Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product.
Optical Encoders
SERIES 62SG
Compact / Cost Effective
FEATURES
• Just 0.3-inch behind panel depth
• Over 1 million rotational cycles
• 2-bit gray code output
• Quadrature coding
• Available in 16, 24 and 32 detent positions
• Optional integrated pushbutton
• Light pipe technology
• Cost competitive with mechanical
encoders at higher volumes
APPLICATIONS
• Automotive
- audio systems
- navigation systems
• Medical
- patient monitoring systems
• Test & Measurement
- analyzers
- oscilloscopes
• Audio & Video
- consumer electronics
- professional editing equipment
DIMENSIONS in inches (and millimeters)
SUGGESTED MOUNTING PANEL CUTOUT
Optical and Mechanical
Encoders
.161 ± .002
[ 4,09 ± 0,05 ]
Ø .380 ± .003
[ 9,65 ± 0,07 ]
.057 ± .002
[ 1,45 ± 0,05 ]
Unless otherwise specified, standard tolerances are:
Linear ± .025
Diameter ± .010
Angle ± 2.0 0
OTHER TERMINATION OPTIONS
P/N JST SHROUDED HEADER
SM08B-GHS-TB MATING CONNECTOR
P/N JST HOUSING GHR-08V-S
RAC
Right Angle
AngleConnector
Connector
RAC -- Right
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
.050”
.050”Stripped
Stripped Cable
Cable
.050”
.050”Pin
Pin Header
Header
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Optical Encoders
WAVEFORM AND TRUTH TABLE
SPECIFICATIONS
Environmental Specifications
Rotary Electrical and
Mechanical Specifications
Operating Voltage: 5.00 ± 0.25 Vdc
Supply Current: 30 mA maximum
Logic Output Characteristics:
Logic High: VOH = 3.0 Vdc MIN at VCC = 4.75
Vdc with 10 kΩ PULL-UP RESISTOR
Logic Low: VOL = 1.0 Vdc MAX at VCC = 5.25
Output: Open Collector Phototransistor
Optical Rise Time: 30ms maximum
Optical Fall Time: 30ms maximum
Mechanical Life: 1,000,000 cycles of
operation. 1 cycle is a rotation through all
positions and a full return
Mounting Torque: 15in-lbs. maximum
Shaft Pushout Force: 45 lbs. minimum
Terminal Strength: 15 lbs. cable pull out
force minimum
Solderability: 95% free of pin holes & voids
Pushbutton Electrical and
Rating: 30 mA @ 5 Vdc
Contact Resistance:
很抱歉,暂时无法提供与“62SG11-M5-060C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+365.004611+46.81918
- 5+311.273315+39.92706
- 10+290.0097310+37.19958
- 25+263.4771525+33.79624
- 50+244.4990050+31.36192
- 100+226.40240100+29.04066
- 250+203.73367250+26.13294
- 国内价格
- 100+187.13245
- 5000+181.09904
