62B22-LPP-025C
62B22-LPP-025C
    GRAYHILLINC.
    OPTICAL ENCODER
62B22-LPP-025C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62B Push-Pull, High Torque FEATURES • Multiple Switching Functions Available in One Compact Device • Push and Pull Travel Options • Pull Shaft Resists Accidental Actuation • High Rotational Torque for Positive Detent Feel and Superior Tactile Feedback • Long Life, High Reliability • CMOS, HCMOS, and TTL Compatible • Pin, Cable and Connector with Cable Termination Options • Custom Modifications Available APPLICATIONS • Use for Menu Scrolling or • Function Selection • Avionics • Industrial • Medical DIMENSIONS in inches (and millimeters) Connector Version Pinned Version Stripped Version .430 (10,92) Optical and Mechanical Encoders DIM "A" SEE CHART SHAFT-DETENT POSITION CHART .350 (8,89) (.050 SPC X 7) .219.004 (5,560,1) 1.183±.015 (30,05±0,38) 4.000±.20 .400 (10,16) .335 (8,51) .161 ± .002 [ 4,09 ± 0,05 ] .500 (12,7) 11.25 5.625 Ø .250.001) (6,350,02) .312 (7,92) .707 (17,96) 3/8-32 UNEF-2A THREAD .395.015 (10,030,38) Suggested Mounting Panel Cutout DIM "A" 16 32 *SHAFT SHOWN IN A DETENT POSITION Ø.687 (17,45) CONNECTOR IS AMP P/N 215083-8 OR EQUIVALENT # POS .250.004 (6,350,1) 1.045 (26,54) 1.080.015 (27,430,38) Ø .380 ± .003 [ 9,65 ± 0,07 ] .110 (2,79) .100 (2,54) XXX.20 SEE ORDERING INFO *TOLERANCES.010 U.O.S. .057 ± .002 [ 1,45 ± 0,05 ] SWITCH SCHEMATIC, WAVEFORM, AND TRUTH TABLE POWER (5V) 8 R* OUTPUT A OUTPUT B 7 R* 6 PULLBUTTON 5 PULLBUTTON 4 PUSHBUTTON 3 PUSHBUTTON 2 GROUND *EXTERNAL 2.2k Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 1 PULL-UP RESISTANCE REQUIRED FOR OPERATION. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders WAVEFORM AND TRUTH TABLE Standard Quadrature 2-Bit Code HIGH OUTPUT "A" OUTPUT "B" LOW 1 2 HIGH LOW Clockwise Rotation Position 3 1 2 3 4 5 POSITION NUMBER 6 4 Output A Output B • • • • •  Indicates logic high; blank indicates logic low. Code repeats every 4 positions. SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: 5.00±.25 Vdc Supply Current: 30 mA maximum at 5 Vdc Output: Open collector phototransistor, external pull-up resistors are required Output Code: Two-bit quadrature, channel A leads channel B by 900 electrically during clockwise rotation of the shaft Logic Output Characteristics: Logic high signal shall be no less than 3.0 Vdc Logic low signal shall be no greater than 1.0 Vdc Minimum Sink Current: 2.0 mA Power Consumption: 150 mW maximum Mechanical Life: 1 million rotational cycles of operation. One cycle is a rotation through all positions and a full return Average Rotational Torque: 16 position: 5.0 ± 1.5 in-oz, 32-position: 2.5 ±1 .5 in-oz. Torque shall be within 50% of initial value throughout life Mounting Torque: 15 in-oz maximum Shaft Push-Out Force: 45 lbs minimum Shaft Pull-Out Force: 20 lbs minimum Terminal Strength: 15 lbs minimum terminal pull-out force for cable or header termination Solderability: 95% free of pin holes and voids Pull-Button/Push-Button Electrical and Mechanical Specifications Rating: 10 mA at 5 Vdc Contact Resistance:
62B22-LPP-025C 价格&库存
很抱歉,暂时无法提供与“62B22-LPP-025C”相匹配的价格&库存,您可以联系我们找货
