28036
28036
    PARALLAXINC.
    DIP-6
28036 数据手册
Web Site: www.parallax.com Forums: forums.parallax.com Sales: sales@parallax.com Technical: support@parallax.com Office: (916) 624-8333 Fax: (916) 624-8003 Sales: (888) 512-1024 Tech Support: (888) 997-8267 4-Directional Tilt Sensor (#28036) The 4-Directional Tilt Sensor is a perfect accelerometer replacement in those applications which may not need precise angular feedback. This type of sensor is commonly used in many smart phones and digital cameras as a cheaper means to adjust the screen display when the device is rotated. Features  Small 6-pin DIP packaging with breadboard-friendly 0.1" pin spacing  Easy communication with any microcontroller  Positional feedback in four directions Key Specifications  Power Requirements: 3 to 5.5 VDC  Communication Interface: 2-pin high/low output for four sensor states  Operating temperature: 32 to 122 °F (0 to 50 °C)  Dimensions: 0.42 x 0.32 x 0.49 in (1.07 x 0.81 x 1.24 cm) Application Ideas  Rotating display adjustment  Robotic movement  Tilt sensing for remote controls  Alarm systems Resources and Downloads Check for the latest version of this document, free software, and example programs from the 4Directional Tilt Sensor product page. Go to www.parallax.com and search 28036. Theory of Operation Internally, the 4-Directional Tilt Sensor includes one IR LED, two phototransistors, and a small ball that moves when the sensor is rotated. Depending on the orientation of the sensor, the two phototransistors will output high or low signals depending whether light is detected or not. New locations are triggered when the sensor is rotated roughly 30° toward the new position. The chart below depicts the cylinder location when rotating the sensor, and the output states of each phototransistor during revolution. Copyright © Parallax Inc. 4-Directional Tilt Sensor (#28036) v1.0 12/20/2010 Page 1 of 4 Location Phototransistor Phototransistor 1 2 A 0 0 B 1 0 C 1 1 D 0 1 Items of Note:   When the sensor is lying flat and only acted on by g-forces, the cylinder will be in Location C. Upon startup and when lying flat, the sensor remains in the last location before shutdown. Once movement is detected, the sensor will respond normally. Pin Definitions and Ratings Pin Name Type Function 1 OUT2* O Output state of phototransistor 2 2 Vdd* P Supply Voltage -> 3.0 - 5.5V 3 GND G Ground -> 0V 4 GND G Ground -> 0V 5 Vdd* P Supply Voltage -> 3.0 - 5.5V 6 OUT1* O Output state of phototransistor 1 Pin Type: P = Power, G = Ground, I = Input, O = Output *Note: Maximum output signal voltage approaches power supply voltage. Copyright © Parallax Inc. 4-Directional Tilt Sensor (#28036) v1.0 12/20/2010 Page 2 of 4 Connection Diagrams For use with the BASIC Stamp and Propeller P8X32A example programs listed below. Note: Maximum output signal voltage approaches power supply voltage, so use the same voltage level for microcontroller and sensor supply. *Vdd = 3.3V for Propeller Applications, 5V for BASIC Stamp Applications BASIC Stamp® Example Code 4DirectionalTiltSesnor_Simple.bs2 displays the output states of both phototransistors. It uses the Debug Terminal, which is built into the BASIC Stamp Editor software. The software is a free download from www.parallax.com/basicstampsoftware. ' 4DirectionalTiltSensor_Simple.bs2 ' Displays output states of both phototransistors ' {$STAMP BS2} ' {$PBASIC 2.5} PAUSE 1000 DO DEBUG HOME, "Phototransistor 1: ", BIN1 IN0, CR, "Phototransistor 2: ", BIN1 IN1 PAUSE 50 LOOP Propeller™ P8X32A Example Code 4DirectionalTiltSesnor_Simple.spin displays the current output states of both phototransistors. It uses the Parallax Serial Terminal to display the device output. The object and the Parallax Serial Terminal itself are included with the with the Propeller Tool v1.2.7 or higher, which is available from the Downloads link at www.parallax.com/Propeller. '' 4DirectionalTiltSensor_Simple.spin for P8X32A '' Displays output states of both phototransistors _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 OBJ pst : "Parallax Serial Terminal.spin" Copyright © Parallax Inc. 4-Directional Tilt Sensor (#28036) v1.0 12/20/2010 Page 3 of 4 PUB Main dira[0..1]~ pst.Start(115_200) ' Set pins 0-1 to input ' Set Parallax Serial Terminal to 115,200 baud repeat pst.Home pst.str(string("Phototransistor 1: ")) pst.bin(ina[0], 1) pst.NewLine pst.str(string("Phototransistor 2: ")) pst.bin(ina[1], 1) waitcnt(clkfreq/10 + cnt) Copyright © Parallax Inc. 4-Directional Tilt Sensor (#28036) v1.0 12/20/2010 Page 4 of 4
28036 价格&库存
很抱歉,暂时无法提供与“28036”相匹配的价格&库存,您可以联系我们找货
