28015
28015
    PARALLAXINC.
28015 数据手册
Web Site: www.parallax.com Forums: forums.parallax.com Sales: sales@parallax.com Technical: support@parallax.com Office: (916) 624-8333 Fax: (916) 624-8003 Sales: (888) 512-1024 Tech Support: (888) 997-8267 PING))) Ultrasonic Distance Sensor (#28015) The Parallax PING)))™ ultrasonic distance sensor provides precise, non-contact distance measurements from about 2 cm (0.8 inches) to 3 meters (3.3 yards). It is very easy to connect to microcontrollers such as the BASIC Stamp®, Propeller chip, or Arduino, requiring only one I/O pin. The PING))) sensor works by transmitting an ultrasonic (well above human hearing range) burst and providing an output pulse that corresponds to the time required for the burst echo to return to the sensor. By measuring the echo pulse width, the distance to target can easily be calculated. Features       Key Specifications Range: 2 cm to 3 m (0.8 in to 3.3 yd) Burst indicator LED shows sensor activity Bidirectional TTL pulse interface on a single I/O pin can communicate with 5 V TTL or 3.3 V CMOS microcontrollers Input trigger: positive TTL pulse, 2 µs min, 5 µs typ. Echo pulse: positive TTL pulse, 115 µs minimum to 18.5 ms maximum. RoHS Compliant        Supply voltage: +5 VDC Supply current: 30 mA typ; 35 mA max Communication: Positive TTL pulse Package: 3-pin SIP, 0.1” spacing (ground, power, signal) Operating temperature: 0 – 70° C. Size: 22 mm H x 46 mm W x 16 mm D (0.84 in x 1.8 in x 0.6 in) Weight: 9 g (0.32 oz) Pin Definitions GND 5V SIG Ground (Vss) 5 VDC (Vdd) Signal (I/O pin) The PING))) sensor has a male 3-pin header used to supply ground, power (+5 VDC) and signal. The header may be plugged into a directly into solderless breadboard, or into a standard 3wire extension cable (Parallax part #800-00120). Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 1 of 9 Dimensions Communication Protocol The PING))) sensor detects objects by emitting a short ultrasonic burst and then "listening" for the echo. Under control of a host microcontroller (trigger pulse), the sensor emits a short 40 kHz (ultrasonic) burst. This burst travels through the air, hits an object and then bounces back to the sensor. The PING))) sensor provides an output pulse to the host that will terminate when the echo is detected, hence the width of this pulse corresponds to the distance to the target. Host Device PING))) Sensor Input Trigger Pulse tOUT 2 µs (min), 5 µs typical Echo Holdoff tHOLDOFF 750 µs Burst Frequency tBURST 200 µs @ 40 kHz Echo Return Pulse Minimum tIN-MIN 115 µs Echo Return Pulse Maximum tIN-MAX Delay before next measurement Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) 18.5 ms 200 µs v2.0 2/4/2013 Page 2 of 9 Practical Considerations for Use Object Positioning The PING))) sensor cannot accurately measure the distance to an object that: a) is more than 3 meters away, b) that has its reflective surface at a shallow angle so that sound will not be reflected back towards the sensor, or c) is too small to reflect enough sound back to the sensor. In addition, if your PING))) sensor is mounted low on your device, you may detect sound reflecting off of the floor. a. b. c. Target Object Material In addition, objects that absorb sound or have a soft or irregular surface, such as a stuffed animal, may not reflect enough sound to be detected accurately. The PING))) sensor will detect the surface of water, however it is not rated for outdoor use or continual use in a wet environment. Condensation on its transducers may affect performance and lifespan of the device. Air Temperature Temperature has an effect on the speed of sound in air that is measurable by the PING))) sensor. If the temperature (°C) is known, the formula is: Cair  331.5  0.6  TC  m/s The percent error over the sensor’s operating range of 0 to 70 ° C is significant, in the magnitude of 11 to 12 percent. The use of conversion constants to account for air temperature may be incorporated into your program (as is the case in the example BS2 program given in the Example Programs section below). Percent error and conversion constant calculations are introduced in Chapter 2 of Smart Sensors and Applications, a Stamps in Class text available for download from the 28029 product page at www.parallax.com. Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 3 of 9 Test Data The test data on the following pages is based on the PING))) sensor, tested in the Parallax lab, while connected to a BASIC Stamp microcontroller module. The test surface was a linoleum floor, so the sensor was elevated to minimize floor reflections in the data. All tests were conducted at room temperature, indoors, in a protected environment. The target was always centered at the same elevation as the PING))) sensor. Test 1 Sensor Elevation: Target: Copyright © Parallax Inc. 40 in. (101.6 cm) 3.5 in. (8.9 cm) diameter cylinder, 4 ft. (121.9 cm) tall – vertical orientation PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 4 of 9 Test 2 Sensor Elevation: Target: Copyright © Parallax Inc. 40 in. (101.6 cm) 12 in. x 12 in. (30.5 cm x 30.5 cm) cardboard, mounted on 1 in. (2.5 cm) pole Target positioned parallel to backplane of sensor PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 5 of 9 Example Programs BASIC Stamp 2 This circuit allows you to quickly connect your PING))) sensor to a BASIC Stamp® 2 via the Board of Education® breadboard area. The PING))) module’s GND pin connects to Vss, the 5 V pin connects to Vdd, and the SIG pin connects to I/O pin P15. This circuit will work with the example BASIC Stamp program listed below. Extension Cable and Port Cautions for the Board of Education If you are connecting your PING))) sensor to a Board of Education platform using an extension cable, follow these steps: 1. When plugging the cable onto the PING))) sensor, connect Black to GND, Red to 5 V, and White to SIG. 2. Check to see if your Board of Education servo ports have a jumper, as shown at right. 3. If your Board of Education servo ports have a jumper, set it to Vdd as shown. Then plug the cable into the port, matching the wire color to the labels next to the port. 4. If your Board of Education servo ports do not have a jumper, do not use them with the PING))) sensor. These ports only provide Vin, not Vdd, and this may damage your PING))) sensor. Go to the next step. 5. Connect the cable directly to the breadboard with a 3-pin header as shown above. Then, use jumper wires to connect Black to Vss, Red to Vdd, and White to I/O pin P15. Board of Education Servo Port Jumper, Set to Vdd Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 6 of 9 Example Program: PingMeasureCmAndIn.bs2 This program for the BASIC Stamp 2 displays distance measurements in both inches and centimeters in the BASIC Stamp Debug Terminal. The example program can be downloaded from the 28015 product page at www.parallax.com. The BASIC Stamp Editor software, which includes the Debug Terminal, is a free download from www.parallax.com/basicstampsoftware. ' Smart Sensors and Applications - PingMeasureCmAndIn.bs2 ' Measure distance with Ping))) sensor and display in both in & cm ' {$STAMP BS2} ' {$PBASIC 2.5} ' Conversion constants for room temperature measurements. CmConstant CON 2260 InConstant CON 890 cmDistance inDistance time VAR VAR VAR Word Word Word DO PULSOUT 15, 5 PULSIN 15, 1, time cmDistance = cmConstant ** time inDistance = inConstant ** time DEBUG HOME, DEC3 cmDistance, " cm" DEBUG CR, DEC3 inDistance, " in" PAUSE 100 LOOP Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 7 of 9 Propeller Microcontroller {{ *************************************** * Ping))) Object V1.1 * * (C) 2006 Parallax, Inc. * * Author: Chris Savage & Jeff Martin * * Started: 05-08-2006 * *************************************** Interface to Ping))) sensor and measure its ultrasonic travel time. Measurements can be in units of time or distance. Each method requires one parameter, Pin, that is the I/O pin that is connected to the Ping)))'s signal line. ┌───────────────────┐ │┌───┐ ┌───┐│ ││ ‣ │ PING))) │ ‣ ││ │└───┘ └───┘│ │ GND +5V SIG │ └─────┬───┬───┬─────┘ │ │  1K  └┘ └ Pin Connection To Propeller Remember PING))) Requires +5V Power Supply --------------------------REVISION HISTORY-------------------------v1.1 - Updated 03/20/2007 to change SIG resistor from 10K to 1K }} CON TO_IN = 73_746 TO_CM = 29_034 ' Inches ' Centimeters PUB Ticks(Pin) : Microseconds | cnt1, cnt2 ''Return Ping)))'s one-way ultrasonic travel time in microseconds outa[Pin]~ ' Clear I/O Pin dira[Pin]~~ ' Make Pin Output outa[Pin]~~ ' Set I/O Pin outa[Pin]~ ' Clear I/O Pin (> 2 μs pulse) dira[Pin]~ ' Make I/O Pin Input waitpne(0, |< Pin, 0) ' Wait For Pin To Go HIGH cnt1 := cnt ' Store Current Counter Value waitpeq(0, |< Pin, 0) ' Wait For Pin To Go LOW cnt2 := cnt ' Store New Counter Value Microseconds := (||(cnt1 - cnt2) / (clkfreq / 1_000_000)) >> 1 ' Return Time in μs PUB Inches(Pin) : Distance ''Measure object distance in inches Distance := Ticks(Pin) * 1_000 / TO_IN ' Distance In Inches PUB Centimeters(Pin) : Distance ''Measure object distance in centimeters Distance := Millimeters(Pin) / 10 ' Distance In Centimeters PUB Millimeters(Pin) : Distance ''Measure object distance in millimeters Distance := Ticks(Pin) * 10_000 / TO_CM Copyright © Parallax Inc. ' Distance In Millimeters PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 8 of 9 The ping.spin object is used in an example project with the Parallax 4 x 20 Serial LCD (#27979) to display distance measurements. The complete Project Archive can be downloaded from the Propeller Object Exchange at http://obex.parallax.com. The Propeller Tool software can be downloaded from www.parallax.com/propellertool. ─────────────────────────────────────── Parallax Propeller Chip Project Archive ─────────────────────────────────────── Project : "ping_demo" Archived : Tuesday, December 18, 2007 at 3:29:46 PM Tool : Propeller Tool version 1.05.8 ping_demo.spin │ ├──Debug_Lcd.spin │ │ │ ├──Serial_Lcd.spin │ │ │ │ │ └──Simple_Serial.spin │ │ │ └──Simple_Numbers.spin │ └──ping.spin Reources and Downloads For additional example code downloads and links to videos, tutorials and robotics projects that use the Ping))) Ultrasonic Distance Sensor, visit www.parallax.com and search “28015.” Product Change Notice Rev A: original release Rev B: resonator added to the SX-28 co-processor circuit. No changes to functionality Rev C: SX-28 co-processor changed to PIC16F57. No changes to functionality. Revision History Version 2.0: Added revision history. Removed Javelin Stamp examples. Added URLs for programming software. Added Product Change Notice section with PCB revision information. Copyright © Parallax Inc. PING))) Ultrasonic Distance Sensor (#28015) v2.0 2/4/2013 Page 9 of 9 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Parallax: 28015
28015 价格&库存
很抱歉,暂时无法提供与“28015”相匹配的价格&库存,您可以联系我们找货
    • 1+362.047281+46.92822
    • 5+343.940655+44.58126
    • 10+325.8436110+42.23554
    • 25+316.8514925+41.06999
    库存:269
    28015
    • 1+278.94504
    • 5+270.57232
    库存:82
