MS09-S
MS09-S
    STANDEX-MEDER(斯丹麦德)
    MAGNET FLOATING MS09-S
MS09-S 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – Magnetic Floats Magnetic Floats  The MS magnetic float products are comprised of buoyant materials containing a built-in magnet (s) and are used in conjunction with our LS Level Sensor series. Choose from various styles, dimensions and buoyant materials such as Polyamide (PA), Polypropylene (PP), Nitrile Butadiene Rubber (NBR) and Stainless Steel (V2A) depending on your application. MS-00-XXX Part-Description: Series Options 01, 02, 03, 04, 06, 07, 08, 09, 10 NBR, PA, PP, S Series Material Outside Dia. Inside Dia. Height MS01-NBR NBR 24.5 8.0 19.0 MS02-NBR NBR 25.0 9.15 16.5 MS01-PA PA 23.5 8.5 19.0 MS02-PA PA 25.0 9.15 16.55 MS07-PA PA 36.0 16.15 19.0 MS01-PP PP 23.5 8.4 19.0 MS02-PP PP 25.2 9.15 16.55 MS03-PP PP 27.0 11.0 11.7 MS04-PP PP 18.5 10.2 20.0 MS08-PP PP 20.0 9.15 16.0 MS06-PP PP 30.0 8.0 8.0 MS09-S V2A 24.0 9.5 24.0 MS10-S V2A 38.3 9.5 26.3 Use with Sensor LS01, LS02, LS02-S, LS04, LS05 All Reed Switches LS01, LS02, LS02-S, LS04, LS05 All Reed Sensors LS02-S, LS05 * All Dimensions in mm USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015 A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – Magnetic Floats Glossary Material PP Polypropylene PA Polyamide NBR Nitrile Butadiene Rubber S Stainless Steel • Water absorption Only 0.1% water absorption gives PP Floats excellent buoyancy • Resistance Resistant to many chemical solves, bases and acids • Many applications Excellent choice for water-level sensors, automotive applications (e.g. brake fluid reservoirs) and manufacturing and plant equipment applications • Resistance for many chemicals Ideal solution in fuel tanks, oil containers and many more • Very high strength-to-weight ratio Shock and abrasion resistant as well as capable of enduring a 5 bar pressure (73 PSI or 0.5 Mpa) • Acceptable for high and low temperature applications Under certain conditions temperature resistance up to 120°C, stable as low as -40°C • Resistance to Oil and Fuels Minimal absorption of gasoline, benzene, alcohol and toluene (consult engineering for details) • Mechanical Strength Floats are ebonite (very strong hard rubber) suitable for insertion of metals or magnets within the NBR • Pressure Resistance Stable buoyancy is achieved with specific gravities up to 0.3kg/cm³, and negligible water absorption with pressures up to 3 Mpa (30 bar) • Almost no dimensional change Minimal dimensional effects particularly when measuring Cp‘s and Cpk‘s • High Temperatures Resistant for high temperatures (>160°C), making them an ideal float switch magnet for fluid level sensing in the Food and Beverage Industry • Pressure Resistance Stainless Steel Floats have a hollow buoyant structure combined with their strengths makes them an excellent choice for use in high pressure tans • Magnet fully contained within the float Actuator magnet is contained within the float therefore fully protected from the liquid material Suitability of Materials Conditions Cut and Break Temperature Resistance Resistance to Fuels, Oil Shock Resistance Metal Inserts Magnet Inserts Water Pressure Resistance Anti-Corrosion Price Range Food Applications Drinking Water + = Ideal o = Suitable NBR Plastic Foam Stainless Steel + o + + + + o + + - o o + o o + + + + + + + + o o + + o o o + + - = Not Suitable USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015
MS09-S 价格&库存
很抱歉,暂时无法提供与“MS09-S”相匹配的价格&库存,您可以联系我们找货
