Optical Encoders
Series 62AG
Price Competitive Solution
FEATURES
Over 1 million rotational cycles
2-bit gray code output
Quadrature coding
Available in 16 detent positions
4 inch cable/connector assembly
RoHS compliant
Optional integrated pushbutton
Patented light pipe technology
Cost competitive with
mechanical encoders
at higher volumes
APPLICATIONS
• Automotive
- audio systems
- navigation systems
• Medical
- patient monitoring systems
• Test & Measurement
- analyzers
- oscilloscopes
• Audio & Video
- consumer electronics
- professional editing equipment
DIMENSIONS in inches (and millimeters)
Optical and Mechanical
Encoders
Unless otherwise specified, standard tolerances are:
Linear ± .025
Diameter ± .010
Angle ± 2.0 0
.152 ±.002
[3,86 ]
.066 ±.002
[1,68 ]
.500
[12,7]
.580
[14,73]
Ø.249 ±.002
[ 6,32 ]
SHAFT
[.687]
.219 ±.004
[ 5,56 ]
.250
[6,35]
.312
[ 7,92 ]
[ 17,45 ]
3/8-32 UNEF-2A THREAD
THREADS TO BE WITHIN
.030 [0,76] OF SHOULDER
NOTE: GRAYHILL ALLOWS
MULTIPLE ORIENTATIONS FOR
THE GRAYHILL TEXT ON THE
BACKPLATE.
CONNECTOR IS AMP
P/N 7-215083-6
OR EQUIVALENT
.532 ±.015
[ 13,51 ]
.512
[ 13 ]
4.00±.200
[101,6]
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
WAVEFORM AND TRUTH TABLE
POWER (+5.0 V)
OUTPUT A
6
OUTPUT B
4
PUSHBUTTON
3
PUSHBUTTON
2
GROUND
*EXTERNAL 10k
HIGH
OUTPUT A
LOW
5
POSITION
OUTPUT B
#2
HIGH
OUTPUT B
LOW
#3
#4
POS. POS. POS. POS. POS. POS.
#1
#2
#3
#4
#5
#6
1
OUTPUT A
#1
INDICATES LOGIC HIGH; BLANK INDICATES LOGIC LOW.
CODE REPEATS EVERY FOUR POSITIONS.
*CLOCKWISE SHAFT ROTATION
PULL-UP RESISTORS REQUIRED FOR OPERATION
SPECIFICATIONS
Environmental Specifications
Rotary Electrical and Mechanical
Specifications
Operating Voltage: 5.00±0.25 Vdc
Supply Current: 30 mA maximum at 5 Vdc.
Logic Output Characteristics:
Logic high shall be no less than 3.0 VdcLogic
low shall be no greater than 1.0 Vdc
Minimum sink current: 0.5 mA for 5 Vdc.
(Preliminary)
Power Consumtpion: 150 mW maximum
for 5 Vdc
Output: Open Collector Phototransistor
Optical Rise Time: 30ms maximum.
Optical Fall Time: 30ms maximum.
Average Rotational Torque:
Low = 2.0±1.4 in-oz initially.
High = 3.5±1.4 in-oz initially.
50% of initial value after 1 million cycles.
Mechanical Life: 1,000,000 cycles of
operation. 1 cycle is a rotation through all
positions and a full return.
Mounting Torque: 15in-lbs. maximum
Shaft Pushout Force: 45 lbs. minimum
Terminal Strength: 15 lbs. Cable pull out
force minimum
Solderability: 95% free of pin holes and
voids
Maximum rotational speed: 100 rpm.
Pushbutton Electrical and
Mechanical Specifications
Rating: 10 mA @ 5 Vdc
Contact Resistance:
很抱歉,暂时无法提供与“62AG22-L0-040C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+346.595401+44.84140
- 5+298.815205+38.65980
- 10+275.2185010+35.60690
- 25+241.7280025+31.27400
- 50+230.6843050+29.84520
- 100+212.01060100+27.42930
- 250+197.98440250+25.61460
- 500+197.27770500+25.52320
- 国内价格 香港价格
- 1+356.977271+46.07872
- 5+304.487965+39.30338
- 10+283.6999610+36.62006
- 25+257.7605925+33.27180
- 50+239.2090450+30.87716
- 100+221.51826100+28.59363
- 250+199.36050250+25.73351
