62NG515-LH5-02C
62NG515-LH5-02C
    GRAYHILLINC.
    ENCODER WITH NON-TURN, CONCENTRI
62NG515-LH5-02C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62NG Encoder with a Separate Non-rotating Pushbutton Shaft FEATURES • Non-turn pushbutton to ensure pushbutton text and orientation • Low cost version of our popular 62N series • Patented light pipe technology • Optically coupled for more than a million cycles • Available for 5 Vdc & 3.3 Vdc • Available in 16, 20, 24, and 32 detent positions • Choices of cable length and terminations APPLICATIONS • Global positioning • Driver information systems • Ultrasound, patient monitor and other medical equipment • Commercial and military cockpit controls DIMENSIONS in inches (and millimeters) SEE NOTE 1 SEE NOTE 1 SUGGESTED MOUNTING PANEL CUTOUT .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] Optical and Mechanical Encoders SEE NOTE 1 .057 ± .002 [ 1,45 ± 0,05 ] SEE NOTE 1 SEE NOTE 1 SEE NOTE 1 Unless otherwise specified, standard tolerances are ±0.010” NOTE 1 - Features are only present on ball & spring detent style encoders OTHER TERMINATION OPTIONS P/N P/NJST JSTSHROUDED SHROUDEDHEADER HEADER SM08B-GHS-TB SM08B-GHS-TBMATING MATINGCONNECTOR CONNECTOR P/N P/NJST JSTHOUSING HOUSINGGHR-08V-S GHR-08V-S RAC- -Right RightAngle AngleConnector Connector RAC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .050” .050”Stripped StrippedCable Cable .050”Pin PinHeader Header .050” 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SPECIFICATIONS Pushbutton Switch Ratings Electrical Rating: at 24 Vdc max, 10 mA, resistive Contact Resistance: less than 10 ohms Pushbutton Life Expectancy: 1 million actuations minimum Contact Bounce: less than 4 mS at make and less than 10 mS at break Actuation Force: 5 = 455 ±140 g Pushbutton Travel: .019±.008 in Encoder Ratings Coding: 2-bit quadrature coded output Operating Voltage: NG5: 5.0 ±.25 Vdc, NG3: 3.3 ±.125 Vdc Supply Current: NG5: 30 mA maximum @5.0 Vdc, NG3: 30 mA maximum @3.3 Vdc Logic Output Characterisitics: Logic High: NG5: 3.0 Vdc minimum, NG3: 2.0 Vdc minimum Logic Low: NG5: 1.0 Vdc maximum, NG3: 1.0 Vdc maximum Mechanical Life: 1,000,000 cycles (one cycle is a rotation through all positions and a full return) Max Rotational Speed: 100 RPM Shaft Pushout / Pullout Force: 45 lbs/45 lbs minimum Mounting Torque: 15 in-lbs maximum Terminal Strength: 15 lbs minimum cable or header pullout force, MIL-STD-202, Method 211A, Test Condition A Solderbility: 95% free of pin holes and voids, MIL-STD-202, Method 208 Environmental Ratings Operating Temperature Range: -40°C to 85°C, IEC 68-2-1, Test Aa and IEC 68-2-2, Test Aa Storage Temperature Range: -40°C to 85°C, IEC 68-2-1, Method Aa and IEC 68-2-2, Method Ba Mechanical Shock: Test 1: 100G, 6 mS, half sine, 12.3 ft/s; Test 2: 100G, 6 mS, sawtooth, 9.7 ft/s, MIL-STD-202, Method 213, Test Condition C and I Relative Humidity: 90–95% at 40°C for 96 hours, MIL-STD-202, Method 103B Mechanical Vibration: Harmonic motion with amplitude 15G within a varied 10 - 2000Hz frequency for 12 hours, MIL-STD-202, Method 204, Test Condition B Materials and Finishes Shafts: Zinc Bushing: Zinc Header Pins: Tin- plated phosphor bronze Hex Nut: Nickel plated brass Lockwasher: Spring steel, zinc plate with clear trivalent chromate finish Cable: Copper stranded with topcoat in PVC insulation (cable version only) EMC Ratings Radiated Immunity: Meets IEC 61000-4-3, level 3 Conducted Immunity: Meets IEC 61000-4-6, level 3 Radiated Emissions: Meets ANSI C63.4 Conducted Emissions: Meets EN 55022 Electrostatic Discharge: Meets IEC 61000-4-2 Power Frequency Magnetic Field: Meets IEC 61000-4-8 Optical and Mechanical Encoders CIRCUITRY, TRUTH TABLE, AND WAVEFORM (5V ) ORDERING INFORMATION Grayhill Series Number Voltage: 5 = 5.0V; 3 = 3.3V Angle of Throw : 11 = 11.25° - 32 positions 62NGXXX-XXX-XXX 15 = 15.00° - 24 positions 18 = 18.00° - 20 positions 22 = 22.50° - 16 positions Detent Style: L = Leaf Spring B = Ball & Spring Rotational Torque: L = Low Torque H = High Torque Termination: S = .050” Stripped Cable C = .050” Connector P = .050” Header RAC = Right Angle Connector .050” centers (See JST Connector Guide for mating connector details) *Eliminate cable length if ordering “P” or “RAC” termination option Cable Length: 02 = 2.00” Cable 04 = 4.00” Cable 06 = 6.00” Cable Pushbutton: 5 = 455±150 g *62NG515-BL5-RAC available as standard P/N, for additional options, please contact Grayhill Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois LEAF SPRING DETENT STYLE BALL & SPRING DETENT STYLE 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
62NG515-LH5-02C 价格&库存
很抱歉,暂时无法提供与“62NG515-LH5-02C”相匹配的价格&库存,您可以联系我们找货
62NG515-LH5-02C
