62A15-01-060C
62A15-01-060C
    GRAYHILLINC.
    ENCODER OPT 1/2" 24POS 6" CABLE
62A15-01-060C 数据手册
Optical Encoders SERIES 62A,V,D 1/2'' Package FEATURES • Low Cost • Long Life • Available in 3.3 or 5.0 Vdc Operating Voltages • High Torque Version to Emphasize Rotational Feel • Economical Size • Optically Coupled for More than a Million Cycles • Optional Integral Pushbutton • Compatible with CMOS, TTL and HCMOS Logic Levels • Available in 12,16, 20, 24 and 32 Detent Positions (Non-detent also available) • Choice of Cable Lengths and Terminations APPLICATIONS • Global Positioning/Driver Information Systems DIMENSIONS in inches (and millimeters) Optical and Mechanical Encoders Cable Version Ø.250±.002 (6,35±0,05) .250 (6,35) 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 (0,76) OF SHOULDER. Dim A = .250 (6,35) for 62A and 62V .290 (7,37) for 62D Dim B = .540 (13,72) for 62A and 62V .580 (14,73) for 62D .375±.015 (9,52±0,38) .312 (7,92) Dim B .510±.015 (12,95±0,38) .525±.015 (13,34±0,38) 62AXX-XX-XXXC XXXX X-X GRAYHILL .250 (6,35) 654321 .500 (12,70) .066±.002 (1,68±0,05 .152±.002 (3,9±0,05) .219±.003 (5,6±0,08) .390 (9,91) Pin Version .540 (13,72) Ø.250 ±.002 (6,32±0,05) .250 (6,35) .066 ±.002 (1,68±0,05) .375 ±.015 (9,52±0.38) .250 (6,35) .500 (12,70) Dim A 3/8-32 UNEF-2A THREAD. THREADS TO BE WITHIN .030 (0,76) OF SHOULDER. .250 (6,35) .312 (7,9) GRAYHILL .602 (15,29) .152±.002 (3,9±0,05) 654321 .219±.003 (5,6±0,08) .522 .100 (2,54) TYP. .817 (20,8) .797 (20,2) 62AXX-XX-P XXXX X-X .450±.010 (11,43±0,3) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .940±.050 (24,0±1,3) .470±.020 (12,0±0,5) .140±.015 (3,6±0,4) .620 (15,7) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders TERMINATION OPTIONS S - STRIPPED CABLE , 0.050" CENTERS C - CONNECTOR , 0.050" CENTERS Optical and Mechanical Encoders CH - CONNECTOR , 0.100" CENTERS SH - STRIPPED CABLE, 0.100" CENTERS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois P - PIN, 0.100" CENTERS 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SUPPLY CURRENT & LOGIC OUTPUT CHARACTERISTICS WAVEFORM AND TRUTH TABLE Standard Quadrature 2-Bit Code Optical and Mechanical Encoders CIRCUITRY: SURFACE MOUNT OPTICS Pushpull Outputs (62A22, 62A15, 62A11) CIRCUITRY: WIREBOND OPTICS Open Collector Outputs (All Others) PIN # POWER +5V 6 R* 5 OUTPUT A R* OUTPUT B 4 N.O. PUSHBUTTON SWITCH 3 GROUND 1 2 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SPECIFICATIONS Electrical and Mechanical Ratings Optical and Mechanical Encoders Pushbutton Rating: 5 Vdc, 10 mA, resistive Pushbutton Contact Resistance: less than 10 ohms (TTL or CMOS compatible) Pushbutton Life: 3 million actuations min. Pushbutton Contact Bounce: less than 4 mS at make and less than 10 mS at break Pushbutton Actuation Force: 1000 ±300 grams Pushbutton Travel: .010/.025 inch Coding: 2-bit quadrature coded output Voltage Breakdown: 250 Vac between mutually insulated parts Rotational Life: 1,000,000 cycles minimum (One cycle is a rotation through all positions and a full return) Optical Rise and Fall Times: less than 30 mS maximum Operating Torque: Style A and V: 2.0 ±1.4 in-oz. initially Style D: 3.5 ±1.4 in-oz initially Non-detent: less than 1.5 in-oz initially Shaft Push Out Force: 45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs cable pull-out force minimum Operating Speed: 100 RPM maximum Axial Shaft Play: .010 maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 90–95% at 40°C for 96 hours Vibration Resistance: Harmonic motion with amplitude of 15G, within a varied 10 to 2000 Hz frequency for 12 hours per MIL-STD-202, Method 204 Mechanical Shock: Test 1: 100G for 6 mS, half sine, 12.3 ft/s; Test 2: 100G for 6 mS, sawtooth, 9.7 ft/s 0.435 inches across flats. Rotor: Thermoplastic Code Housing: Thermoplastic Pushbutton Dome: Stainless steel Dome Retaining Disk: Thermoplastic Pushbutton Housing: Thermoplastic Phototransistor: Planar Silicon NPN Infrared Emitter: Gallium aluminum arsenide Pushbutton Contact: Brass, nickel-plated Flex Cable: 28 AWG, stranded/top coated wire, PVC coated on .050 or .100" centers (cabled version) Header Pins: Phospher bronze, tin-plated Spacer: ABS Backplate/Strain Relief: Stainless steel Materials and Finishes Code Housing: Reinforced thermoplastic Shaft: Zinc or aluminum Bushing: Zinc casting Shaft Retaining Ring: Stainless steel Detent Spring: Stainless steel Printed Circuit Boards: NEMA grade FR-4 gold over nickel or palladium Terminals: Brass, tin-plated Mounting Hardware: One brass, nickel-plated nut and zinc-plated spring steel with clear trivalent chromate finish lockwasher supplied with each switch. Nut is 0.094 inches thick by ORDERING INFORMATION Series Style: A = 1/2" package, 5.0 Vdc Input, D = high torque w/5.0 Vdc input, V = 3.3 Vdc input Angle of Throw: Detent Non-detent (Styles A&V only) 11 = 11.25° or 32 positions 01 = 11.25° or 32 positions 15 = 15° or 24 positions 05 = 15° or 24 positions 18= 18° or 20 positions 08= 18° or 20 positions 22 = 22.5° or 16 positions 02 = 22.5° or 16 positions 30 = 30° or 12 positions 03 = 30° or 12 positions Pushbutton Option: 01 = w/o pushbutton, 02 = with pushbutton 62A22-01-040S Termination: S = Stripped cable; .050" centers SH = Stripped cable; .100" centers C = Connector; .050" centers CH = Connector; .100" centers P = Pin; .100" centers Cable Length: Cable Terminination: 040 = 4.0in. Cable is terminated with Amp P/N 215083-6. See Amp Mateability Guide for Mating Connector details. *Eliminate cable length if ordering pins. (Ex: 62A22-02-P). These switches have Quadrature 2-bit code output and an optional shaft actuated pushbutton switch. Custom materials, styles, colors, and markings are available. Control knobs available. Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
62A15-01-060C 价格&库存
很抱歉,暂时无法提供与“62A15-01-060C”相匹配的价格&库存,您可以联系我们找货
62A15-01-060C
    • 2+514.40719
    • 25+386.18270
    • 100+347.56563
    库存:101
    62A15-01-060C
    • 4+384.38688
    • 9+377.22114
    • 17+370.05541
    • 25+355.87085
    • 100+320.30334
    库存:130
    62A15-01-060C
      • 2+411.209322+53.43770
      • 25+308.6896025+40.11500
      • 100+277.82064100+36.10350
      库存:101
