SEN-09496
SEN-09496
    SPARKFUNELECTRONICS
    ULTRASONICRANGEFINDER-XL-MAX
SEN-09496 数据手册
XL-MaxSonar® - WR/WRC™ Series XL-MaxSonar®- WR/WRC™ Series High Performance, IP67 Weather Resistant, Ultrasonic Range Finder MB7051, MB7052, MB7053, MB7060, MB7062, MB7066, MB7070, MB7072, MB7076, MB7092, MB7150, MB71554 The XL-MaxSonar-WR and XL-MaxSonar-WRC sensor series provide users with robust range information in air. These sensors also feature high-power acoustic output along with real-time auto sensitivity adjustment for changing conditions (supply voltage sag, acoustic noise, or electrical noise), operation with supply voltage from 3V to 5.5V, object detection from 0-cm to 765-cm2 (select models) or 1068-cm (select models), and sonar range information from 20-cm1 out to 765 -cm (select models) or 1068-cm (select models) with 1-cm resolution. Objects from 0-cm to 20-cm1 range as 20cm1 or closer. The sensor is housed in a robust PVC housing, designed to meet the IP67 water intrusion standard, and matches standard electrical/water ¾” PVC pipe fittings. The user interface formats included are pulse-width (select models), real-time analog-voltage envelope (select models), analog voltage output, and serial output. • Analog, (Vcc/1024) / cm for standard models Real-time auto sensitivity adjustment • Analog, (Vcc/1024) / 2-cm for and noise rejection 10-meter models (MB7051, High acoustic power output MB7053, MB7066, MB7076) Precise narrow beam • Sensor operates at 42KHz Object detection includes zero range Benefits objects • Acoustic and electrical noise 3V to 5.5V supply with very low resistance average current draw3 • Reliable and stable range data Free run operation can continually measure and output range information • Robust, low cost IP67 standard sensor 10Hz refresh rate (MB7060, MB7062, MB7066, MB7070, • Narrow beam characteristics MB7072, MB7076, MB7092, • Very low power excellent for battery MB7150, MB7155) based systems 6.6Hz refresh rate (MB7052) • Ranging can be triggered externally 5.1Hz refresh rate (MB7051, or internally MB7053) • Sensor reports the range reading Triggered operation provides the directly, frees up user processor range reading as desired • Easy hole mounting or mating with All interfaces are active standard electrical fittings simultaneously • Filtering allows very reliable RS232/TTL Serial, 0 to Vcc, 9600 operation in most environments Baud, 81N Features Applications and Uses • • • • • • • • • • • • • • • • • • • • Tank level measurement Bin level measurement Proximity zone detection Environments with acoustic and electrical noise Distance measuring Long range object detection Super high sensitivity for long range small object detection (MB7051 & MB7053) Industrial sensor -40C to +65C (limited operation to +85C) 3 Notes: 1 Minimum distance is 25-cm for the MB7052, MB7092 Pipe and Compact,; 50-cm for the MB7051 and MB7053 horned part. 2 The maximum range detection to a large flat surface is 700cm for the MB7052, MB7092, and MB7150. Target from 700cm to 765cm may still be detected and the sensor will report the range to the target (i.e. a target at 720cm when detected will report 720cm) 3 Please reference page 13 for minimum operating voltage verses temperature information 4 Please reference page 23 for part number key Close Range Operation Applications requiring 100% reading-to-reading reliability should not use MaxSonar sensors at a distance closer than 20cm1. Although most users find MaxSonar sensors to work reliably from 0 to 20-cm1 for detecting objects in many applications, MaxBotix® Inc. does not guarantee operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances. 1 25-cm (MB7052, MB7092 Pipe and compact; 50-cm for the MB7051 and MB7053 horned part Warning: Personal Safety Applications We do not recommend or endorse this product be used as a component in any personal safety applications. This product is not designed, intended or authorized for such use. These sensors and controls do not include the self-checking redundant circuitry needed for such use. Such unauthorized use may create a failure of the MaxBotix® Inc. product which may result in personal injury or death. MaxBotix® Inc. will not be held liable for unauthorized use of this component. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 1 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series XL-MaxSonar-WR/WRC Pin Out Pin 1- Leave open (or high) for serial output on the Pin 5 output. When Pin 1 is held low the Pin 5 output sends a pulse (instead of serial data), suitable for low noise chaining. Pin 2- This pin outputs a pulse-width representation of range. To calculate the distance, use a scale factor of 58uS per cm. (MB7051, MB7052, MB7053, MB7060, MB7062, MB7066) This pin outputs the analog voltage envelope of the acoustic waveform. For the MB7070 series and MB7092 sensors, this is a real-time always-active output (MB7070, MB7072, MB7076, MB7092, MB7150, MB7155) Pin 3- AN-This pin outputs analog voltage with a scaling factor of (Vcc/1024) per cm. A supply of 5V yields ~4.9mV/ cm., and 3.3V yields ~3.2mV/cm. Hardware limits the maximum reported range on this output to ~700 cm at 5V and ~600 cm at 3.3V. The output is buffered and corresponds to the most recent range data. For the 10-meter sensors (MB7051, MB7053, MB7066, MB7076) Pin 3 outputs an analog voltage with a scaling of (Vcc/1024) per 2-cm. A supply of 5V yields ~4.9mV/2-cm., and 3.3V yields ~3.2mV/2-cm. This Analog Voltage output steps in 2-cm increments. Pin 4- RX- This pin is internally pulled high. If Pin-4 is left unconnected or held high, the sensor will continually measure the range. If Pin-4 is held low the sensor will stop ranging. Bring high 20uS or more to command a range reading. Pin 5- TX- When Pin 1 is open or held high, the Pin 5 output delivers asynchronous serial data in an RS232* format, except the voltages are 0-Vcc. The output is an ASCII capital “R”, followed by ASCII character digits representing the range in centimeters up to a maximum of 765 (select models) or 1068 (select models), followed by a carriage return (ASCII 13). The baud rate is 9600, 8 bits, no parity, with one stop bit. Although the voltages of 0V to Vcc are outside the RS232* standard, most RS232* devices have sufficient margin to read the 0V to Vcc serial data. If standard voltage level RS232* is desired, invert, and connect an RS23* converter such as a MAX232.When Pin 1 is held low, the Pin 5 output sends a single pulse, suitable for low noise chaining (no serial data). *The MB7150 & MB7155 are TTL output format (inverted RS232) and follow the same ASCII data structure V+ Operates on 3V - 5.5V. The average (and peak) current draw for 3.3V operation is 2.1mA (50mA peak) and 5V operation is 3.4mA (100mA peak) respectively. Peak current is used during sonar pulse transmit. Please reference page 13 for minimum operating voltage verses temperature information. GND-Return for the DC power supply. GND (& V+) must be ripple and noise free for best operation. _______________________________________________________________________________________________________________________________________ About Ultrasonic Sensors Our ultrasonic sensors are desired for use in air, non-contact object detection and ranging sensors that detect objects within a defined area. These sensors are not affected by the color or other visual characteristics of the detected object. Ultrasonic sensors use high frequency sound to detect and localize objects in a variety of environments. Ultrasonic sensors measure the time of flight for sound that has been transmitted to and reflected back from nearby objects. Based upon the time of flight, the sensor then outputs a range reading. _____________________________________________________________________________________________________________________________________ Auto Sensitivity Adjustment Each time before the XL-MaxSonar-WR takes a range reading it auto calibrates. The sensor then uses this data to range objects. If the temperature, humidity, or applied voltage changes during sensor operation, the sensor will continue to function normally. (The sensors do not apply compensation for the speed of sound change verses temperature to any range readings.) If the application requires temperature compensation please look at the HRXL-MaxSonar-WR sensor line. _______________________________________________________________________________________________________________________________________ Supply Voltage Compensation During power up, the XL-MaxSonar-WR sensor line will calibrate itself for the supply voltage. Additionally, the sensor will compensate if the supplied voltage gradually changes. If the average voltage applied to the sensor changes faster than 0.5V per second, it is best to remove and reapply power to the sensor. For best operation, the sensor requires noise free power. If the sensor is used with noise on the supplied power or ground, the accuracy of the readings may be affected. Typically, adding a 100uF capacitor at the sensor between the V+ and GND pins will correct most power related electrical noise issues. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 2 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Real-time Noise Rejection While the XL-MaxSonar-WR is designed to operate in the presence of noise, best operation is obtained when noise strength is low and desired signal strength is high. Hence, the user is encouraged to mount the sensor in such a way that minimizes outside acoustic noise pickup. In addition, keep the DC power to the sensor free of noise. This will let the sensor deal with noise issues outside of the users direct control (Even so, in general, the sensor will still function well even if these things are ignored). Users are encouraged to test the sensor in their application to verify usability. _______________________________________________________________________________________________________________________________________ Sensor Minimum Distance The XL-MaxSonar-WR sensors have a minimum reported distance of 20-cm1 (7.87 inches). However, the XL-MaxSonar-WR will range and report targets to the front sensor face. Large targets closer than 20-cm1 will typically range as 20-cm1. For the alternative housings, objects between 4-cm and 20-cm1 will typically range as 20-cm1. Note 1: 25-cm for the MB7052, MB7092 Pipe and Compact; 50-cm for the MB7051 and MB7053 horned part. _______________________________________________________________________________________________________________________________________ WR Exposed Materials The exposed materials of a properly mounted MaxSonar WR standard sensor are: Aluminum (oxidized surface), PVC, & silicone rubber (VMQ). _______________________________________________________________________________________________________________________________________ Additional Options for Purchase Please contact MaxBotix for any additional information regarding the options listed below at info@maxbotix.com F-Option In addition to the standard MaxSonar WR, MaxBotix Inc. has developed the F-Option for additional protection necessary in a few hazardous chemical environments. Extremely corrosive gases or liquids can degrade or compromise the operation of the sensing unit. As a result, we offer a more chemically inert seal which allows our sensors to operate in all but the harshest of chemical environments. In addition to the chemical resistance the sensor has improved performance in wet or dust environments. Please Note: Our sensors are designed for operation in normal atmosphere (air). Please be aware that the speed of sound and atmospheric attenuation may change as a result of the transmission properties of different chemical/air mediums. Users are strongly encouraged to characterize and test the operation of the sensor in the new medium to verify operation, and properly scale the outputted range information. The exposed materials of a properly mounted MaxSonar WR sensor with the F-Option added are: Aluminum (oxidized surface), PVC, & Fluorosilicone (with an additional back up FEP Teflon® seal). Shielded Cable Attach Option For simple integration of our sensors into end-user applications, MaxBotix has developed the Shielded Cable Attach Option to create a completely IP67 rated MaxSonar-WR sensor. The standard Shielded Cable Attach Option uses 3 feet of the MaxSonar MB7954 Shielded Cable (MB7984 when attached by MaxBotix) with an epoxy filled cap to fully protect the pin-out of the MaxSonar sensor. Additional cable length can be specified and purchased using part number MB7984. P-Option The P-Option is a Parylene coating applied to the surface of the aluminum transducer. This helps to improve the corrosion resistance of the aluminum transducer. The exposed materials of a properly mounted MaxSonar WR sensor with the POption added are: Parylene, PVC, & silicone rubber (VMQ). The F-Option can be purchased with the P-Option. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 3 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Sensor Descriptions Base Sensor (MB7060, MB7070 & MB7155) The MB7060, MB7070 & MB7155 are the base models of the XL-MaxSonar-WR sensor line. These sensors are recommended for general purpose usage. All other sensors in this series are based off these sensor models. The additional features are mentioned in their respective sections below. _______________________________________________________________________________________________________________________________________ XL-MaxSonar-WR1 (MB7062 and MB7072) The XL-MaxSonar-WR1 sensors feature a 3 reading stability filter that ranges to the first detectable target. Filtering is available on Pin3 (AN) and Pin 5 (TX). Filtering is not applied to the output on Pin 2 (PW). This filter requires that 3 consecutive range readings are within 1cm of each other to be considered a valid range reading. If the range readings are outside 1-cm, the sensor discards the range reading set and reports the last valid range reading. This sensor does not view maximum range as a valid range, and will not report 765 when no target is detected. If this sensor does not detect a target for 1 hour, the sensor will go into fail-safe and report 000. _______________________________________________________________________________________________________________________________________ XL-MaxSonar-WRL (MB7066 and MB7076) The XL-MaxSonar-WRL will report a maximum distance of 10 meters for large targets. _______________________________________________________________________________________________________________________________________ XL-MaxSonar-WRM (MB7052, MB7092 & MB7150) The MB7052, MB7092 & MB7150 sensors prioritize large targets over both small targets and noise. These sensors report the target that gives the largest acoustic reflection. This stands in contrast to other units such as the MB7060 which are designed to report the distance to the first detectable target. If the largest target is removed from the field of view, the MB7052, MB7092 & MB7150 will switch to the target that gives the next largest detectable return. When targets are of similar amplitude reflections, preference is given to the closer target. The sensor expects to see a target by 7.56 meters. If no target is found, the sensor will increase in sensitivity until a target is found, or until no targets can be found. In addition to the most-likely filtering, the MB7052, MB7092 & MB7150 come equipped with a three-reading filter and reading hold which requires three consecutive range readings within 1cm of the most recent reading to be considered a valid range reading. If readings are found to be outside 1cm, or no target can be found by the sensor, then the sensor will report the last valid range reading. Upon power-up the sensor will default to reporting 7.65 meters unit a valid range reading is found. The last reading hold is designed for users operating in environments with intermittent high noise who desire to poll the MB7052, MB7092 & MB7150 at intermittent times. This allows the sensor to report the previously valid reading until the sensor’s environment improves. If no valid range reading is found for ~1.5 hours, the sensor will send a fail-safe output “000” on all interfaces. _______________________________________________________________________________________________________________________________________ XL-MaxSonar-WRML (MB7051) The MB7051 includes all the features of the MB7052 with a maximum distance of 10 meters which provides a very robust long range sensing solution. The MB7051 is ideal for applications requiring small or soft target detection at longer ranges than our previously mentioned XL-MaxSonar-WR sensors. The MB7051 has improved sensitivity to objects with the addition of a horn extension. This improvement results in the sensor detecting objects of similar size about 2.5 times further in comparison to the MB7066 sensor. The detection patterns of each are shown in the beam pattern section of the datasheet. _______________________________________________________________________________________________________________________________________ XL-MaxSonar-WRML1 (MB7053) The MB7053 is based on the MB7051 but removes the three reading stability filter. This prevents the sensor from entering a fail -safe mode where it reports 000. It also allows the MB7053 to respond to large changes in range more quickly than the MB7051. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 4 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Sensor Comparison Chart Stability Filter Most Likely Filter1 Refresh Rate Yes Yes Yes 5.1Hz RS232 Yes Yes Yes 6.6Hz Yes RS232 Yes Yes 5.1Hz MB7060 Yes RS232 Yes MB7062 Yes RS232 Yes MB7066 Yes RS232 Yes MB7070 Yes RS232 Yes MB7072 Yes RS232 Yes MB7076 Yes RS232 Yes MB7092 Yes RS232 Yes MB7150 Yes TTL Yes MB7155 Yes TTL Yes Serial Data Part Number AN Voltage (0 to Vcc level) Pulse Width MB70512 Yes RS232 MB7052 Yes MB70532 Analog Envelope Yes Other Packages Available 7-meter range Yes Yes Yes Yes 10Hz Yes Yes 10Hz Yes Yes 10Hz Yes Yes 10Hz Yes Yes 10Hz Yes Yes 10Hz Yes Yes Yes Yes 10-meter range Yes 10Hz Yes Yes 10Hz Yes Yes 10Hz Yes Yes 1 Our standard sensors provide the range to the first target they detect. Our most-likely filter allows our sensors to continue looking for larger targets. This way they only give you the range to the target with the largest return of sound as seen by the sensor. Note that while this will often be the largest target in an environment, there are times when small targets will reflect more sound to the sensor than larger targets 2 Higher gain and other sensitivity adjustments allows better performance to soft targets such as grain. Package Types Currently Available Full Horn — 3/4” NPT straight; back mounted thread (best performance) Compact — 3/4” NPT straight; back mounted thread Ultra-Compact — PCB with 4 mounting holes 1”NPS — External thread over full sensor body (1”NPS) 1” BSPP — External thread over full sensor body (1”BSPP) 30mm1.5 — External thread over full sensor body (30mm1.5) Extended Horn – 3/4” NPT straight; back mounted thread. Enhanced detection of distant and small targets. All package types have exposed PCB on user end for easy connection. Users desiring a fully enclosed assembly may purchase the “Shielded Cable Option” along with their sensor. About Package Types The XL-MaxSonar-WR sensor line is available in a variety of packages for applications with specific mounting requirements. The full horn package provides peak accuracy and sensitivity in this sensor line. It is recommended that testing is completed to ensure that the selected sensor will operate as desired in your application. _______________________________________________________________________________________________________________________________________ Performance Changes when Selecting a Compact, Pipe or Ultra-Compact Package When selecting a XL-MaxSonar-WR without the full horn the sensor will experience the following performance changes: • The sensor will have a wider beam shape for the first meter. • The sensor may have a dead zone from 0-6-cm. • The sensor may be less accurate by an additional +/- 0.5%. • The sensor may have worse performance to small or soft targets. • The sensor may experience decreased noise immunity when ranging to small, soft, angled, or distant targets. • The maximum effective range is 645-cm, the sensor will still report 765 as a “no detection” output if a target is not found. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 5 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Mechanical Dimensions Full Horn –100 C A 1.72” dia. 43.8 mm dia. B 2.00” 50.7 mm C 0.58” 14.4 mm D 0.31” 7.9 mm E 0.23” 5.8 mm F 0.10” 2.54 mm G 3/4”-14 NPS H 1.032” dia. 26.2 mm dia. I 1.37” 34.8 mm Weight 50 grams Values Are Nominal B D E Pin 1 A F G H I Ultra-Compact –300 & –400 J A C K D P L O E Q F B R V I H A B C D E M G N All values are nominal 30.48 mm 1.20 ” 35.56 mm 1.40 ” 12.24 mm 0.60 ” 2.540 mm 0.10 ” 2.540 mm 0.10 ” F G H I J K 17.78 30.48 3.180 25.40 25.27 10.40 mm mm mm mm mm mm 0.70 ” 1.20 ” 0.13 ” 1.00 ” 1.00 ” 0.41 ” S L M N O P Q 13.4 25.0 1.57 6.20 8.00 13.9 mm mm mm mm mm mm 0.53 ” 0.98 ” 0.062 ” 0.24 ” 0.31 ” 0.55 ” T R S T U V U 7.80 mm 0.31 ” 7.62 mm 0.30 ” 2.54 mm 0.10 ” 1.07 mm 0.04 ” 1.27 mm 0.05 ” Weight 15.1 gram. Compact Housing –200 B C D E F A Pin 1 G A 1.37” dia. 34.7 mm dia. B 0.70” 17.9 mm C 0.57” 14.4 mm D 0.31” 7.9 mm E 0.23” 5.8 mm F 0.10” 2.54 mm G 3/4”-14 NPS H 1.032” dia. 26.2 mm dia. I 1.37” 34.8 mm Weight 32 grams Values Are Nominal MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 H I Page 6 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Mechanical Dimensions Continued 1” NPS Pipe Threading –500 C B Pin 1 A D A B C D E F 1.29” dia. 38.2 mm dia. 1.30” 33.1 mm 0.20” 5.2 mm 0.10” 2.54 mm 1”— NPS 0.78” 19.8 mm Weight 35 grams Values Are Nominal F A B C D E F 1.29” dia. 38.2 mm dia. 1.30” 33.1 mm 0.20” 5.2 mm 0.10” 2.54 mm 1”— BSPP 0.78” 19.8 mm Weight 34 grams Values Are Nominal F A B C D E F 1.17” dia. 29.7 mm dia. 1.30” 33.1 mm 0.20” 5.2 mm 0.10” 2.54 mm 30mm 1.5 0.78” 19.8 mm Weight 31 grams Values Are Nominal F E 1” BSPP Pipe Threading –600 C B Pin 1 A D E 30mm1.5 Pipe Threading –700 C B Pin 1 A D E Extended Horn –800 I B G H F E D C Pin 1 L A J M K A 3.039” dia. 77.2 mm dia. B 8.327” 211.5mm C 4.827” 122.6mm D 0.636” 16.2mm E 0.580” 14.7mm F G H I J 1.198” 30.4mm 0.315” 7.9mm 0.580” 14.7mm 0.191” 4.9mm 0.10” 2.54 mm Values Are Nominal K 3/4”-14 NPS L 1.032” dia. 26.2 mm dia. M 1.37” 34.8 mm Weight 50 grams MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 7 Web: www.maxbotix.com PD11838z Range “0” Location XL-MaxSonar® - WR/WRC™ Series The XL-MaxSonar-WR sensors reports the range to distant targets starting from the front of the sensor as shown in the diagrams below. The XL-MaxSonar-WR will report the range to the closest detectable object. Target detection has been characterized in the sensor beam patterns. Range Zero The range is measured from the front of the transducer to the target. Range Zero The range is measured from the front of the transducer to the target. Range Zero The range is measured from the front of the transducer to the target. Range Zero The range is measured from the front of the transducer to the target. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 8 Web: www.maxbotix.com PD11838z Range “0” Location Continued XL-MaxSonar® - WR/WRC™ Series Range Zero The range is measured from the front of the transducer to the target. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 9 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Typical Performance to Target All sensor models Typical Performance in Clutter MB7060*, MB7062*, MB7066*, MB7070, MB7072, MB7076, MB7155 Typical Performance in Clutter MB7051*, MB7052*, MB7053*, MB7092, MB7150 Graphs depict the analog envelope output for reference to help understand typical performance. The performance information is accurate, but this output is not available on sensors with the pulse-width output on pin 2. These sensors are indicated by an asterisk. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 10 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series XL-MaxSonar-WR Sensor Operating Modes Independent Sensor Operation The XL-MaxSonar-WR sensors are designed to operate in a single sensor environment. Free-run is the default mode of operation for all of the MaxBotix Inc., sensors. The XL-MaxSonar-WR sensors have three separate outputs that update the range data simultaneously: Analog Voltage, Pulse Width1, and RS232 Serial. Below are diagrams on how to connect the sensor for each of the three outputs. Note 1 - select models output an Analog Envelope for end user processing (MB707X sensors and MB7092) Using Multiple Sensors in a Single System When using multiple ultrasonic sensors in a single system, there can be interference (cross-talk) from the other sensors. MaxBotix Inc., has engineered a solution to this problem for the XL-MaxSonar-WR sensors. The solution is referred to as chaining. We have 3 methods of chaining that work well to avoid the issue of cross-talk. The first method is AN Output Commanded Loop. The first sensor will range, then trigger the next sensor to range and so on for all the sensors in the array. Once the last sensor has ranged, the array stops until the first sensor is triggered to range again. Below is a diagram on how to set this up. The next method is AN Output Constantly Looping. The first sensor will range, then trigger the next sensor to range and so on for all the sensor in the array. Once the last sensor has ranged, it will trigger the first sensor in the array to range again and will continue this loop indefinitely. Below is a diagram on how to set this up. The final method is AN Output Simultaneous Operation. This method does not work in all applications and is sensitive to how the other sensors in the array are physically positioned in comparison to each other. Testing is recommend to verify this method will work for your application. All the sensors RX pins are connected together and triggered at the same time causing all the sensor to take a range reading at the same time. Once the range reading is complete, the sensors stop ranging until triggered next time. Below is a diagram on how to set this up. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 11 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Sensor Timing Diagrams Power-Up Timing Boot data output in RS232/TTL (RS232/TTL Serial Output) High idle state for TTL Vcc Power supply must be noise free for best results Pin 6 (Vcc) 0 Pin 4 (Ranging Start/ Stop) Drive high for >20uS (>0.02ms) The analog voltage output mains the voltage corresponding to the latest range measurement Pin 3 (ADC Output) Range information is output with a high pulse width that is at least 1.16mS Pin 2 (PW Output) Pin 5 Data sent in RS232/TTL (RS232/TTL Serial) 0mS A B C D Product Maximum Refresh Rate Pulse Width Reported Max Pulse Width End Serial Data Reported End of Range Cycle MB7051, MB7053 5.1 Hz ~135mS ~195.9mS ~188mS ~196mS MB7052 6.6 Hz ~82.3mS ~126.7mS ~144.3mS ~149mS MB7060, MB7062, 10 Hz ~32.3mS ~76.7mS ~94.3mS ~99mS MB7066 10 Hz ~32.3mS ~94.2mS ~94.3mS ~99mS MB7070, MB7072, MB7076, MB7092, MB7150, MB7155 10 Hz NA NA ~94.3mS ~99mS MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 12 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Sensor Free-Run Timing Sensor Timing Diagrams Continued Timing Description 175mS after power-up, the XL-MaxSonar-WR is ready to begin ranging. If Pin-4 is left open or held high (20uS or greater), the sensor will take a range reading. The XL-MaxSonar-WR checks Pin-4 at the end of every cycle. Range data can be acquired once every period. Each period starts by Pin-4 being high or open, after which the XL-MaxSonar-WR calibrates and calculates for 20.5mS, and after which, the 42KHz waves are sent. The sensor then determines the range to the target. Next the analog voltage is set. The sensors with a pulse width (PW), Pin 2 is set high for a length of time 1. Then serial data is sent1. The most accurate range output on the XL-MaxSonar-WR sensors is the PW output. Note 1: Reference the timing specifications on page 12 for the exact times. Sensors with the analog envelope output (MB7070 series and MB7092, MB7150, MB7155), Pin-2 will show the real-time signal return information of the Analog Waveform. __________________________________________________________________________________________________ Voltage vs Temperature The graph below shows minimum operating voltage of the sensor verses temperature. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 13 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Attenuation of Ultrasound Attenuation, specifically absorption of sound through the air, restricts the maximum range of ultrasonic rangefinders. As sound waves travel through the air, that air absorbs some of their energy. High frequency sounds like ultrasound are often attenuated more quickly than lower frequency sounds. In addition to frequency, relative humidity also affect attenuation. Warm air masses with low relative humidity will typically attenuate sound waves faster. As such performance of ultrasonic devices may be limited at low relative humidity, especially when trying to detect targets at longer ranges. Background Information Regarding our Beam Patterns Each XL-MaxSonar-WR sensor has an individually calibrated beam pattern, and is matched to provide the approximate detection pattern shown in this datasheet. This allows end users to select the part number that People Sensing: matches their given sensing application. Each part number has a consistent field of detection so For users that additional units of the same part number will have similar beam patterns. The beam plots are desire to detect provided to help identify an estimated detection zone for an application based on the acoustic people, the properties of a target versus the plotted beam patterns. detection area to Each beam pattern is a 2D representation of the detection area of the sensor. The beam pattern is the 1-inch actually shaped like a 3D cone (having the same detection pattern both vertically and horizontally). diameter dowel, in Detection patterns for dowels are used to show the beam pattern of each sensor. Dowels are long general, represents cylindered targets of a given diameter. The dowels provide consistent target detection characteristics the area that the for a given size target which allows easy comparison of one MaxSonar sensor to another MaxSonar sensor will sensor. reliably detect people. For each part number, the four patterns (A, B, C, and D) represent the detection zone for a given target size. Each beam pattern shown is determined by the sensor’s part number and target size. The actual beam angle changes over the full range. Use the beam pattern for a specific target at any given distance to calculate the beam angle for that target at the specific distance. Generally, smaller targets are detected over a narrower beam angle and a shorter distance. Larger targets are detected over a wider beam angle and a longer range. Beam Pattern Target Shapes A 6.1-mm (0.25-inch) diameter dowel 4ft length B 2.54-cm (1-inch) diameter dowel 4ft length C 8.89-cm (3.5-inch) diameter dowel 4ft length D 11-inch wide board 4ft in length moved left to right with the board parallel to the front sensor face. This shows the sensor’s range capability. Corner Reflectors Sometimes when using an ultrasonic sensor, users experience detection of unwanted objects that appear outside the expected beam pattern. These types of detections are the result of reflectors present in the environment. Corner reflectors can be surprisingly small, yet present a large reflection back to the sensor. Certain objects are prone to causing corner reflections. One of the most common corner reflectors is two flat surfaces joining together to create a 90° angle. A halfcircle also acts as a similar reflector. You can learn more about corner reflectors in our Cube Corner Reflectors article. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 14 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB7051-MB7053 XL-MaxSonar®-WRML/WRML1™ Beam Pattern and Uses The XL-MaxSonar-WRML/WRML1 provide a super sensitive robust long range sensing solution. The MB7051MB7053 are ideal for applications requiring small or soft target detection ranges out to 10 meters. The sensors are great for applications such as 10 meter bin and tank level measurement, and soft target detection. MB7051-MB7053 Features and Benefits • Pencil beam applications >10º • Super high sensitivity to small and soft targets. About 2.5 times further compared to the MB7052. • Extremely narrow beam which is great for cluttered environments. • 10 meter maximum distance. • Clutter rejection provides range to the largest amplitude reflection within the field of view • Real-time sensitivity adjustment, noise rejection and additional filtering provides stable range information • Excellent for ranging to large objects in the presence of cluttered or noisy environments • Excellent for applications that require consistently accurate outputs • Impressive acoustic and electrical noise resistance • 5.1Hz refresh rate MB7051-MB7053 Applications and Uses • Pencil beam applications >10º • Environments with acoustic and electrical noise • Soft Targets • Bin Level Measurement • Tank Level Measurement MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 15 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB7052, MB7092, MB7150 XL-MaxSonar®-WRM1/WRMA1/WRMA1R™ Beam Pattern and Uses The XL-MaxSonar-WRM1/WRMA1 ignores smaller targets and only reports the range to the largest acoustic return. The filtering also rejects moving target clutter such as rain or snow, electrical noise, and outside acoustic noise. MB7052, MB7092, MB7150 Features and Benefits • Clutter rejection provides range to the largest amplitude reflection within the field of view • Real-time sensitivity adjustment, noise rejection and additional filtering provides stable range information • Excellent for ranging to large objects in the presence of cluttered or noisy environments • Excellent for applications that require consistently accurate outputs • Impressive acoustic and electrical noise resistance • 10Hz refresh rate for the MB7092 • 6.6Hz refresh rate on the MB7052 MB7052, MB7092, MB7150 Applications and Uses • Environments with acoustic and electrical noise • Bin Level Measurement • Tank Level Measurement MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 16 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB7060, MB7070, MB7155 XL-MaxSonar®-WR/WRA1/WRAT™ Beam Pattern and Uses The XL-MaxSonar-WR/WRA1 reports the range to the first detectable target. The sensors are the most recommended XL-MaxSonar-WR sensor. This is a good starting place when unsure of which XL-MaxSonar-WR to use. MB7060, MB7070, MB7155 Features and Benefits • Real-time sensitivity adjustment, and noise rejection for every ranging cycle • Readings can occur up to every 100mS (10Hz) • Analog voltage (Vcc/1024) / cm • Precise narrow beam • Continuously variable gain MB7060, MB7070, MB7155 Applications and Uses • Applications where a stability filter is not needed or desired • Multi-Sensor Arrays • Distance Measuring • People Detection MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 17 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB7062-MB7072 XL-MaxSonar®-WR/WRA™ Beam Pattern and Uses The XL-MaxSonar-WR/WRA sensors have a 3 reading stability filter in the firmware. This sensor is well suited for applications requiring stable, accurate range readings. This sensor ranges to the first detectable target. MB7062-MB7072 Features and Benefits • 1 hour fail-safe built into sensor • Real-time sensitivity adjustment, noise rejection and additional filtering provides stable range information • Excellent for ranging to large objects in the presence of cluttered or noisy environments • Excellent for applications that require consistently accurate outputs • Advanced acoustic and electrical noise filtered output • Reports filtered output on serial and analog-voltage outputs • Reliable stable range data • No power up calibration is required MB7062-MB7072 Applications and Uses • Long range object detection • Industrial sensor • Drop in upgrade for MB7060 and MB7070 MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 18 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB7066-MB7076 XL-MaxSonar®-WRL/WRLA1™ Beam Pattern and Uses The XL-MaxSonar-WRL/WRLA1 ranges objects from 0-cm to 1068-cm (35 feet) and provides range information from 20-cm to 1068-cm with a 1-cm resolution. This sensor is designed for applications where large object detection is needed to 10 meters. MB7066-MB7076 Features and Benefits MB7066-MB7076 Applications and Uses • Extended 10 meter range detection and outputs • High acoustic power output • Readings can occur up to every 100ms, 10-Hz rate • Triggered operation provides the range reading as desired • Fast measurement cycle • Quality narrow beam characteristics • Low cost, long range IP67 sensor • • • • • Robot ranging sensor Autonomous navigation Distance measuring Long range object detection Industrial sensor MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 19 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB706X, MB707X, MB7150 XL-MaxSonar-WRC Beam Pattern and Uses The XL-MaxSonar-WR product line is available in alternative housings that include a WRC housing, 1” NPS pipe threading, 1” BSPP pipe threading, and 30mm 1.5 pipe threading. MB706X, MB707X, MB7150 Features and Benefits MB706X, MB707X, MB7150 Applications and Uses • Can be flush mounted in an application • Same resolution as the full horn equivalent • Available in both metric and imperial housing sizes • • • • • • UAV blimps Bin level measurement Proximity zone detection Robot ranging sensor Tank level measurement Auto sizing MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 20 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB706X, MB707X, MB7150 XL-MaxSonar-WR Ultra Compact Beam Pattern and Uses The XL-MaxSonar-WR product line is available in an Ultra Compact alternative housing. The Ultra Compact housing is designed for users that are creating a custom horn mount. The recommended horn can be downloaded from http://www.maxbotix.com/Ultrasonic_Sensors/Outdoor_Sensors.htm under the “Documents” Tab. MB706X, MB707X, MB7150 Features and Benefits • Can be flush mounted in an application • Same resolution as the full horn equivalent • Gives the ability to create custom mounts • Note 1: The “full horn” reference means that the sensor is mounted in a horn like the image to the right. MB706X, MB707X, MB7150 Applications and Uses • • • • • • UAV blimps Bin level measurement Proximity zone detection Robot ranging sensor Tank level measurement Auto sizing MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 21 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series MB706X, MB707X, MB7150 XL-MaxSonar-WR Ultra Compact Beam Pattern and Uses The XL-MaxSonar-WR product line is available in an Ultra Compact alternative housing. The Ultra Compact housing is designed for users that want to create a custom mount. The recommended designs can be downloaded from http://www.maxbotix.com/Ultrasonic_Sensors/Outdoor_Sensors.htm under the “Documents” Tab. MB706X, MB707X, MB7150 Features and Benefits • Can be flush mounted in an application • Same resolution as the full horn equivalent • Allows for custom mounts to be designed. • Note 1: The “flush mount” reference means that the sensor is mounted in a housing without a horn like the image to the right or used without a housing. MB706X, MB707X, MB7150 Applications and Uses • • • • • • UAV blimps Bin level measurement Proximity zone detection Robot ranging sensor Tank level measurement Auto sizing MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 22 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Part Numbers All part numbers are a combination of a six-character base followed by a dash and a three-digit product code. Please review the following table for more information on the three-digit product code. Note: Active part numbers listed on pages 23, 24 and 25. M B 7 0 X - X Base 1 0 0 Housing Options Wire 0 Not Applicable 0 No Options (Bagged) 0 No Wire 1 3/4” NPS WR 1 F-Option 1 Wire Attached 2 3/4” NPS WRC 2 P-Option 2 Connector 3 Ultra Compact 3 F-Option and P-Option 4 Ultra Compact Flush Mount 4 No Options (Trayed) 5 1” NPS 5 TTL (Bagged) 6 1” BSPP 6 TTL (Trayed) 7 30MM 1.5 8 Extended Horn The following tables display all of the active and valid part numbers for these products. Active Part Numbers for MB7051 MB7051-800 MB7051-801 MB7051-810 MB7051-811 MB7051-820 MB7051-821 MB7051-830 MB7051-831 Active Part Numbers for MB7052 MB7052-100 MB7052-101 MB7052-110 MB7052-111 MB7052-120 MB7052-121 MB7052-130 MB7052-131 MB7052-200 MB7052-201 MB7052-210 MB7052-211 MB7052-220 MB7052-221 MB7052-230 MB7052-231 MB7052-300 MB7052-320 MB7052-400 MB7052-420 MB7052-500 MB7052-501 MB7052-510 MB7052-511 MB7052-520 MB7052-521 MB7052-530 MB7052-531 MB7052-600 MB7052-601 MB7052-610 MB7052-611 MB7052-620 MB7052-621 MB7052-630 MB7052-631 MB7052-700 MB7052-701 MB7052-710 MB7052-711 MB7052-720 MB7052-721 MB7052-730 MB7052-731 MB7053-830 MB7053-831 Active Part Numbers for MB7053 MB7053-800 MB7053-801 MB7053-810 MB7053-811 MB7053-820 MB7053-821 MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 23 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series The following tables display all of the active and valid part numbers for these products. Active Part Numbers for MB7060 MB7060-100 MB7060-101 MB7060-110 MB7060-111 MB7060-120 MB7060-121 MB7060-130 MB7060-131 MB7060-200 MB7060-201 MB7060-210 MB7060-211 MB7060-220 MB7060-221 MB7060-230 MB7060-231 MB7060-300 MB7060-320 MB7060-400 MB7060-420 MB7060-500 MB7060-501 MB7060-510 MB7060-511 MB7060-520 MB7060-521 MB7060-530 MB7060-531 MB7060-600 MB7060-601 MB7060-610 MB7060-611 MB7060-620 MB7060-621 MB7060-630 MB7060-631 MB7060-700 MB7060-701 MB7060-710 MB7060-711 MB7060-720 MB7060-721 MB7060-730 MB7060-731 Active Part Numbers for MB7062 MB7062-100 MB7062-101 MB7062-110 MB7062-111 MB7062-120 MB7062-121 MB7062-130 MB7062-131 MB7062-200 MB7062-201 MB7062-210 MB7062-211 MB7062-220 MB7062-221 MB7062-230 MB7062-231 MB7062-300 MB7062-320 MB7062-400 MB7062-420 MB7062-500 MB7062-501 MB7062-510 MB7062-511 MB7062-520 MB7062-521 MB7062-530 MB7062-531 MB7062-600 MB7062-601 MB7062-610 MB7062-611 MB7062-620 MB7062-621 MB7062-630 MB7062-631 MB7062-700 MB7062-701 MB7062-710 MB7062-711 MB7062-720 MB7062-721 MB7062-730 MB7062-731 MB7066-130 MB7066-131 Active Part Numbers for MB7066 MB7066-100 MB7066-101 MB7066-110 MB7066-111 MB7066-120 MB7066-121 Active Part Numbers for MB7070 MB7070-100 MB7070-101 MB7070-110 MB7070-111 MB7070-120 MB7070-121 MB7070-130 MB7070-131 MB7070-200 MB7070-201 MB7070-210 MB7070-211 MB7070-220 MB7070-221 MB7070-230 MB7070-231 MB7070-300 MB7070-320 MB7070-400 MB7070-420 MB7070-500 MB7070-501 MB7070-510 MB7070-511 MB7070-520 MB7070-521 MB7070-530 MB7070-531 MB7070-600 MB7070-601 MB7070-610 MB7070-611 MB7070-620 MB7070-621 MB7070-630 MB7070-631 MB7070-700 MB7070-701 MB7070-710 MB7070-711 MB7070-720 MB7070-721 MB7070-730 MB7070-731 Active Part Numbers for MB7072 MB7072-100 MB7072-101 MB7072-110 MB7072-111 MB7072-120 MB7072-121 MB7072-130 MB7072-131 MB7072-200 MB7072-201 MB7072-210 MB7072-211 MB7072-220 MB7072-221 MB7072-230 MB7072-231 MB7072-300 MB7072-320 MB7072-400 MB7072-420 MB7072-500 MB7072-501 MB7072-510 MB7072-511 MB7072-520 MB7072-521 MB7072-530 MB7072-531 MB7072-600 MB7072-601 MB7072-610 MB7072-611 MB7072-620 MB7072-621 MB7072-630 MB7072-631 MB7072-700 MB7072-701 MB7072-710 MB7072-711 MB7072-720 MB7072-721 MB7072-730 MB7072-731 MB7076-130 MB7076-131 Active Part Numbers for MB7076 MB7076-100 MB7076-101 MB7076-110 MB7076-111 MB7076-120 MB7076-121 MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 24 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series Active Part Numbers for MB7092 MB7092-100 MB7092-101 MB7092-110 MB7092-111 MB7092-120 MB7092-121 MB7092-130 MB7092-131 MB7092-200 MB7092-201 MB7092-210 MB7092-211 MB7092-220 MB7092-221 MB7092-230 MB7092-231 MB7092-300 MB7092-320 MB7092-400 MB7092-420 MB7092-500 MB7092-501 MB7092-510 MB7092-511 MB7092-520 MB7092-521 MB7092-530 MB7092-531 MB7092-600 MB7092-601 MB7092-610 MB7092-611 MB7092-620 MB7092-621 MB7092-630 MB7092-631 MB7092-700 MB7092-701 MB7092-710 MB7092-711 MB7092-720 MB7092-721 MB7092-730 MB7092-731 Active Part Numbers for MB7150 MB7150-100 MB7150-101 MB7150-110 MB7150-111 MB7150-120 MB7150-121 MB7150-130 MB7150-131 MB7150-200 MB7150-201 MB7150-210 MB7150-211 MB7150-220 MB7150-221 MB7150-230 MB7150-231 MB7150-300 MB7150-320 MB7150-400 MB7150-420 MB7150-500 MB7150-501 MB7150-510 MB7150-511 MB7150-520 MB7150-521 MB7150-530 MB7150-531 MB7150-600 MB7150-601 MB7150-610 MB7150-611 MB7150-620 MB7150-621 MB7150-630 MB7150-631 MB7150-700 MB7150-701 MB7150-710 MB7150-711 MB7150-720 MB7150-721 MB7150-730 MB7150-731 Active Part Numbers for MB7155 MB7155-100 MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 25 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series The legacy part numbers MB7067, MB7068, MB7260, MB7262, MB7267, MB7077, MB7078, MB7270, MB7277 and MB7278 are now contained within MB7060, MB7062, MB7070 and MB7072 which are the base for all housing options on these products. To select a product with a legacy part number, select the desired housing option on the product with the appropriate base. Please review the following table for more information. IF YOU BOUGHT NOW BUY Legacy Part Number Base and Housing Active Part Number MB7067 – Compact MB7060 in 3/4” NPS WRC Housing MB7060-2XX MB7260 – Ultra Compact MB7060 in Ultra Compact MB7060-3XX MB7267 – Ultra Compact Flush Mount MB7060 in Ultra Compact Flush Mount MB7060-4XX MB7067 – 1” NPS MB7060 in 1” NPS Housing MB7060-5XX MB7067 – 1” BSPP MB7060 in 1” BSPP Housing MB7060-6XX MB7067 – 30mm 1.5 MB7060 in 30mm 1.5 Housing MB7060-7XX MB7068 – Compact MB7062 in 3/4” NPS WRC Housing MB7062-2XX MB7262 – Ultra Compact MB7062 in Ultra Compact MB7062-3XX MB7068 – Ultra Compact Flush Mount MB7062 in Ultra Compact Flush Mount MB7062-4XX MB7068 – 1” NPS MB7062 in 1” NPS Housing MB7062-5XX MB7068 – 1” BSPP MB7062 in 1” BSPP Housing MB7062-6XX MB7068 – 30mm 1.5 MB7062 in 30mm 1.5 Housing MB7062-7XX MB7077 – Compact MB7070 in 3/4” NPS WRC Housing MB7070-2XX MB7270 – Ultra Compact MB7070 in Ultra Compact MB7070-3XX MB7277 – Ultra Compact Flush Mount MB7070 in Ultra Compact Flush Mount MB7070-4XX MB7077 – 1” NPS MB7070 in 1” NPS Housing MB7070-5XX MB7077 – 1” BSPP MB7070 in 1” BSPP Housing MB7070-6XX MB7077 – 30mm 1.5 MB7070 in 30mm 1.5 Housing MB7070-7XX MB7078 – Compact MB7072 in 3/4” NPS WRC Housing MB7072-2XX MB7278 – Ultra Compact Flush Mount MB7072 in Ultra Compact Flush Mount MB7072-4XX MB7078 – 1” NPS MB7072 in 1” NPS Housing MB7072-5XX MB7078 – 1” BSPP MB7072 in 1” BSPP Housing MB7072-6XX MB7078 – 30mm 1.5 MB7072 in 30mm 1.5 Housing MB7072-7XX MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 26 Web: www.maxbotix.com PD11838z XL-MaxSonar® - WR/WRC™ Series After reviewing this datasheet, do you have any more questions? We offer Technical Support on all of our products even if you purchased them through one of our many vendors worldwide. You can fill out a Technical Support form for assistance on a sensor here --> Technical Support Not sure which sensor you need for your application? We offer Sensor Selection Assistance, click the link here to fill out a form for support --> Sensor Selection Help Looking for tutorials to help you get started? Frequently Asked Questions about Our Sensors We receive many questions about our products and services. This resource offers answers to common inquiries we receive about our product lines and their application. Fully Calibrated Beam Patterns All of our sensors are factory calibrated to provide consistent beam patterns, detection zones, to fit into a wide variety of applications. In our product lines, each model number comes with a different beam pattern that reflects the sensitivity and the detection zone of how it sees a target. Additionally, we strive to maintain consistency between our finished products, and you will see little to no deviation between sensors of the same model. This allows you to have confidence in your final application when using multiple sensors. Understanding Range Readings The success of an application may hinge upon knowing the exact location of a target. However, a sensor may report one meter even if the target is not exactly one meter away from the sensor. Sensor specifications, such as resolution, precision, and accuracy, help you to understand sensor performance. How to Use Multiple Ultrasonic Sensors This guide covers three ways to run your sensors in a Multiple Sensor environment and issues you may face. Contact us now with any questions at sales@maxbotix.com or call +1-218-454-0766. Please call during our preferred business hours of 8:00 am – 4:30 pm EST on Monday through Thursday and 8:00 am – 2:00 pm EST on Friday, or you may leave us a voicemail anytime. MaxBotix Inc., products are engineered and assembled in the USA Copyright 2005 - 2022 MaxBotix Incorporated Patent 7,679,996 Page 27 Web: www.maxbotix.com PD11838z
SEN-09496 价格&库存
很抱歉,暂时无法提供与“SEN-09496”相匹配的价格&库存,您可以联系我们找货
