FOR CABLE LENGTH) .700 (17,78) 62AXX-01-XXXC XXXX X-X .100 (2,54) Center Connector Stripped Cable Version CONNECTOR IS AMP P/N 215083-6, .050 (1,27) CENTERS P/N 640443-6, .100 (2,54) CENTERS 28 AWG CABLE WIRES ON .050 (1,27) CENTERS .320 (8,13) REF .525 ± .015 (13,34 ± 0,38) .312 (7,92) Unless otherwise specified, standard tolerance is ±.010 (0,25). Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I-6 Optical Encoders DIMENSIONS In inches (and millimeters) Pin Version .620 (15,7) 654321 GRAYHILL .470±.020 (12,0±0,5) .140±.015 (3,6±0,4) .580 (14,73) For "D" Style .066±.002 (1,68±0,05) .100(2,54)TYP .249/.250 DIA (6,32/6,35) .522 (13,26) .250 (6,35) Optical and Mechanical Encoders .450±.010 (11,43±0,3) .375±.015 (9,5±0,4) .219±.003 (5,6±0,08) .250 (6,35) XXXX X-X 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 OF SHOULDER 62AXX-XX-P .540 (13,72) .940±.050 (24,0±1,3) .602 (15,29) .797(20,2) .312 (7,9) .152 (3,9) .817(20,8) .250(6,35) Unless otherwise specified, standard tolerance is ±.010 (0.25) .500(12,7) CIRCUITRY, TRUTH TABLE, AND WAVEFORM Standard Quadrature 2-Bit Code Standard 5.0 Volt (Styles A and D) Clockwise Rotation Position Output A Output B 1 2 3 4 PIN # POWER +5V 6 R* 5 OUTPUT A 200 Ω 5% • • R* OUTPUT B 4 N.O. PUSHBUTTON SWITCH 3 • • Indicates logic high; blank indicates • logic low. Code repeats every 4 positions. 2 1 GROUND * External pull-up resistors required for operation (2.2 kΩ). 3.3 Volt (Style V only) PIN # POWER +3.3V R* OUTPUT A OUTPUT B OUTPUT A 6 5 R* 100 Ω 5% 100 Ω 5% OUTPUT B HIGH LOW HIGH LOW 4 1 N.O. PUSHBUTTON SWITCH 3 2 3 4 5 6 POSITION NUMBER 2 GROUND 1 * External pull-up resisitors required for operation (2.2k Ω) I-7 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SPECIFICATIONS Materials and Finishes Mechanical Ratings Optical Rise and Fall Times: less than 30 mS maximum Operating Torque: Style A and V: 2.0 ±1.4 in-oz. initially Style D: 3.5 ±1.4 in-oz initially Non-detent: less than 1.5 in-oz initially Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Axial Shaft Play: .010 maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 90–95% at 40°C for 96 hours Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Mechanical Shock: Test 1: 100G for 6 mS, half sine, 12.3 ft/s; Test 2: 100G for 6 mS, sawtooth, 9.7 ft/s Code Housing: Reinforced thermoplastic Shaft: Zinc or aluminum Bushing: Zinc casting Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and stainless steel lockwasher supplied with each switch. Nut is 0.094 inches thick by 0.562 inches across flats. Rotor: Thermoplastic Code Housing: Thermoplastic Pushbutton Dome: Stainless steel Dome Retaining Disk: Thermoplastic Pushbutton Housing: Thermoplastic Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Pushbutton Contact: Brass, nickel-plated Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 or .100" centers (cabled version) Header Pins: Phospher bronze, tin-plated Spacer: ABS Backplate/Strain Relief: Stainless steel ORDERING INFORMATION Series Style: A = 1/2" package, 5.0 Vdc Input, D = high torque w/5.0 Vdc input, V = 3.3 Vdc input Angle of Throw: Detent Non-detent (Styles A&V only) 11 = 11.25° or 32 positions 01 = 11.25° or 32 positions 15 = 15° or 24 positions 05 = 15° or 24 positions 18= 18° or 20 positions 08= 18° or 20 positions 22 = 22.5° or 16 positions 02 = 22.5° or 16 positions 30 = 30° or 12 positions 03 = 30° or 12 positions Pushbutton Option: 01 = w/o pushbutton, 02 = with pushbutton 62A22-01-020S Termination: S = Stripped cable; .050" centers SH = Stripped cable; .100" centers C = Connector; .050" centers CH = Connector; .100" centers P = Pin; .100" centers Cable Length: 020 = 2.0 inches minimum to 250 = 25.0 inches maximum. Provided in increments of 1/2 inch. Example 035 = 3.5", 060 = 6.0". *Eliminate cable length if ordering pins. (Ex: 62A22-02-P) These switches have Quadrature 2-bit code output and an optional shaft actuated pushbutton switch. Custom materials, styles, colors, and markings are available. Control knobs available. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I-8 Optical and Mechanical Encoders Rating: 5 Vdc, 10 mA, resistive Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations minimum Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 1000 ±300 grams Pushbutton Travel: .010/.025 inch Coding: 2-bit quadrature coded output Operating Voltage: 5.0 ±.25 Vdc, 3.30±.125 Vdc (style V only) Voltage Breakdown: 250 Vac between mutually insulated parts Supply Current: 30 mA maximum Logic Output Characterisitics: Logic High: 3.8 Vdc (5.0 Vdc); 2.3 (3.3 Vdc) minimum Logic Low: 0.8 Vdc maximum Rotational Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Minimum Sink Current: 2.0 mA for 5 Vdc; 1.0 mA for 3.3 Vdc Power Consumption: 150 mW maximum for 5 Vdc; 80 mW for 3.3 Vdc
62A15-02-060C 价格&库存
很抱歉,暂时无法提供与“62A15-02-060C”相匹配的价格&库存,您可以联系我们找货
62A15-02-060C
  • 1+730.683371+94.82937
