62AG22-L5-050C
62AG22-L5-050C
    GRAYHILLINC.
    ENCODER OPT 1/2"B 16POS 5"CABLE
62AG22-L5-050C 数据手册
Optical Encoders SERIES 62AG Price Competitive Solution FEATURES • • • • • • • • • Over 1 million rotational cycles 2-bit gray code output Quadrature coding Available in 16, 20, 24 and 32 detent positions Choices of cable length and terminations Available for 5Vdc and 3.3Vdc Optional integrated pushbutton Patented light pipe technology Cost competitive with mechanical encoders at higher volumes APPLICATIONS • Automotive - audio systems - navigation systems • Medical - patient monitoring systems • Test & Measurement - analyzers - oscilloscopes • Audio & Video - consumer electronics - professional editing equipment Optical and Mechanical Encoders DIMENSIONS in inches (and millimeters) Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 .152 ±.002 [3,86 ] .066 ±.002 [1,68 ] .500 [12,7] .580 [14,73] Ø.249 ±.002 [ 6,32 ] SHAFT .687 .219 ±.004 [ 5,56 ] .250 [6,35] .312 [ 7,92 ] [ 17,45 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER NOTE: GRAYHILL ALLOWS MULTIPLE ORIENTATIONS FOR THE GRAYHILL TEXT ON THE BACKPLATE. CONNECTOR IS AMP P/N 7-215083-6 OR EQUIVALENT .532 ±.015 [ 13,51 ] .512 [ 13 ] x.xx ± .200 [x.xx ± 5,08] Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders Termination Options SEE DETAIL KEY .290 [7,37] .250 [6,35] .500 [12,7] .125 [3,18] .250 [6,35] .420 [10,67] .580 [14,73] .219 ` .004 [ 5,56 ` 0,1 ] .250 [6,35] .687 [ +.010 -.020 17,45 +0,25 -0,50 .312 [7,92] ] n .249 ` .002 [ 6,32 ` 0,05 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .512 [13] .672 ` .020 [ 17,07 ` 0,5 ] Optical and Mechanical Encoders .532 ` .015 [ 13,51 ` 0,38 ] .370 [9,4] .016 [0,41] SQUARE 6 PLACES .050 [1,27] 5 PLACES .130 [3,3] P - .050 Center Pins with 0.185 inch length .290 [7,37] .290 [7,37] SEE DETAIL KEY .500 [12,7] .500 [12,7] .250 [6,35] .687 [ +.010 -.020 17,45 .250 [6,35] .219 ` .004 [ 5,56 ` 0,1 ] .580 [14,73] ] .250 [6,35] .512 [13] .532 ` .015 [ 13,51 ` 0,38 ] .580 [14,73] .219 ` .004 [ 5,56 ` 0,1 ] n .249 ` .002 [ 6,32 ` 0,05 ] n .249 ` .002 [ 6,32 ` 0,05 ] .312 [7,92] +0,25 -0,50 SEE DETAIL KEY 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .687 [ +.010 -.020 17,45 +0,25 -0,50 ] CONNECTOR IS AMP P/N 7-215083-6 OR EQUIVALENT XXX ` .200 [XXX ` 5,08] SEE PART NUMBER INFORMATION ON SHEET 4 C - .050 Center Ribbon Cable with connector Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .312 [7,92] .512 [13] .532 ` .015 [ 13,51 ` 0,38 ] .250 [6,35] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER .100 [2,54] CONDUCTORS ARE TOPCOATED XXX ` .200 [XXX ` 5,08] SEE PART NUMBER INFORMATION ON SHEET 4. S - .050 Center Ribbon Cable with .100 stripped end 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders WAVEFORM AND TRUTH TABLE PIN # Standard 5.0V (Style AG) 6 POWER +5V R* OUTPUT A OUTPUT B R* *10K Ω PULL-UP RESISTOR REQUIRED FOR OPERATION **NOISE FILTERING CAPACITOR, LESS THAN 1000pf 5 4 NORMALLY OPEN PUSHBUTTON SWITCH 3 GROUND 1 WAVEFORM (CW ROTATION) 6 POWER +3.3V R* OUTPUT A OUTPUT B R* 5 NORMALLY OPEN PUSHBUTTON SWITCH GROUND 1 POSITION LOW 1 HIGH 2 ** ** 2 OUTPUT B 4 LOW POSITION: OUTPUT A 3 OUTPUT B 4 3 TRUTH TABLE (CW ROTATION) HIGH OUTPUT A PIN # Standard 3.3V (Style VG) CW ROTATION ** ** 2 1 2 3 4 5 6... BLANK = LOGIC LOW = LOGIC HIGH CODE REPEATS EVERY FOUR POSITIONS. SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: AG Style 5.00±0.25 Vdc VG Style 3.30±0.125 Vdc Supply Current: AG Style 30 mA maximum VG Style 30 mA maximum Logic Output Characteristics: AG Style - Logic high no less than 3.0 Vdc. Logic low shall be no greater than 1.0 Vdc. VG Style - Logic high no less than 2.0 Vdc. Logic low shall be no greater than 1.0 Vdc. Output: Open Collector Phototransistor Optical Rise Time: 30ms maximum. Optical Fall Time: 30ms maximum. Average Rotational Torque: Low = 2.0±1.4 in-oz initially. High = 3.5±1.4 in-oz initially. 50% of initial value after 1 million cycles. Mechanical Life: 1,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return. Mounting Torque: 15in-lbs. maximum Shaft Pushout Force: 45 lbs. minimum Terminal Strength: 15 lbs. Cable pull out force minimum Solderability: 95% free of pin holes & voids Maximum rotational speed: 100 rpm. Pushbutton Electrical and Mechanical Specifications Rating: 10 mA @ 5 Vdc Contact Resistance:
62AG22-L5-050C 价格&库存
很抱歉,暂时无法提供与“62AG22-L5-050C”相匹配的价格&库存,您可以联系我们找货
62AG22-L5-050C
  • 1+400.960261+51.87492
  • 5+341.800055+44.22096
  • 10+318.4108810+41.19495
  • 25+289.1919825+37.41470
  • 50+268.2967450+34.71135
  • 100+248.36841100+32.13309
  • 250+223.40336250+28.90319
库存:25
62AG22-L5-050C
    62AG22-L5-050C
