25LB22-G-Z
25LB22-G-Z
    GRAYHILLINC.
    ENCODER ROTARY 16 POS W/BRACKET
25LB22-G-Z 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Mechanical Encoders SERIES 25L Hex, Gray and Quadrature Code FEATURES • Price Competitive to Similar Designs • Quality Construction and Contact Materials • Multiple Code and Indexing Choices • 100,000 Life Cycles • Less than 1.0" Square • Manufactured to ISO 9001 Standards DIMENSIONS in inches (and millimeters) .925 ± .010 (23,50 ± 0,25) .343 ± .025 (8,71 ± 0,64) .865 ± .015 (21,97 ± 0,38) .250 ± .015 (6,35 ± 0,38) .045 ± .005 (1,14 ± 0,13) .865 ± .015 (21,97 ± 0,38) Optical and Mechanical Encoders 1.020 ± .010 (25,91 ± 0,25) 3/8-32 UNEF-2A THREAD .025 ± .002 (0,64 ± 0,05) SQUARE PIN (3 PLACES) Ø .470 ± .010 (11,94 ± 0,25) NON-TURN C L TAB .250 + .001 –.002 (6,35 + 0,03 –0,05) DIA. .320 ± .010 (8,13 ± 0,25) .400 ± .015 (10,16 ± 0,38) CL BUSHING FLATS CL .500 ± .010 (12,7 ± 0,25) .250 ± .015 (6,35 ± 0,38) .500 ± .015 (12,7 ± 0,38) NON-TURN TAB Ø .120 ± .005 (3,05 ± 0,13) WIDE BY .068 ± .005 (1,73 ± 0,13) THICK CL .590 ± .010 (14,97 ± 0,25) .250 ± .010 (6,35 ± 0,25) MOUNTING BRACKET .219 ± .004 (5,56 ± 0,10) 90˚ .100 ± .005 (2,54 ± 0,13) TYP. CL SHAFT FLAT LOCK TAB (2) FOR MOUNTING BRACKET 25J5155 TRUTH TABLES Switch Position 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Clockwise Rotation Clockwise Rotation 4-Bit Gray Code-16 Position 4-Bit Binary Code Hexadecimal-16 Position Code Position 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 1 2 Output 4 8 Indicates closed circuit; blank indicates open circuit. Switch Position 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Code Position 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 OUTPUT B HIGH LOW HIGH LOW 1 2 3 4 5 2 4 Quadrature 2-Bit Code 1/4 Cycle per Detent 8 Indicates closed circuit; blank indicates open circuit. Quadrature 2-bit Code Output Table for CW Rotation OUTPUT A 1 Output Clockwise Rotation 6 POSITION NUMBER Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Switch Position 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 "A" Output "B" Indicates closed circuit; blank indicates open circuit. Code repeats every 4 positions. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Mechanical Encoders SPECIFICATIONS Electrical Ratings Switching Loads: 1.5 mA at 115 Vac, resistive; 150 mA at 14 Vdc, resistive Current Carrying Capacity: 250 mA maximum at 28 Vdc, resistive load Contact Resistance: 75 mΩ, typical Insulation Resistance: 1000 mΩ minimum between terminals Voltage Breakdown: 1000 Vac minimum between terminals Life Expectancy: 100,000 cycles of operation at rated loads. One cycle of operation is a rotation through all of the active positions and a return to the starting position. Mechanical Ratings PCB MOUNTING PATTERN Optical and Mechanical Encoders Rotational Torque: 2 to 6 in-oz Operating Temperature Range: -40 C° to +85 C° Storage Temperature Range: -65 C° to +85 C° Continuous Rotation: All standard switches are continuous rotation. Desired stop locations supplied upon request. Anti-Rotation Device: Integral non-turn tab, flatted bushing, .375" diameter, .320 double “D” across flats. Termination: Standard is PC style, parallel to shaft, facing rear. Options include PC, parallel to shaft, facing front. Panel Mounting Torque: 10 in-lbs maximum Materials and Finishes Bushing/Housing and Shaft/Rotor: Reinforced thermoplastic Detent Ball: Stainless steel, nickel-plated Detent Spring: Tinned music wire Contacts: Beryllium copper, gold plate over nickel Terminals: Copper alloy, #725, 100% tin plate over nickel plate Output Board: FR-4, copper/nickel-plated Mounting Nut: Brass, tin/zinc-plated hex nut Mounting Bracket: Stainless Steel, tin-plated RECOMMENDED PANEL CUTOUT ORDERING INFORMATION Series: 25L = Economical, single deck encoder Housing Color: B = Black housing; R = Red housing Angle of Throw: 10 = 10°, 36 positions; 11 = 11.25°, 32 positions; 15 = 15°, 24 positions; 18 = 18°, 20 positions; 22 = 22.5°, 16 positions; 30 = 30°, 12 positions; 45 = 45°, 8 positions 25LB10-Q-Z Mounting Bracket: Z = with bracket, Blank = no bracket Code Output: H = Hexadecimal available only in 22.5° G = Gray available only in 22.5° Q = Quadrature (2-bit) Custom materials, styles, color and markings are available. Custom knobs available. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized Distributor or Grayhill. For Custom codes. Termination, Torque, Angles of Throw, call Grayhill for more information. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
25LB22-G-Z 价格&库存
很抱歉,暂时无法提供与“25LB22-G-Z”相匹配的价格&库存,您可以联系我们找货
25LB22-G-Z
    25LB22-G-Z
    • 25+337.3706525+43.27457
    25LB22-G-Z
