62NG511-LH5-06C
62NG511-LH5-06C
    GRAYHILLINC.
    ENCODER WITH NON-TURN, CONCENTRI
62NG511-LH5-06C 数据手册
Optical Encoders SERIES 62NG Encoder with a Separate Non-rotating Pushbutton Shaft FEATURES • Non-turn pushbutton to ensure pushbutton text and orientation • Low cost version of our popular 62N series • Patented light pipe technology • Optically coupled for more than a million cycles • Available for 5 Vdc & 3.3 Vdc • Available in 16, 20, 24, and 32 detent positions • Choices of cable length and terminations APPLICATIONS • Global positioning • Driver information systems • Ultrasound, patient monitor and other medical equipment • Commercial and military cockpit controls DIMENSIONS in inches (and millimeters) SEE NOTE 1 SEE NOTE 1 Optical and Mechanical Encoders .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] SEE NOTE 1 SEE NOTE 1 .057 ± .002 [ 1,45 ± 0,05 ] NEW SEE NOTE 1 SEE NOTE 1 P/N JST SHROUDED HEADER SM08B-GHS-TB MATING CONNECTOR P/N JST HOUSING GHR-08V-S Unless otherwise specified, standard tolerances are ±0.010” NOTE 1 - Features are only present on ball & spring detent style encoders Connector TERMINATION OPTIONS M AT I N G C O N N E C T O R AMP P/N 7-215079-6 .050” Connector Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .050” Stripped Cable .050” Pin Header 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders SPECIFICATIONS Pushbutton Switch Ratings Shaft Pushout / Pullout Force: 45 lbs/45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs minimum cable or header pullout force, MIL-STD-202, Method 211A, Test Condition A Solderbility: 95% free of pin holes and voids, MIL-STD-202, Method 208 Electrical Rating: at 24 Vdc max, 10 mA, resistive Contact Resistance: less than 10 ohms Pushbutton Life Expectancy: 1 million actuations minimum Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 5 = 455 ±140 g Pushbutton Travel: .019±.008 in Environmental Ratings Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: NG5: 5.0 ±.25 Vdc, NG3: 3.3 ±.125 Vdc Supply Current: NG5: 30 mA maximum @5.0 Vdc, NG3: 30 mA maximum @3.3 Vdc Logic Output Characterisitics: Logic High: NG5: 3.0 Vdc minimum, NG3: 2.0 Vdc minimum Logic Low: NG5: 1.0 Vdc maximum, NG3: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles (one cycle is a rotation through all positions and a full return) Max Rotational Speed: 100 RPM Operating Temperature Range: -40°C to 85°C, IEC 68-2-1, Test Aa and IEC 68-2-2, Test Aa Storage Temperature Range: -40°C to 85°C, IEC 68-2-1, Method Aa and IEC 68-2-2, Method Ba Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s, MIL-STD-202, Method 213, Test Condition C and I Relative Humidity: 90–95% at 40°C for 96 hours, MIL-STD-202, Method 103B Mechanical Vibration: Harmonic motion with amplitude 15G within a varied 10 - 2000Hz frequency for 12 hours, MIL-STD-202, Method 204, Test Condition B Materials and Finishes Shafts: Zinc Bushing: Zinc Header Pins: Tin- plated phosphor bronze Hex Nut: Nickel plated brass Lockwasher: Spring steel, zinc plate with clear trivalent chromate finish Cable: Copper stranded with topcoat in PVC insulation (cable version only) EMC Ratings Radiated Immunity: Meets IEC 61000-4-3, level 3 Conducted Immunity: Meets IEC 61000-4-6, level 3 Radiated Emissions: Meets ANSI C63.4 Conducted Emissions: Meets EN 55022 Electrostatic Discharge: Meets IEC 61000-4-2 Power Frequency Magnetic Field: Meets IEC 61000-4-8 Optical and Mechanical Encoders CIRCUITRY, TRUTH TABLE, AND WAVEFORM (5V NG5) 3V NG3 ORDERING INFORMATION Grayhill Series Number Voltage: 5 = 5.0V; 3 = 3.3V Angle of Throw : 11 = 11.25° - 32 positions 62NGXXX-XXX-XXX 15 = 15.00° - 24 positions 18 = 18.00° - 20 positions 22 = 22.50° - 16 positions Detent Style: L = Leaf Spring B = Ball & Spring Rotational Torque: L = Low Torque H = High Torque Termination: S = .050” Stripped Cable C = .050” Connector 02 = 2.00” Cable P = .050” Header 03 = 3.00” Cable RAC = Shrouded Header 04 = 4.00” Cable 05 = 5.00” Cable 06 = 6.00” Cable Leave blank if header or RAC Cable Length: Pushbutton: 5 = 455±150 g Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois LEAF SPRING DETENT STYLE BALL & SPRING DETENT STYLE 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
62NG511-LH5-06C 价格&库存
很抱歉,暂时无法提供与“62NG511-LH5-06C”相匹配的价格&库存,您可以联系我们找货
