25BP15-Q-1-24F
25BP15-Q-1-24F
    GRAYHILLINC.
    ENCODER MECH PC 24POS SNGL
25BP15-Q-1-24F 数据手册
Mechanical Encoders SERIES 25 Multi-Deck FEATURES • Multiple Code and Indexing Choices • Reliability Tested to Listed Specifications • Less than 1.0" Square • Termination Choices • Panel and Shaft Seal Option • Manufactured to ISO 9001 and Military Standards • Custom Configurations Available DIMENSIONS In inches (and millimeters) Optical and Mechanical Encoders DIM. A ± .025 (DIM A ± 0,64) .250 ± .015 (6,35 ± 0,38) .320 ± .010 (8,13 ± 0,25) .865 ± .015 (21,97 ± 0,38) .365 ± .020 (9,27 ± 0,51) .219 ± .005 (5,56 ± 0,13) PART NUMBER, DATE CODE, AND PINOUT ID LABEL ‡ .250 + .001 - .002 (6,35 + 0,03 - 0,05) .865 ± .015 (21,97 ± 0,38) .250 ± .020 (6,35 ± 0,51) .060 ± .015 (1,53 ± 0,38) .375 (9,53) 3/8-32 UNEF-2A THREAD .190 ± .015 (4,83 ± 0,38) .050 ± .005 (1,27 ± 0,13) .020 ± .005 (0,51 ± 0,13) .288 ± .015 (7,31 ± 0,38) .100 ± .010 (2,54 ± 0,25) TYP. Encoder 2 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois CL CL .200 ± .015 (5,08 ± 0,38) Number of Decks 1 2 3 4 Dimension A .450 (11,43) .650 (16,51) .850 (21,59) 1.050 (26,67) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Mechanical Encoders SPECIFICATIONS Electrical Ratings Mechanical Ratings Materials and Finishes Switching Loads: 150 mA at 120 Vac, resistive; 150 mA at 28 Vdc, resistive Current Carrying Capacity: 250 mA at 28 Vdc, resistive Contact Resistance: 75 m: maximum after life Insulation Resistance: 1000 m: minimum between terminals and shaft Voltage Breakdown: 1000 Vac minimum between terminals and shaft Life Expectancy: 50,000 cycles at rated loads Contacts: Shorting Stop Strength: 10 in-lbs minimum Rotational Torque: 4-20 in-oz, dependent on the number of decks Operating Temperature Range: -65°C to +85°C Non-Turn Device: Flatted mounting bushing, .375" dia. x .320" Package Size: .865" square Termination: PC terminals, .100" on center. Decks are .200" apart. Bushing: Die cast zinc alloy, tin-zinc plated Mounting Hardware: plated brass Decks, Deck Separators, End Plate: Thermoplastic Contacts and Terminals: Gold, silver, nickelplated beryllium copper Shaft, Stop Blades: Stainless Steel Detent Balls: Steel, nickel-plated Rivets: Brass, zinc-plated ORDERING INFORMATION Optical and Mechanical Encoders Series 25: Multi-deck Shaft size: B = 1/4" diameter shaft Sealed or non-sealed: S = Shaft and panel seal; No letter = no seal Terminal structure: P = PC, perpendicular to shaft; R = PC, rear facing (one deck only); F = PC, front facing (one deck only). Angle of throw (determines the maximum number of positions): 10 = 10°, 36 positions; 11 = 11.25°, 32 positions; 12 = 12°, 30 positions; 15 = 15°, 24 positions; 18 = 18°, 20 positions; 22 = 22.5°, 16 positions; 30 = 30°, 12 positions; 45 = 45°, 8 positions; 60 = 60°, 6 positions; 90 = 90°, 4 positions. 25BSP22–Q–1–16 C Stop arrangement: For switches with maximum positions, add C for continuous rotation; add F for stop between first and last. No notation required for less than maximum positions. Number of positions: Maximum is dependent on the angle of throw. Minimum is two. Number of decks: One through four possible. Code output: B = Binary available in 22.5° Q = Quadrature G = Gray available in 22.5° Specials include 1/8 " diameter shaft, custom angles of throw for binary, binary complement and gray code outputs. Contact Grayhill Sales for availability. Control knobs available, see page I-57. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Encoder 3
25BP15-Q-1-24F 价格&库存
很抱歉,暂时无法提供与“25BP15-Q-1-24F”相匹配的价格&库存,您可以联系我们找货
